Home » Eclipse Projects » Eclipse 4 » Where's the best place to start with e4?
Where's the best place to start with e4? [message #552370] Wed, 11 August 2010 18:48 Go to next message
Hi all...
There are lots of wiki pages, forum posts, and so on about using e4. And
though I want to dig into e4 in detail at some point, my first priority
is making sure that DTP's views/editors/perspective all work in e4. This
seems to mean that I would need to use the compatibility layer, which is
fine since DTP is all 3.x-based.
If you were me, where would you start? I'm not looking for anything
earth shattering here. Just the ability to bring the DTP Data Source
Explorer view (based on the Common Navigator Framework) into an e4
application to see if everything works ok.
Thanks in advance and sorry this is such a broad question.
--Fitz
Re: Where's the best place to start with e4? [message #552470 is a reply to message #552370] Thu, 12 August 2010 05:46 Go to previous messageGo to next message
Well here's what I can suggest:
1. Make your plug-ins in the 4.0 SDK
a) Download Eclipse 4.0 SDK
b) Install the source packages of:
E4 UI > Eclipse E4 UI CSS Source
E4 UI > Eclipse e4 Modeled Workbench Source
(so that you can step through with the debugger if things go wrong )
c) Check out your sources from your CVS Repo
d) Fix compile errors => most likely because you are using internal APIs
e) Launch an inner Eclipse
All should work like a charme if the compat layer works appropriately.
If you want to see what the compat layer made from your contributions
you can also install the "E4 Tools"-feature if you hit ALT+SHIFT+F9 in
your inner you can inspect the live running application (model).
2. Make your plug-ins run in an 4.0 Application
a) If the above works you can go one step further and create a 3.x
RCP-Application using the PDE-wizards (e.g. the mail example)
b) Modify the generated project as described in [1]
c) Add your DTP bundles
d) Launch the product
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=317912
Am 12.08.10 00:48, schrieb Brian Fitzpatrick:
> Hi all...
> --Fitz
Re: Where's the best place to start with e4? [message #552535 is a reply to message #552470] Thu, 12 August 2010 09:55 Go to previous messageGo to next message
Thanks Tom! I'll give it a shot.
Tom Schindl wrote:
> Tom
>> Hi all...
>> --Fitz
Re: Where's the best place to start with e4? [message #552615 is a reply to message #552470] Thu, 12 August 2010 16:41 Go to previous messageGo to next message
Worked great Tom! Thanks for the tips!
Other than some weird repaint issues with tabs in a few views, DTP seems
to work just fine under e4.0 - at least as a quick check. :)
--Fitz
Tom Schindl wrote:
> Tom
>> Hi all...
>> --Fitz
Re: Where's the best place to start with e4? [message #552691 is a reply to message #552615] Fri, 13 August 2010 04:08 Go to previous message
Fitz,
Could you file a bugzilla with screenshots, os-version, ... and
probably steps to reproduce? Please add my to bugzilla with the above
e-mail-address
Tom
Am 12.08.10 22:41, schrieb Brian Fitzpatrick:
> --Fitz
> Tom Schindl wrote:
>> Hi,
>> Tom
>>> Hi all...
>>> --Fitz
Re: Where's the best place to start with e4? [message #580619 is a reply to message #552370] Thu, 12 August 2010 05:46 Go to previous message
Tom
> Hi all...
> --Fitz
Re: Where's the best place to start with e4? [message #580648 is a reply to message #552470] Thu, 12 August 2010 09:55 Go to previous message
Tom Schindl wrote:
> Tom
>> Hi all...
>> --Fitz
Re: Where's the best place to start with e4? [message #580659 is a reply to message #552470] Thu, 12 August 2010 16:41 Go to previous message
--Fitz
Tom Schindl wrote:
> Tom
>> Hi all...
>> --Fitz
Re: Where's the best place to start with e4? [message #580734 is a reply to message #552615] Fri, 13 August 2010 04:08 Go to previous message
Fitz,
e-mail-address
Tom
> --Fitz
> Tom Schindl wrote:
>> Hi,
>> Tom
>>> Hi all...
>>> --Fitz
Previous Topic:PartSashContainer: Children
Next Topic:xwt browser
Current Time: Sat Jul 19 13:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.05882 seconds
