Home » Modeling » OCL » OCL Enumeration ordered?
OCL Enumeration ordered? [message #553661] Wed, 18 August 2010 08:03 Go to next message
Playing around with the enumerations in OCL I am wondering, whether an enumeration is ordered in OCL and how to access the ordinal number of an element.
If I retrieve for example the instances of an enumeration in the OCL Interactive Console by
EnumType.allInstances()
I get something like
Element1 = 0
Element2 = 1
Element3 = 2
But I see no possibility to access the ordinal ("0", "1" etc.).
Any ideas?
[Updated on: Wed, 18 August 2010 08:03] by Moderator
Re: OCL Enumeration ordered? [message #553740 is a reply to message #553661] Wed, 18 August 2010 12:21 Go to previous messageGo to next message
Hi Joern
EnumType.allInstances()->asSequence()->indexOf(...) will give you a
1-based integer.
But since allInstances() returns a Set, you will be at the mercy of the
implmentation. Ordering will only be sensible if the implementation
happens to use a LinkedHashSet or List.
However UML defines Enumeration::ownedLiteral as ordered, so I'll raise
an OMG OCL issue to get Enumeration.allInstances changed to return an
OrderedSet.
Ed Willink
> element.
> Interactive Console by EnumType.allInstances() I get something like
> Element1 = 0
> Element2 =1
> Element3=2
> Any ideas?
Re: OCL Enumeration ordered? [message #553750 is a reply to message #553740] Wed, 18 August 2010 13:11 Go to previous message
Hi Ed,
thanks for your quick reply.
Does not work for me (at least the OCL Interpreter Console does not compute). I will post a bug.
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=323069
Therefore I will have to switch to define explicit ordinals.
Thank you again,
Joern
[Updated on: Wed, 18 August 2010 13:26] by Moderator
Previous Topic:[OCLInEcore] Operator ^
Next Topic:OCLinEcore issues with derived attributes/operations
Current Time: Sat Jul 19 23:31:07 EDT 2025
Powered by FUDForum. Page generated in 0.03493 seconds
