Home » Eclipse Projects » Eclipse Platform » classpath problem
classpath problem [message #552872] Fri, 13 August 2010 18:32 Go to next message
this should be trivial, but I'm getting mad :(
I am tring to use Jintilla, which has a couple of dll containing the
editor compnent itself.
I have not found the right incantation to convince my stupid wrapper to
fint them in a dir in my workspace.
I can make it work *ONLY* if I place them in the systrm Java\jre6\bin
directory.
If I place the two diretories there everything is ok.
If I place them anywhere else, even if I modify "java.library.path"
and/or "sun.boot.library.path", explicitly or via IDE settings the
closest I get is:
Exception in thread "main" java.lang.UnsatisfiedLinkError:
C:\Users\Mauro\workspace\it.condarelli.jintilla\resources\sc ijni.dll:
Routine di inizializzazione della libreria di collegamento dinamico
(DLL) non riuscita
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.scintilla.editor.Scintilla.<clinit>(Scintilla.java:52)
at it.condarelli.jintilla.Main.main(Main.java:46)
which seems to indicate the dll is actually found, but something else
coes wrong (perhaps the second one is not found?)
Can someone help me, please?
Thanks in Advance
Mauro
Re: classpath problem [message #552896 is a reply to message #552872] Sat, 14 August 2010 02:28 Go to previous messageGo to next message
You need to use the "Bundle-NativeCode" header in your MANIFEST.MF and
you need to load them in the correct order. If DLL2 depends on DLL1 you
need to:
System.loadLibrary("DLL1");
System.loadLibrary("DLL2");
If you use Bundle-NativeCode you don't need to modify the java.library.path.
Tom
Am 14.08.10 00:32, schrieb Mauro Condarelli:
> directory.
> closest I get is:
> (DLL) non riuscita
> Thanks in Advance
> Mauro
Re: classpath problem [message #552902 is a reply to message #552896] Sat, 14 August 2010 04:48 Go to previous messageGo to next message
> need to:
Thanks, will do.
A bit of additional complexity comes from the fact I actually load only
one lib:
static {
System.loadLibrary("scijni");
while the other (scilexer.dll) is loaded directly by this lib.
The error I got was due to the fact scijni.dll can't find scilexer.dll.
In order to have it working I need to have scilexer.dll in the PATH.
So there are two different mechanisms for loading the two libs.
That's why I took so long to find out wat was wrong.
A friend of mine said bugs always come in couples... and if you don't
squash them fast enough they spawn!
Is there a way I can modify (progrmmatically or via some XML) the PATH
environment variable for scijni?
> Tom
>> Hi,
>> directory.
>> closest I get is:
>> (DLL) non riuscita
>> Thanks in Advance
>> Mauro
Re: classpath problem [message #552915 is a reply to message #552902] Sat, 14 August 2010 09:13 Go to previous messageGo to next message
Can't you simply include the 2nd one as well in your project?
Tom
Am 14.08.10 10:48, schrieb Mauro Condarelli:
>> need to:
>> java.library.path.
> Thanks, will do.
> one lib:
> static {
>> Tom
>>> Hi,
>>> directory.
>>> closest I get is:
>>> (DLL) non riuscita
>>> Thanks in Advance
>>> Mauro
Re: classpath problem [message #552918 is a reply to message #552915] Sat, 14 August 2010 09:39 Go to previous messageGo to next message
I don't think so, Tom.
The second dll (scilexer.dll) is not a jni lib, it's a regular C++ dll,
while the first (scjni.dll) is a jni wrapper around it.
I can try to load it, but I do not realy expect it to work.
I would like to further wrap this into a SWT Composite, adding several
controls.
scilexer. dll is the Scintilla editor component and I would like to have
it, together with menu and toolbars in a shrink-wrapped SWT component (I
didn't find anything equivalent so far: StyledText falls very short on
two issues: wordwrap and spellcheck, unfortunately).
That is the reason why I would like to find a way to add to PATH
programmatically and I would like to avoid resorting to command-line
options or similar.
Any suggestion?
Mauro
> Tom
>>> need to:
>>> java.library.path.
>> Thanks, will do.
>> one lib:
>> static {
>>> Tom
>>>> Hi,
>>>> directory.
>>>> closest I get is:
>>>> (DLL) non riuscita
>>>> Thanks in Advance
>>>> Mauro
Re: classpath problem [message #553107 is a reply to message #552918] Mon, 16 August 2010 09:21 Go to previous messageGo to next message
Originally posted by: Jim.Cooper.sas.com
On Windoze, the current directory is always in the path. Most DLLs also
see the directory they were loaded from.
If you physically include both DLLs in your project in the same
directory (especially in the same directory as the main 'executable',
your problem may be resolved.
Another alternative is to do the LoadLibrary on the scilexer.dll before
the scjni.dll, just so it it will already be in memory (where it should
be found before the path is searched).
> controls.
> options or similar.
> Any suggestion?
> Regards
> Mauro
>> Tom
>>>> need to:
>>>> java.library.path.
>>> Thanks, will do.
>>> one lib:
>>> static {
>>>> Tom
>>>>> Hi,
>>>>> wrapper to
>>>>> directory.
>>>>> closest I get is:
>>>>> (DLL) non riuscita
>>>>> Thanks in Advance
>>>>> Mauro
Re: classpath problem [message #553212 is a reply to message #553107] Mon, 16 August 2010 12:42 Go to previous message
it should work.
I already solved the problem modifying the first library so I add the
directory where it is to the front of the search path.
This way everything is ok if thetwo .DLL are in the same place.
Thanks.
Mauro
>> controls.
>> options or similar.
>> Any suggestion?
>> Regards
>> Mauro
>>> Tom
>>>>> you
>>>>> need to:
>>>>> java.library.path.
>>>> Thanks, will do.
>>>> one lib:
>>>> static {
>>>>> Tom
>>>>>> Hi,
>>>>>> wrapper to
>>>>>> directory.
>>>>>> closest I get is:
>>>>>> (DLL) non riuscita
>>>>>> Thanks in Advance
>>>>>> Mauro
Previous Topic:Re: Key bindings not working in Eclipse
Next Topic:Hide/Show Status Bar any time
Current Time: Sat Jul 19 05:28:37 EDT 2025
Powered by FUDForum. Page generated in 0.05708 seconds
