Home » Archived » M2M (model-to-model transformation) » [QVTo] how to check cyclic references easily (use 'closure'?)
[QVTo] how to check cyclic references easily (use 'closure'?) [message #552451] Thu, 12 August 2010 05:47 Go to next message
I have to write a check for self-referencing, that is, does a definition reference itself directly or indirectly?
Obviously, I have to traverse the tree of the definition and the referenced definitions entirely to answer this question.
Unfortunately, the definition may use objects from several class hierarchies, so writing all these recursive checking specifically for each case is going to be a lot of code.
So my question is, is there an easier way?
I was thinking towards collecting all contained or referenced objects from a starting object, and then checking whether the definition is included in that collection.
Something along the lines of
<pre>
def.value->closure(true)->excludes(def)
</pre>
(the collection of objects reachable from 'def.value' should not include 'def' itself, where 'def' is the definition object).
However, the above is not working (it complains about 'true'), and I cannot find further information of what 'closure()' does exactly, what its parameter should be, and how it should be used.
Can anyone enlighten me, please?
Re: [QVTo] how to check cyclic references easily (use 'closure'?) [message #552507 is a reply to message #552451] Thu, 12 August 2010 08:26 Go to previous messageGo to next message
Originally posted by: koen.yskout.cs.kuleuven.be
closure is defined by MDT OCL (non-standard), and apparently expects the
name of the reference, so I guess def->closure(value) should work in
your case.
Haven't checked it, though, so it may be completely wrong :)
On 12/08/10 11:47, Albert Hofkamp wrote:
> Hello,
> <pre>
> </pre>
Re: [QVTo] how to check cyclic references easily (use 'closure'?) [message #552573 is a reply to message #552451] Thu, 12 August 2010 12:22 Go to previous message
--------------000807090200010002080501
My proposed resolution for OMG Issue 13944 is attached. This is what
MDT/OCL 3.0.0 implements. (MDT/OCL 1.3.0 implements closure on Sets only.)
The closure argument as you can see is an expression to compute
children, often a reference; never a true literal.
Ed Willink
On 12/08/2010 10:47, Albert Hofkamp wrote:
> Hello,
> <pre>
> </pre>
Content-Type: application/pdf;
name="13944-Closure.pdf"
filename="13944-Closure.pdf"
JVBERi0xLjQKJcOkw7zDtsOfCjIgMCBvYmoKPDwvTGVuZ3RoIDMgMCBSL0Zp bHRlci9GbGF0
ZURlY29kZT4+CnN0cmVhbQp4nL1ay4rsNhDdz1d4HZiOS5IlGZqGtqc7kN1N BrIIWeUFITeQ
bPL7qZcetuz2zM1NGNC49SydqjpVkt2foPv76c+u7557fPRgsAwjlX/93H33 RfcHN9LfX78+
Ta9PI3ULzp989/pT9+UdOui711++P/dwCefeXJ7dubcXc+4dPw69vzzbcx+o NV7waeT6K5fy
PF08dcdivjwHfZQOaTCVL1zeLoDlnVqh5xIuP7x+/XR7ffqwktW54TRsCgsG WMZKCnBUwSvB
cAFzBlwbeuyaK42IhgvSKBYBxbEk5Y4EpgeCC0sjEpjOZLgMw2UJLsCZESp+ MNSAa+fmoQ+I
HP0eRWZDkAnOQM2zwgNUDyTTjjisPO+Hk03SQBRpcDOAeNLWgAHBX4afbW8R K3qatB4l5d9R
fmO5t3szrtczIPgPFycAnyFwGbV8KLkZkiZtBybh+JxAsz3rcCAMvDaES5JU 1G1zX/430V7Q
5GaBj8fftN+dx/AEqdONTC4toVNbHBAeyj2M4ylmxEVuEOzIqNgUgdeEiadn h0BExgfggo3L
qTMkqMSBtWdpapxPnvsZTTwS9OJSCLfHOiiYMAQ3ASESCAA0KpB41DWqA0bF BgTVe4EEjYUf
4IpGuRIcVHALPYq8JbhqaVsW3IwneEaSJUjrnbxxXwj2C3hRnTnZhnTXKfuI k95wpqmWFlTe
WtIfPz71p9D9rU3ffPWElEnO/bEDH06j/Pi9+7ZloRDRatv9nuGOIL3+tm82 wa01a8kweKum
JyikRFOJolED+1wkc/o+UZGrXIhQzzQk7hMUzOw/xNFYf8VyFNeZ2QsyLyeC 4qd7T6QxpAlR
B8Rq0hcAB+tqN1E2zeB4EJMYadn0Do0zplZuuQKQNlmUK0434X9pjkqGwn/k 62j1EPQHckxk
Z6Aah36QZmS5pBhkRmQlZH1pDDJQpn5Rlt0LNj5uoEtm90jFGJvcWh1ZAbJi DbZsRqpexD8d
d3UQUyN3nAg+RVmw5+qinzw/7DKMSAgx2W2WkLiKpyD4ed5PWV6VgX0ngl+c dYAXIq9ZDUIs
DPXgqqkskXGlJlXSAhS4wV0MAO7kJGKJKqLTxe60ugHqy/aBxDOcjUmCLUxT tIDWZyVFQRsa
stOIAI7x2N50siAVLk3o8YfZw3/oR0xfWgUc2VQ/rC2qgnHa3tgbfXm5a/lX O23llrqmEV0U
fOWZdFJAVvxQLcOhVtJeEuTYs+gZVupTK4lCGhQH86BbHgAjVmUO3HPvEBtk DxThRmi59q1w
h0fMKa3Cxdv+lxj00AfjpgtSPkzK2DQWkyUQmQTjuWJTIuiKM1PweCwLqZs1 Z6z42o5MbCAq
iM6yp7MYUAGtGo70FsIDUh6z9Ap45uFpSVif4mXA6Qzp5CEpOzc2pGwcMVvR EIlkONczfIgy
gc8vu+FS/nGFokpKq5UTWwsA5YBrAmO1p2JibKxGsvxiACmmZjh0ImEUsYBJ ehPn52BtJIsT
W98KArhfICogSpIZ3ru4uZrJzEpqVX9nXhJGSZ5d/o6YMba6OjI/6zdJIykV FOWpUuGYItza
/sJOb186V3lelXAQiVcZRsU0dsH+U0GCF2JO1ewp+fM7gb9V7Nd7zvjMORE+ xJQ50j9zx1b1
niKHyjdmMtqPsS4azN3XkB9pyJiW2GOyxlkyZpMeS/rKaqlNac2nnz04LOff UIR/6H0E3SQn
sIWrNW4mafW/97ODCPE4VbWjO61dx/Z63Hv76WDpbbhZv09on1NjKXFa6szS YV4gRQZPYdcf
Mjj13Ey3C8OH2psiru0hthn2OhgMu3SHkLcqOHAlG/smkm26yCKa7ulkStFI qWkxhy8U5rP5
5WhO1yIEEOOQwJ2EQ0xeUniTbfTGXe2GGy1QXKW4SUtTzbWOz52ZUJ3aCDKt Ii7eK0yH2ark
CW1I3uU4i3GoRfpINT6sFbOX75l1uifB6E25p4xZNUvlVbJYyv+xmrAPxUtz NKqSpzzpphbJ
4Snb1xms3Ir56jYgn2XqHDOp8X8ggt1EIjTaOFLeYNsQ1br+G/hkEcrzCXoN zjI9VgdZXhrN
iWjmopRCWRrm8/FFIgrl+5LrYXpbKFJ1VUwQ1gZUDMXyBWdmUJN3Uc7lUzXa 54Ns6+WrMCZX
KHs6M2ZDCUdas2N78njhVw6CcDrAbjFkRdRN+Cfkrc1Y52wNd5fSk+dHYKVz NAfKjUsYGpyP
RhuhZ+0oZndB62C0w7vOKauVYHqcJQC0EcfINFxEzmOsT0USVvYdlX8TkDku xjrRG5nRLY9H
ipozN+ldhS8QBvkvSyWWC2p9iEXgKkXDPn5BYsZmZ2rUscBm+XWXrMdSrnbU moZsiLWY+2D8
IULkCXkqcZtl/LXpgEG6Lk6U1k5siw+3fGcgdCzwN8YhLysW40w9DOU04gNi mvuHM8Er9K2/
PbKFFKTvjBnt6gA0wpeAky038ood32tY0rEtXzyTFcgyVmDaV92OMYKKPu6O zua9vYkyvYyO
yrop+oalXnnqcnG+JdxDrQy+yeMbWZJziqRTZYjF845VpCOWpo2VWdawCBOi lHkpgRjEsoUD
UsOD3N84fa/XRJ/6vkXuI2uSrbi3mpoPwdWBa/2GJRPIXELmEYk40xIkpVOS /iB9DHqlhLlT
qFK8FHjtVa9ncJCuXt894BRTcoaV08uLeF/yADvjTg7EhaHJdNLdpVxgaAYp yvNZ/ynRrK84
lke/ok7LiUdJGzgOg1+9idILi3TnDLVOg/DAf3rmX2QFKc/7hPxn9xwx4jmi xfsgqaFvIBqS
fVNytbpDrUxYkpKcMFYnLjl5mDoCHSQEEOz7EoJ/GQRCzf+ixDK0OhVWlLox 5O3EX3tpbY51
XDAbEV5oUK1ZFrWY0b7Ym73bgSJtvnGViR7HWlwQy+VHEH318QG92pbPH+TT HP5yQUsjuQvJ
zZssC33oaCk3YsCgb5co50Zlpk+XRAh+V6/SRLqfiAMa5McOnVoe6a29NLiT TQ30SA2518du
MPRiIA/J3XJLGiNSve+LqtO4/kaJ9ypfGQ2azNDzTF8cOf2Iyi8/kZIvlaBU D/LRBoZjz69t
HWMctGLWCu5Aj1VgziKOfRcMfcKAJ+aul2388oVUj031h+4fWZk0mwplbmRz dHJlYW0KZW5k
b2JqCgozIDAgb2JqCjIzNDUKZW5kb2JqCgo1IDAgb2JqCjw8L0xlbmd0aCA2 IDAgUi9GaWx0
ZXIvRmxhdGVEZWNvZGU+PgpzdHJlYW0KeJy9XMtu7LgR3d+v6PUAdsSHSAkw Gmi33QGym+QC
WQyySyZAkAmQ2eT3w3qRRVKUum3P4AJ92xJFFutx6lRR9vRsTv/79t/TdHqa 0tdgbPqMK3z+
+o/TX384/Qdvwr9f//nt9fu3FYZFH57D6fvfT3+4mZOZTt9//ullMuf4Mtnz k3+Z3Nm+TB6/
zlM4P7mXKcLd5Zy+rXj9gp/0/fUcYHj6uJ6fIn+lAfIwfL7h5/vZpM8b3DUT fprz377/6dv7
928/NrJ6Pz/Pm8Iaa1BGJYXxcAFXMvPZ2BeT1jZTGpovWhItLQhPoQhJHAdS DiQgbU3L80IC
+JOxoq00m02aMmnSKaTFLExmZZuy2XQhgAALDpsu6fNKzyQhQQM4AEcbM73K hPjgCh944ZUe
Wmn0a9oYqDmtj5dpLW8WGowfMd2OaWyew7AQZkka8UnepBt6HG8YS7edOc8v dkkrvNhI1kz6
WmQRlobkXdMaWQ84NN0A/RpnHA2lp9asnKIL1tVA8bOZn92G5sGC3/81NFVY 59ZQiyhvzhrE
pfHHq9jA3FinST2GRnltw0jjZZvFPF4b3UsA0D1eOOqJigC3PNvIE9RU4mnp jjKEeNRaGyHS
vsjE9y2i/Uh2rOYdBWg0KTRbpR/ZaDHPtrUSO/5FHIx9eBZ/NtpteGcL+u2U HTzkcKHBKD3H
zVPoHBDnDslZ0f45OkTRtEYxriwE+kL1RtZTcvaVHqawgSXQuCVSSL4JpIDg a+zVxVcBitZ0
TpxWVJSgYN0w+SiqJvO8bhjgyGIhPvvWYhTppEXGjtqL7gwBw2izDYXWWMtb 3IqzZC4diqL1
dDlozSegckn7djuYx0CsVkeonbQA8tBrsYqpoFSDH9tMobFoKLSOpyM8TbgD kGHDMkemnJ0k
02JKMhGKVLQpSUXEwf25GgFFGZsOqvxd+QV9BrLAu4rQNk35xmFsExAYZuWx dw5yyMVLiicX
8UenkJ9u61Rq6yDia1fJn+Jkjr0j2aiYXczLspD5UhoZQeUCiu/Vf2Qvt/bc g51YhVSbZhMo
IYrEHmzY0aNk6AGCSDrPoOTK3XTVrOQbMf0rOnatndntEbSLOywSAqzpOikL mu5ysmBaQDLX
RFzQNwbPJWH1g3NP5dCZAYtnctLhTC5uinAHb+uRjP5flBbx9oX+q5mb5BF0 xhQgBgHDSbZU
S9IgtZC4BUNTwxjuTb/OZSuVBZbsJjiZRc7vJ7wGunWQmBOvTD9nYjmKklS5 xE6zRzEyTT2h
0DyBXK8jCQwJxUKFIJjCvAIG0tLbU3QXGCsy7yAOnQAwanWayCnIaTSq+LvX XEEihgZNXeqr
Z7MQNnsBM0ff5XB7Sc7OhlKhi6pzmSfVVURKpSnSsKgT8dfK50nDC+zQzJUW M04XXiDITCOv
mnmFwk47D2esqHwXndJUjKukb2T1jEJWU7dcEzEswizuihj1mn68HWRhvyyp TOl1e+Cxc5j6
LHxJHmMKgKh8qhBV6b9RFKpwhAWS+kaaqvhumsQygabnLriGr/NOoTUNnRIK tUwLPsfc7P6K
CEEmOUqb2WjicYadQ7JCr9ojW/jQZ9i7uau5YBSmfZJV6sDNwVklNutFsyni 55eaNedoG7Cq
CptsCUBze8RQOt68waqF+R3XHuQOWByBpGXbS66DaA6dKQISAp393iRHeaED 027RP22Y48h+
zrXWU22WyIRjtweQfE5MVrPvW5mmZ1Kt3jbrySzFOZktawEWtC3v3wrdrfYN lxhqdt1R2eYe
XR9KKqWa+Y4L/RXaMa2qjyxj1j4vf0lVCJFkVBJUyT6DfI6X9aWtRKIkozzO EFSNmwW6VFNd
o0LFXAmoukcD8XjBwJjH5tho4hwF1tBSYUPxR5aa5r7A5xL4JknpVScjEpc3 HtCNg6RVGYaR
r+JHYYqt1Nxiyo4jN4SV3UJmzEli1USsyU8csNdMtfv4aSh6gV/lr338BEUb 3olmdD28sdUg
vjozHNjNr6bnEYrEFf6r1fsFIaiahtHEtqbgEOMsdJtCYlR3dDPvipQeh4e+ oLmqBk0W0DZJ
cbfbkmrHuKHuI/vE2HMLrrQuKgUVh4pEaxGrLuBLcIoROsUJLFBEYUoQdUuy MFycbFQu+43Q
unFVSLNkyKVUPmZR7KJZv5w1ZNBtakAING9VE0X8VfULWHgYZqxSA29mSCRi Cqde+0fmCh0I
hmlRemgPeTaQ7sv6nmaFf9aaGW1p3gDKLj3TtHrsaq+7VaBPmYFzuC2FB1ar tIu3s3XYz0XV
Q2595QwLJseoIhKHl5NQxH6X3VVdqpLmfILH7Zp33PwNusg3nCUy06SzQ7xA acLyCBrsuDdj
5Ss9TY/A05yUcDo7YcjjvXn0EK5j8SuOtNgQohHv/DCMsTjGYnVyKV/3Ne6C k1ycNG5AD3r3
EAkgI38lSrnid3Dyp9JZg/Gq4ngtI5Oo2Lji8qAIh4cRZ7KnTBTZkLsyu1Xl ITkeRvDh8yGC
BwoBB8sirc0XA13J7D/SsDcWQ57AeRBPHEHWVGYnnIdvedmFnsKfZvmGpIPt DVjoCL6MHrdy
DJJosURsmW+V6Dvz2uUWzkaVUJ4rz3DJm0GkZmZUiY1STllZPMzRQs10gSb0 pExP4gd6Ws2x
uS0kxahBs081XDJub+IDbHQ2g+mcfSKescUn233i1ER+N2qeJggKerriYl50 Lb2Dc6XwXYux
E0B4kxKODfjb2k9OKh4w4O3Di8vatOjXzDLENb9Cdu0teORBJjy71uS/k35q 43zNLF+j48fD
/CbPxYKZb3zwzA5dhY6l9zSSpO+VFHMGbZmGoVh4uWAoTEnhY9yLXmLIvqD8 7M195B+TTxy7
8Y/3c9zNNF3YU2sDR1YqpuHl8cg71LmMvt/EohlB2CTdsiHPIrpdFIbNknmn LIaonmSy8EYS
nJYYoMPQAeKzN0c8Om/iWmTAZRJjkMt9EhgfnLkQAXm31GxKOTV8epnrpz+X BryZRzaXqmVo
7lA8tnJUUW8TmW/cp1NBOfRcmzCtF+rAc+3qVL9lymW4gZLTTgUAUIa0B9u7 RC3zMHl6n4JK
rVeMoOieYYrs2DRDdm5C3Ba+IMyOLEtIbHZTlrnIst4ri50ANQbSHMFAQzg7 fKyQj94ULAw0
zVHPHjeDNkylnyNJYKgbG8Avwir9gtZONkcIamXMlmbwSDVR1oqhRsGb5AkG iJDxJ8MXVBUo
dcoc5pVJjmHXxGoeewXeSRZ7p/0vLYeqIBPAhkTwVNfGknDoaC4tl0qmfQ3N S/r8Cg2ViT6p
oQ+pwWUtlGxi8fpdWvBB6uNPaqFM9BktPLT7ve0ROtqO9alackjopSgkrMwM KR4SpMIENona
EH+wOM/Cfi67WT89r1s7P4aybh81a2Pywl/mbFVDuS2XOXszPqgZt1hIOr1m Bi4KTnQZ532T
Cs8NzXyYA1f7GJ7Tz92aR0kdBf2EkBs161YlmhnsfdVo3QKRcNExeSMzlxf1 cH5owyvK38p6
nNKAFS1aK8UPQvFjnfodM7OnfHCSaDKIF/nNf3n3iQMf2lhmiCUuzhBSW1ZR PSOCYaHjRMHH
e/L4EmW/JxBj2zW8ncYyxCZMNV6y8t/b4Kx7Xxp5r7VjsdMN9TMn+9gN2Q7c 3KxrUmuzmYDn
EC47UZ/iWVYlpGWoTpuhc9iCWpWj61i5q2rW9fIwGAbJw9TJ4x5okWK5xM+D eN2M5S3J7hvT
6zckbN7ZDuv2KcVHbbXfOQxns2yuD5C/52b4olTjZkPzZR6vfGJBt1qxCQGv UzxsWd3CeSX/
+RCc00NVTZetq8EcnIljlgGBlyjbvhY3zYPuy+k1O7qr9zRyKAe4quyTMdCN MNAtCWM2LVqH
zkPq9cW2jn65Y/9XGcyy6VZHcBdD33d+kA+ZlDWinmmz8BWmaNh7h+8Sw9lY L9Z4H8YPtvGI
usdF/QS23Zq+yXBFV/xLLJMCfnxrRNxAtSSF1aRSw724iX/ZUOWDIH07Z6RI N1EBL/l99yQc
zcXdVBH0kZNTKSrm0DS79GddasUc0mC3x4IttOJ+Myv6EDcnh+RmPR7xXs75 RcIj7owHRo94
KEVamEdNqruLWgNrqomOYwPPt/ulx9nJWLO5xqOWyMVa1B2jgf/ieTaThfhy 3HtNpctIo48j
jvUI+Fs7buQvrJq3sCj6dyl5T5UgEse6baDUALvEH5qzyv3Oc1i+bvdunca7 L53iyr50WW14
r9u8SGuFbwhdyAfVaPLCN4fHKNQbMm6Dn9Maq/Am7ulpHxU7cPEh1Kocm1/x bR0TvS9Q2pWn
iIgyfQZdk1F3+JvbdnYQh65nqQbXo9bYdaeBEqGftbV5gXq37iZpu4R6go+C kDMIfxuSUN/v
LdcDqL4+NUGqS0Ljb6DzmzzIdWNxgrEi4dRlW5Ef8P3knAOPyvkT43/MDsgl 7Qbz+wJHY4t+
cirXdTz3MXxH98nys97tx0qt4fQzHJD2ygRj7OVV7MM0nniBt6Yyd5IzT9UV 0kVU1gMNXmh4
weuo1Sg9lHfVg4h68Ll93+Kx09LSxXNX+OUH/jMOO3LpUubHE2jIw+kI/OkL e0rFzJL/8gXp
7s9//JaVuPg0coG3bH85uYm//vv0F74Bh2t8A77CjTzql9Ns4Zdt8yN5WL4j z5BUj/1BDgnJ
8icuIr+F5vHNrUmKdbIt/w2O8FL9hQ36QxemXJ4NVfX4Xhz+sQyDPkIXrnyB 8rGHkMmazSKu
0ykmHw0n7+xpom38/ANdXrvLP57+D5A9paIKZW5kc3RyZWFtCmVuZG9iagoK NiAwIG9iagoz
NTY2CmVuZG9iagoKOCAwIG9iago8PC9MZW5ndGggOSAwIFIvRmlsdGVyL0Zs YXRlRGVjb2Rl
Pj4Kc3RyZWFtCniczVpJb+w2Er77V+gcwB5uIiWg0YDdbgfI7c0YmMNDblmA YDLA5DJ/P6yF
ZHGR1P3i5AUGZDUlksVavvpYlHrS0/8f/jep6VHFW69NvIYVrr/9OP37m+m/ +BD+fvv54eX9
YYXXgvNPfnr/YfrHm560mt5/+nxS+hxOypwf3UnZszkph7ez8udHe1IBni7n eLdi+zNe6f7l
7OH1eLmcHwPf0gupM1xf8Xo963h9g6da4VWfv3//7uH6/vCpkdW5+WkeCquN RhmFFNpBA86k
57M2Jx3n1iq+mhsNiRYnhF4oQhTHgpQbEmjjQV1aJQlcVtcSF2th7Rb0BYsE OWiZGmaLmtCv
8GCOF1gqTMRPdelndHpHmSjNY3pXh/gOaJMGN2ZLRrSoX0K8NiLioF6TDZY4 KQmIA6IcynGT
oUbHzZbtjE0etAxWjX8Hi1631pFf129olA8ZaqWh/o5Tbg5VDJqEErpGR1n3 7extDInaziZ6
Po1o1MCkPq57SZ5HAklHcFEuaiwLmItMV/bbsB8i3qnW+4orsfM/n20VF5fs h1ZDbML8URhL
Nkqa0sEqBqUkFIZMDAgaTt8RZxwLvtbRCw23q3ftn9wfjy9+93KubfBCznjh BWh8VQn9k1YO
fGOOsL82MupnwGLP+nQ0s8tqYO3Qs2Y5iuWL0uhr8tasTn58GXgKr52dP/qe y9bgqHDF9qAk
A9BsAK5PJsSfC4C0GJ/Gk/4LrsS3wl1cTAogpgywot9LkRp7GoWdRivYV7Nf n2zrCo7XFGXn
xHaP8GDabdmTlDcKX0fHPcFhj2cHORN2fqF45q7lbsR6CouyLK0zkAUanDLr l1slCnKACnMk
KMufk3XrUchS15Ksykr/kOMJUAhRfU5aWrEkMmOw/JXxvtAPctJ1ShdN7Lkp CVtnqfSUocSK
e8h8b/VCi9q3GGfwQ7MCcXz/ZdsPrHsyjR845Ju1iu5DocZbfA/RlW/J5cnl 5mnziMmiId2+
5S4b/M+ehr7xUWtMvEq6QutjMMLe6MQV0jjCj+4MBhlkWeFy1S1D4ok3PGqO OzIzcJAjjzLm
KbTI8pw1nFyA6eMli2SSAgprr7BG2NfphW5w2MIFtFBDC7BoEgk9rct5gVRs wTRSZ/6PAa80
fAeqBSgYR3j8lfLYLrC7de22U/oCzp4QEHebEhrNGD096qChm1LylgYKNfmC baeyixny6oqa
CZKZtJMwMSohJBbGsG+b0EmysqNpNqOBe3iobedVe6gsgr2sIWWc+nfSScI3 mLeiwXNZUkIn
msKnGWeSYwveFx/DsDfuQTC6uLnu9v/CTgIHUr6u0iVBre99MiGLAODn/EaZ QDI16Gh0hmOy
TWfqUzHUFea+1ckOosKrpDgzaZM2n3alOg9VYmC7gYQe/NxAU74NHDOBW4n2 UyfYYhjwciBu
gXs+Yh1pTv0tXnFsjkXtAPKo7hMQRvTMHc16XmD7Q36DpZ8kCLd66irHpp50 fyVpdxVifZf3
CSZuYTJHlinbEYqSHNdA6s2ZIidZXeR6r0PaatmK4bXxFcULO6F1Iz7RLiO6 cCmuXDMA6bKP
FJJk59zIXjLTvkmoE2zkJsRJJRHBcDnwkjq1Figj9V4E38rsCnJ67wJHYGJc n9lvC1LeAd2q
6rkQv7Q10lUartlypgGyGlBzRt2yvI7ONTv7Nk3AOpsCwwGyt/WjuF/gepBk KGn8QQK+Uwuc
FgsgD7dql4L1NXNeS+pdq+Vt0kM78IgjF9K2L/ZSpoiIpiD/oNrekvsL92oJ LqRlUpjpq1Ui
DAUr44GSM+Bl4boVjhJkipMk+VZzZMkTzcrim0ESXWpKbmyVcjsPPAC1DnUX BFRUbNEoDm8a
NBMKgbUiv74xmI42EWFg9CMvUXqDtWxUIb56bmgQiGqVB5WrA8piw9JRFs2M Ief7wNSDzozS
7TXTF+rgJXlgjuCRWnDTMxCOV2x3meTcTibsnPeIppxz0brxzOwFN0nPWCa1 fLoG1uEmPAuD
+V1yUI09gDCgEWk7DS9Z6hJH3BXIqi5TGbCRfTVsGy1L6HLzGIqXoZW4gFxS /VpAGjHD503+
rZR12/J0JGFV6MhZCcQ0vKhus29HRqtb327KFySAtannsi+JWec+ElP6QsYL lmII6VOLXVHZ
brMWqaOT2/Ese8GzMZpBvY1Gc2YPJeo8ehejoZpuwsYgSzqp/ps0Qf9fdx3X BNPlR3JcVztu
de6xV+ORBGflRHe2aHkuXW8jWOxz1/kW5RLelrl0pC5eMm/RhlwXq1j+eC+c acym1BUjGMlq
N0S1pXI3PGgK6QR+tw5yILbdrdjOxgzsfZAa46azO0X9SDeoFTrQ2T5c2G5/ 8HVgy8z9mefH
w9Zoli+HrcFoN8HWLp5E6rW2/rXpYay8rg+fEopq5pbr4zZn7F8l4nxWUnyN PwEg9HW+1CYj
yY4B/bjQjAimYyQRHzZsqziskRAMV6bFzmP33MwqG/PKhnYy6P0VesHXCe2K bkhXGf3yocMI
/raKjB543FhLjIe17JvFSrehbTwObfn7/qG1UaY5tCZvPHTjrt/n3HG05VyV L57EJ7gETGjS
aALQr/RN+oorgP43I3sFhQ4kuSevbg0+o5ZHy5Q+vRkRM0BYr9xoop38E9XU HzAeWKLvw5YQ
FZJUMtnzBB3WvmB1gyf0/b6WJ4wkuc3WZtz5vrg0zkTyMFDjgc196Ks8Rzrv +giblwJKVNuu
xa3pqDzR4euIDu/RMeFr4riDuWh9NiQTwmBX2B4cDupqNvNI0WnEuXSoKsNN EQvrN8nA5Zu7
vWVYWR97uXHtNbH7NIEl3Bo17/EI2MI3BembXLLRP799yMaKYO+nBcjLr3Hn yrf/mf7FD1wE
GH4At/Agv/XrNJsQ/+cu+bX8JPUhqe77VDiln/LxLZZO6PPZOVXPHTNNx18H +/rbX/oEV5fm
WS+sMo81DYdkMnDDhRsorWNZI2s2i7iqKZglasdZMylaxk/fUPPaNX+afgeO 8KNfCmVuZHN0
cmVhbQplbmRvYmoKCjkgMCBvYmoKMjI1MgplbmRvYmoKCjExIDAgb2JqCjw8 L0xlbmd0aCAx
MiAwIFIvRmlsdGVyL0ZsYXRlRGVjb2RlPj4Kc3RyZWFtCniczRvLauzIde+v 6PVAO1WnXhI0
ArevHcjuJoYsLtklEwiZQGaT3895VEkl1UNS2wODoZEl1Xk/65TUs7787+m/ F3W5Krz0GvA3
jPT76z8uf/3p8h9+SH+//vPp/vE00mvB+md/+fj75Q/v+qLV5ePnHzelp3BT MF3tTZkJbsry
pVN+upqbCvR0mPBq5Psv/CvX98nT6/jzOl1DvJQX0mL6/ca/b5PG33d6qhX/ 6ulvH396evt4
+r6h1Vr37KrEatBMY0aFtnSDMWk3abhpxK0VvjrfBCENEdIqJgHJMURlgwIN nsSlVaLAzuJy
vFAFwm5IZMiWfmOU8ZYFy7ymFwxJiuTzOs13Pd4yN2PSyqFPiR9H/N1Q8iYy RoaI3bvgxv8J
jfYROevFjITZWmhiCcOzqWMhfklhTDSqUqMcmXgE3oCGkn+GKjQLSCHTHQkc EHRIrLCovjVp
9GTdfghoGxsamSzlE2FuisD0SOImBcFkWMosbHkk1z5jUL+SqQgwHY1ouw40 iRQGsfK4TmXC
douS36LUQlNQKCJTZ0kjaiDUbTEbPT6P1dUAwryZMuIyo2CzERpnPhOyK0SL aalhHEgNoXAM
4faFLU0PKJsgUHMlzEgC3RZHnRWAr6DngEQMrW/WkzqiletgkNRBEKASTEsH 5pwKjDUkxJKd
IwrwFkW/XUvS//hXR3S4ym6xCbWQdPOYABsWnK3pCe6s8Ro7kORq3OgN1mbc MQGehyqMg9a7
r6QodAdI7IbMDIGIzGTGm/l/ihX1WNLHazV6eAUvWfTsMg0Qo6T2gCLa+Dc5 gQ3ACcUqzYbD
kf6I0GyDkatmCG8UkEUedm2XNt4uE4yktu6ibXSO2D5BLwfxbtp0o8VE9HtI 4G5QmRYhRUzg
/I25G1LqJsf2U1RIjMTkrZS8ryw9TfKCmI0NZ2Ni4hZfsAw2whjkVaTRM6e7 6dX5sKVyJHAw
kbrmyNMEMjhkMwcShf6lafZkiIdgsYyrEHUgesDo0ILKtZ/JsK1Y6MwGFSmA StdeNnG8aq0y
NBkXHc9Ex2O7YQuQbOKZIMcyH9KDphC8w+C5xvQ70Ktx9jnUyTqSvIPDyFxb /RvoliO5g5DS
nE6qAhvbGe5h4AaOLuMvtTrgl0s3v0bo0Svfqat57yNVJiGFObfeY89GAieX xi7K6JdppDjX
A2YHVUh6ifO9TkGyhI/loQTSgcNTFtnf+B/MjO2kivHFFmR0fASL43F538X3 tVeA1ZVrrKL+
xdSYTamNmXoVQxB7F2Mdl17mfTYf5o+XBhKMpLz4XPIKss8OYrHq0CpBEMC5 L4TcPQ6mThK5
CJ/xz4VC0y0GU5HYD8nYtJ70TFeh20Bbbp2rIpT8e8z19xK8db6sPpvdoGNh f0s3W7Ya+4tZ
p0uds+h9KQKkjrFmXbMDxAedRooTrrW2LEyjaaEArI0bM4nmSGWqV1sRWxvM wzXYwlpTRO8Y
V1THPACLfsgBzwZC3KfKjotS6e/bSdmsAS17BJQubpZqvk7nIPEIyupa9oMg uVdirB/YzFgW
2Se0cI2F8+K2Nq22yzZNTJa5AS2GzrY5B5OQF5+rZ0PmLFnH/RaLQ6EE8tgw 5BWs5deR/lD1
t1it6xSRUxyBJYPnAQ8UA2VkIcWwgaLd7NhZcZ1ojCKIr9jkfmhA65CXhIDU lmSmVNIMQIFq
lkyvLo8PbJkMTIR55bpoiH2LawF1isJNaSzkN/VU4tSwJmM3ZYk9Dj6VJQdz FsoIA262biGt
nR21Xa+ZcY2a2tOX1joDaxq3PjMbQzP22bGC93QQ0cHWyZi9Lt8a7acSg+G4 6BAO9IpGU7zZ
VsHz9kEfp9PFFinKnd3sRaLW1WTB5FgokhC/LDEqVttztE9OG50d3XVHROCG BrlZKR8e79DG
EWVfgidW6iZosKxdETSbbsvYDXqir7PA9f77SsysvrgbGZZKgMrTXWGZrbAe NW+qxWpS74hl
4AB1RiwjtIVCVUw4wLFVdbSnOUZvWgPa5dgai6H1DMfWKiwamjz3SjaJzWbc TIU6/Ye4eW0F
/TXjqyFTLVb96Hu1yRP0XOw2tycNuVwNx6b8KKreWCG3fBkgB5un3fBY1gUH LXHsBy6vyKAK
etrmIZsdNWz2ZQdX0M+wpzZJD04E0PJ7dKfhQYaN5PSKAs4GHwZRMd128LGw ltx+8MFuwlUZ
TZEnTi7bExhoANiN5S2Io6vKnnu8bskGRyu8GBSgaDjs6i+fpzW9GF0DaqDO GRxtkwwVMHnH
nG9BxEpHp1qFI04nJBjag5rBf0VI8LYUeHvuJgLXvhyzrkW+nsK1G3fayy/B dTTuDaWcGgEn
FSWcqMqewZqT1mgrK9DGsrbUtC+4zL6WaNMvcnfdlGKqzck+uhE3cHKvs5sq /O72CoymHC32
hZAV2KkzVdlOUDOjAhhUbw3hgTRlaCMjW/vwtorza0C7URsc1d4l6n6GhCqO lgOCp9q7Lhqa
b/U2JCGMVWzns6omY6rJmI4EYZh7mWzsfHs5cTwlXTpeAHWkDwc/E8yakV35 mxAavnDYjwZd
bpDlGaoTRvIRupfuUzwqjlnZy6znQVR+2kMGI/1DC41Gsz1/anfkwmdQ5bx+ ezijnUZJSFUQ
n9/RNRxdCtgdxzb+ADVHdXVwuNcyWQgUZCq0fMn+gfF0jqoKnvdCdOpmm402 5afa+s22wMPJ
AcNclcJO0SL26IZyV6qR3NtmqSgG1SB9gVmyyRewe2bpDlCzNUs5BvXYeaf4 RLZ5HM9lpKRd
Dq3EZnopCSTmdM8t1Zn4MoPhSq8m2B2DsaHcDj164EjKS9JQ2XgW5eUKYE9Y 3B4Bn1D+3KhG
yNPDkMro3VJFo3mGfEWZ+BqHlvaGq7wTGOcTmcnp9Zx7DbTtRHSEs+Tr9NQV 26K1gH6ruasO
4ZM797z9NoNZq2U5f2aBNvDjyc87j5nyaZYMngrntWmevq5QjitjqDD4gCps ncEziijM1G/E
kOwz0OiWmY4yawvFryXB8Oxy1HZJKbtWwG1dZXLU8kar16v6ap9PiWTDRwS+ q91+O6F1lfLz
ChY7qTNzRsULN+GgmmFRc2tbJtXRhl76UtVzNCdNFi15dhRos/kW60ovYZO2 rNPgSb3Lu/dl
i4lnw0MutfRy5/uFkbJelapTo7M2BnB0oCXDMFv8vTknBefWa7LvIBYDXzWw 6RC2hY0/V/Yz
+azUajYlr25N5Ew1Qp0YzApsd8JW3KgmcFtB3B9W6MxCXzN7lwMLmw9a+KhB az6v6URgSdXO
tF2bSo/EYUXcMJUD6ahvOjKUT0ryiD0kNpc3F5GnKcI6YPFmW+DjYfg7ZfPl nJDkQYgiE9Te
Ua904Gw5dIH01Q6hzIUdviw371OsB+rlz0pGbVOhSVMm46VmSLt/SFH/6KTG 6tHMpxg1lTcx
4iTfpfhAR1zjOVeO5HLIiYiTS34W6Ke9fwauje6Fj3sl8AztlS+/8enoe7SJ GfT3CwG3NEqg
D/Ro0IopI32fJ2j//MenGf9AoxtuRX+5GBUv/335S3xgkab4gC7pwfzWL/F0 6bxkfm1+ktYI
Vec+G0z+tHyIx6dQ5VM6x0FHPFy+SIhfCvr1d4DyOZ5ebjvNe12YazztvtEx 1Hs8X+6ptZMb
8q2WXc0yZxJHdQlAm4vWwEUJGz//JLfH4vb3y/8BKZNDNgplbmRzdHJlYW0K ZW5kb2JqCgox
MiAwIG9iagoyNzU0CmVuZG9iagoKMTUgMCBvYmoKPDwvTGVuZ3RoIDE2IDAg Ui9GaWx0ZXIv
RmxhdGVEZWNvZGUvTGVuZ3RoMSAyNTg3Mj4+CnN0cmVhbQp4nO28eXxURdYw XFX33r699+0l
vSd9O510QjqQkIUQiOQCCagh7GCCRBJIIGHLCoKihFEEEQWdEdcR3EFlaELA gDpklHFBGXBc
ZkZHQcV1Jsr4MKhgur9T1d0hOM58z/t7/3t/052qOlV1bi2nTp0659TtdLSt aEB61Ik4pCxY
Vtfy5v5nXkUIvYEQtixY2SHrP045BTAE1cyFLYuW6eevmo6QugDyyxctXb3w 06F3jEDI+BhC
I4ONDXX1H7R+aERoAjyPRjRCwYrIL0SEJvKQT2tc1rGqU1q3GfKZkL9/afOC ujfTDushfwTy
U5fVrWrZyPcD7uU2yMvL65Y16B6wr4Y89Cf90NLc3rENZUURqs6l9S1tDS3X zfmwAvJTEdL9
FsowfOkH2sQqmiccL6hEtUar0xuMJslssdqS7A6ny+3xJqf4ZH9qIC09iP7f /QiHkAuCW3gS
ufggciIU/RzCFzSNNEW/oPU0JV8Bck88ILQT7cZNaDc6jF7EZ+CpPegg6kav IgcqQw+iNehX
aANSoTlQciuaDl8Byn+FXdFulIMeBl56GB0D3KvQjegQsmNn9Eu0Fq3n3oKn 1iMDSkVj0VTU
jG7Hk6Ir0Fx0kr8JFaFJaDlqwZ3Rqugd0buij6HH0UHu1Wg/0iE3WgDfY9Gv hT9H/4qGwhN3
o/vQSXyXZj9SoJdOwPw1akP3czU8ji6KnocR+NG1MAYeVaJjuJeEoPUG9Dl2 4jXceGjl0Wg4
egSwvKgGNaL70SFciCcSvzA3Whk9huzQxypo9T7UhQ7Atwe9gN7DeuFM9LHo GeRC2egKmE83
+gPu5SL96yKllNBApSGoGGqa0W/RK+gEDuDfkWZBL+QJinBd9G1kQ8PRLBjt k/DkZ/g7ciN8
13Iv8xOi45AR6HInpTb6PfoIu3EOnoJnkyGkmTzEtSE19DgcvvWoCeh9L7T+ IQ7hA0RPjnOP
8k/zF1TJkVNRI6xIED2Afo1+hw0wUxm341/gd/EnZDyZRx4gH3O/4nfxfxTr YNbXoGXodvQ0
+g5b8Eg8DV+NG/EavAHfie/Dx/AJ/AUZS2aSJeQbrpFr5V7gx8F3Bt/O3yTc Itym+iJSFTkS
eTPyXTQveguaBvywDkZ/N3oIZnYQHUd/ge9J9DEWsA4b4StjP56Fr4fvjfh2 /AjeiXfhbujl
BP4Yf4m/xf/EFwiCr4p4iJ+kwjdA2si15FfkQXIcvifI38kPnINL5UJcIVfC VXPNMKoN3Fb4
7uc+4t38cT4KdM4TtgnbhZ3C08KLwhmVXvyFGqnf+PHR/qz+DyMosjGyLdIV 6Y5+hJJgDd1A
BR8qgdHXwXcxrPc24Lg96C2sB9q5cRYegycBZebhxbgVrwJK3ozvx4+zsf8G Pw9U+hP+BsZs
IF425mGkkIwjU+B7DWkgrWQruYt0k3fJeU7kdJyJS+KyuIlcDdfAdXCruW1c mHuD+4D7mDvH
/QjfKK/lfXwqH+RD/ER+Hr+Cf4j/nP9cmCu8Lnyq0qqWqW5R9aj+IY4Qx4hT xWlijbhFPCC+
ra4F7nwJ7UfPDt7z+BS3jivn9qM7SD7vIn8gfwB+nofquUoCnEp24o3kBtxN 0oRVqtFkNJ6M
zvBBoPXLZDs5R0ZzlbgCz0CLyfBYayob/xQkJfxLqI9/Hub2B2h5lUqPbyTf qPSoCyNSDH3+
nsvlQ9zr6D3uJBb5h9H7vBY7cB95kpsKXPACP0aoQn7uQfQbrhXfgPaTcoS0 F9SbgY8n46dA
LszEefh7Loo4Mhm4qIj7BN2ElpA/oz7YxxvRPbieX4TuQPl4DfocPQG7Yoiw XJWlSsKvkSZ+
E7HibkT4XTC7YpyGOcGGbsY13P2qb8hf0Ap0nNeiD7lnYPTHyW+4Sv6MMB03 wg64Ad2CWqPr
0Gqhiv8jXoQ4PBul86dAuq3h8ng/pGtBqswFmXYAdvchkANjuUoocQLnTAK+ mAUS4n743gty
ggcOaoI9fhVIsT+gbtVM0oMWCUYMUgch/vXIdDQn+gS6L7oILY/ehYaCPNgQ XQMt7kSfoi1o
J14fuR61oBTYOR/iScIEclyYEB1KNpG/kBlk26XrC9ROx070FXx/A5kxwnNo E/8nNAOVRjdH
3wHuzgQJex+aj65Ep2GWX0MPl3O9KD8ymeyNTuBaYL4n0bTok1Ef1qLG6FI0 BT2PHhcFVCeG
YI3D+I8w3+tRA5ke7eAaIk1Ahy1ABQWotQLkz63K+FkzxyqlYy4rGT2qeGRR YUF+3vDcnGFD
s0NZQzIzgulpgVS/7EtJ9nrcLqfDnmSzWsySyWjQ67QatagSeI5glF0emFAr h4O1YT4YuPzy
oTQfqIOCukEFtWEZiiZcihOWaxmafCmmApgLf4KpxDCVAUwsySWoZGi2XB6Q w8fKAnIPnjOt
CuDbywLVcriPwZUM3spgA8B+Pzwglzsby+QwrpXLwxNWNm4qry2D5vbqtOMD 4xu0Q7PRXq0O
QB1AYUegZS92jMEMII7yUXsJUhtgUGF3oKw87AqU0RGEufTyuvrw1GlV5WUe v796aHYYj18Q
mB9GgXFhU4ihoPGsm7BqfFhk3chNdDboNnlvdu+mzT0Sml8b0tcH6uvmVoW5 umrahzkE/ZaF
Hdeddl7MQuOW8VUbBtd6uE3lziaZZjdt2iCHd0yrGlzrp3F1NbQBz5L0CbWb JkDXm4GIFTNk
6I2sr64K4/XQpUxnQmcVm19DoJyW1C6Ww5rAuEDjpsW1sDTuTWE0fbW/y+1W DkZPIXe5vGlm
VcAfLvUEquvKvHttaNP01ftciuy6tGZo9l7JHCPsXqMpDugNg4GGgToGMXQK VUwfoCymIwpc
AQwRlhfIMJKqAMxpJI0aRqJNC0YCGnyqMTwVrocVaQprxtdukkbRcvp8WEiX AvKmfyLggEDf
3y8tqYuXqNKlfyIKUj4ZYDWoT8DhUCiclUVZRBwPawpjHMPyhUOzV/aQQKBF kiEB8qGpQNu6
6lE5QH6/ny7wbT0Kmg+ZcOe0qlheRvM9XUjJCVWHSS2t6U3UJM2iNZ2JmoHH awPAyd1MRU4K
q4MDfybJbi1vHBXG9v9Q3RCrr5gRqJg2p0ou31Qbp23FzEtysfqRA3VxKGwd X8V5SBwiHo7V
AlPOHUCmmSp9mE+HPxVj6voeUQ1cyUqwPCEs1V4ei6u1fv//8qGe6Bn6FEsu PhYfZnhU6NL8
6EvylwxPv4mDAcNRWTFzzqZN2kvqgNViHV4RT4Dj0cwqvzw+jGbBzkyHv55o 70gaqj1hBUg2
niIA/8WK4tlLED1xuBo+lDuHZk8AQbdp04SAPGFT7aa6nmjn/IAsBTYdJC+S Fze1lNcmGKcn
eug2T3jC5mqgVSMeBZuCoHF7A3jjtL0K3jhjTtVBCeynjTOruggm42vHVe9N g7qqgzJCCisl
tJQW0oxMM6gCwyS7iJrhew4qCHWyWp4VsPyCHoxYmTpRhtGCHhIrkxJlBMr4 WJnCyuiHypjx
M6sGcw/bktVDgRsJZgq2gEBjB2vSb/ab0yHCcOj+KHO9PyoCuoBkvhfRtqOf Cx8Ib4NG7UFH
laluE7ZJNpvH4fHwvMTbdA6dh9/lOGB82cg5HE4PkZMV8xTrFIfirhKqNFdJ s8zzrHMc85yz
3Vd5bnPcRyRXCsdZUnSapKAsYrEn+kW3JJFZAHzdbTAw4Ey3Xs+Ar7p1OhUF zkIVA84rfr0e
IHdnMk42BWUgiIriIBUtRi7vgrnO0GTpbChUU9k3Wao5F2IfyKDSvtK+4bm4 phXV1NS0WiXk
z+MtSTbCB1LTSJGE8vOQuYAEA6loAd6IR7yOJzzdHTlw+Hjk0M5XcfKf3see 1V/e+YfIn8hR
vAz/+sXI4389Gdmx/1U857eR7yLHcQH27MO6X0Y+BZrdEv2C94ElKKFk3Kk8 gAW9KU0oFMoF
odQX9hGfL9Wb7x3nbfFt9alGWUvsJe5J9knuGnWNocpUY7/GvVi91NBoWm5f 7u71/UX/nuM9
18fWvzv+7vok+ZQv6nPJQo4px5YrlJoUYZJpqrBQeC/5n/x5SS8lGXkVQR6v SsTaJK9R50w7
ocOSTtHV6jp1vE+hBNbpTSaInQzuiZ5jxNZRqlNC6iixTSYGnOqmRKUlSg6l v64Dm/MRT/ER
TwtQPpdOSC/GW/EOHMZnMO/DpWBpcbgnGmHLCsCPSrLRCJCedogl+jS26HS0 hHYIGN8DqiqG
aqddYyftF9toF9iVMrEovqSJT01rW0ml1A8lp6X+i4VsieHPXGy2FA/PRTWw 1m2o1R8w55tH
5OelkCQJBVIzOJvDnp83orAAllqFhz7Z3bZ3/p5WJfLtC88vIQWz7lz5zOMr Vj4jHOr/55Yp
W462R76JvPtrvO3wrNuOvX7i5WOIRB+JTMOjYHU5ZEHvKOW8kC6M5vPBkBMc akEQeZ7wghVh
g45wNj1vFnQidyNGOpXoNZu22rDN4XDr9YZ0rXarDvt0pbopOk5HObuIkkkn sXVhZNLpKZl0
KWxd9JRGOjVbET1bDZfVtts/caozFJp89iIVKGVKJkvlDWWftaLSSkoRIIel GENczEJ+/gZJ
XTI8d/xqxaiWTEG1pPVgjVH0IBTCodA6XGMtzE/CRYxKQDubqAqk3tIdaUwd 4Ssa0Z0/9p4r
+C/ffPOH6+8zXnEXP/fCjiOV9VRSVADXp/BjQF9OxjMUhw95k8gsrkao0czS NXBLhGZNg06d
1BM9zTazGQBlOoWSvTTOsPxFOG875+aHW0a5hnvHWirdY73TLHNd0711lmXu Ou8q1aqkc+Sc
U0J2bDI4HFPttfYWO2f3mrZKOyQiSbzHqxXRIfIUwtHeBPf1KhIlnIQxvtvq 5XUOxdAT/SuT
NIaYyFFR4CvG6gaKr8nIKggbsMHtg9y+9GABTZWxKYGCXB/22fOlNFFJyyrw iaXiFJETZbpG
opNJLC8TYEYmtLxMTtmZ3HKlFAzm4ZpQZf/pyVJrKHSuleaZcOqvAXYu7bMU 59SU9LeWsOWi
bIxrENSEcGsbdqhgIZA5Jqpsot9OVwj7gxmUk7lrDmV/ffDLyDfY9td3sBH/ +IW2a/2Czf3v
kWn6kbNvXbMLz3Y82o19sDn1ODPyYeQHSd5zqBHffcv4xidAjE6NfsH1weq5 8Zy9hB4dSoFx
rQmbdFhBU8GS4hBv8epEJ9AQG5NENWVWke1pUc8mLzFC5NAJHXv7ZSZupSM1 eTQMz/UoEzV6
7POOt453zLDOcNRaax0PkAe4+w2PSY+59WqDS7uYNHGLhRX6FkOn4Qn9fs0B 7X693q6/Rf8J
4Yyp80zNprUmzoR7yFPK6lxEB1ULw9qKdqBT6AzSIJNJhy6O0QtDTzOqKfmN qR6YX5ou5MMY
AR8oTOwoTOZcziSNm0maK7xJacdFTBeWxBdRS5FEC1vK4Z6CI86QdC4ma1ga qmmLH7AHKc+N
rO5rOxvqa2Nzh4U0F+dINafhjwqjVpBG1YklLLCAQLI7xCBduSQbXUeuZG/y N795L/Jd25e3
7v6rb49r7ZyNTz128+I78HrHs8dxMtY+g8m6PQ97lix96a13X/wF9c2mRb8l WcJ9yIH+fBBp
gVsDwQIN41YAOl0wW71BizlklzQhk1Zl93I6k5SKUrHBkq7HUVFdrimvFVvE TnGryCNRFneI
YbFXPCGq2HEcP5fpecCAb7vZolOBHT+pv0+c1OeZCKdnt6KjIlxk5zE73dkO OEQWIycesXdh
nIIJaXX2tNRX0l8inT5bQqkGoBm4HkSU9Bpl/VAo3QEECwYLzYHCfHOROT8p YLZRvieSe1LJ
/KXZN9+8b/9+aygz5eHt0piGR8iCzVhcGrl9c/8vK7PdlEb3IqQy0bOYnI7x 9UGkjp5TdHTg
aqPBTGYRJgcAEABQMimkt9BqwaTnNAgTtUZnRGoN0epUlCRxEQ2TPsCktIR6 op8xYiFKEUos
AH5kNEJ0PxxjESot7e2VTpzoNVscxaEQTA9KkWevim02HxUkqlkqFnMs5lks sFgN1FcCFCLs
1OQYfYmRxho9jbX6OMW/ZxSHB75XfBQKClgvay0FJhYJeg5how6p1Zho6cRp awxgjTxHZsOp
JpHZigHpBylWiWYRpnM5mwOSDJWWlJaUxCZTE5sN+yAWe5S1iJjUNuJR8yth E78KpNRfob/C
xA3h0w3Zxiruan6lYZVxg0GtI4K62DDCOIVUcGWioq40jDNq7yX3cdvEbeqd 3JOiykJMRmOu
QGyCQNQgc3IFNYBq/XTTdKxgQtT0PkJnMBiNEl2nWkunhVgOkZ3IgId3CbK6 Bw9XtHqNVlb0
a3VYdwgmacQ6qCE9WKdoTBjJphYJSz1k9rOyUCt0CpzQQ3buM4+udoZc0tma szUlTuDSPrdL
6gPYPZA5XYOcpUAGadDXLfX1bRCGhTbccGTDMCdNYP9XhHUzKsIpICpeQPro BeDBd0GVeHfk
yJHVuCKsh7pMJkYM0e/3GrW0FMwwmn37gL/YmO0vhrPp7QNFxca8IgbuHwql Q4tjJK9ua61B
raDvVFfngxpvd4wown5zwIwD2HwvTsNX59pdhXgeFp6LzN4TqRIOXfj2zsun PsD9eH4C//qF
Qv7UBRnO7yvh/PbCCZCJishQJVtj0GS5DO6sIYasLFiepCLPqKwrsmoMNVmL DU1ZtbmbDLcM
ud/+gHuXISmT7nPKLRkAKC4KPeF6KvOA67nMI67jmX9M+iBTXWbHKVSTNFN+ sjCRKjCWLQRF
U5lFIZ/D5wxlZxUU88XZV/CXZ89WV4cWqptCK/Ub9K/pfzD8EDIXFRgxL+Wk FTjy/DbnvCHN
Q8gQb46x1LjFuN0YNQrbjXuM3xg5I9NxjfRcp/vSSDtOohLKyFQno4rKKKPR yzngODngvNvm
9YqIIrkZt5dnaPNAVg6pk+qQim3jdH9aT/TvrDEKKDpamsZU4TSq0dCzL42K Sjp3AP6q6Gh3
aayjNCoNaMNpPeRqxZihoKAUlIO5wT1BoRjENROrwZ7ouwcYMJyWKQaqcBT3 FpMdxbjYQcc2
lrboSHem5qQdVh1XEZ+qVEVURjpTFTuIVUwLUTGtUcV2r8pIp6uSaOeq4SMH RC8cYGf7QlJN
awhKavoG1MeS/tCnn1JBfDoEGslp0EFyEvitkKE6CaY7nh5oIaaVQIJa0+mp FiwsGDGiiH0L
C5hKImaMIXDM2R32JDjjHIEgpxKNJHbcARJXUn9w8Z7nJ7ZfXrjkvUU4v3zj 2tXJYefyE7du
fGqqpHGkPu91zD/SPDdvWVPjI8Hkm2ZNeHr95HWTbUaDOy1du3zoZdWtztbb KpS6K4etOnNh
/WUj8QeZXimzMufy2qunXHYtyP4NYOB+BhxtxzcoVoFTWclOqUf6hPvceoY7 Z1Xx9Lgq0RkK
Vkv4XumE85Qz6uRltc1os1u8gohVdoPWYNQb05wKXXinwtTxTHYG2JiyTlnB zE4Dxgq6VIZB
F0vHlHYbU9p7oj9QhgFIG7eszilsA+iU/BEFUR2GP91kJ111d8GIgrDzjJO0 OHc4w85eJ+/k
SH6SPR0jaqqZzexsOZ84bc4rDjqOuE2mpb0jnoltWmemvSHCWDpmr9EuLNDn GeqUktEJUJ14
NNkhnatpvWhewSF8toTxxuBS+PSBcKNSHyyKYkx1U7Ag7CqzRqvWilpOJQXN KqMHm7QWD2aW
RNY6am0D8+TDuT0izgkglgpiao95wyMrPqh9eKqk7c5acnn7k3zwnj3lLZV5 N/S3k1uWLxt7
1xv9z1O7YlxkGvcVrGIKysLNSq1OJ9iydem2Sbpym0qT7ErO1gVt2YFi3Qjb lboJttlila5R
d177zyTjsEB2xpjAmIxJGVuzd2SLI/wjhpRmT9BN8JcPmemfOaRJXOBfMKQ2 uzP7vYwv/F8H
vskwO+yqpB6ytzvTaxWZpinJKJfpmZ2oF8gFQoLcoOQJXq9JW57q1WvtSfnp +dp0p/OEA0sO
xVHr6HTw2aBdkFnZzNp2WOhSsf1rpjvVoaIL5rCzOpBPMUahWCqajx3DDmoK X0lXzNFhwuko
1Zd22HTcdNIUNfE+U6lpCijCzO4wuenCm1JpayYvbcnEBJyJyTGTK5Td4S8Y bCHWtFbCzr9o
NTOLUeo/fY6qX6epFXKapiVxR0mrw2F3xLZrBmxxUsgUVweoYja25a22i6b0 wj26vPEdN2x0
GvHK8Ptnlr95+/PXPdHw/o7ffnXfEzes2bn7ulU7q9zT0vPq5xSFb8MlH9yL 8eZ7O39c/P3x
VU9zWW/2Hn7jpZdfQrFdqwrCegfwK/QAPJvQZ2IA6Ld/Viph06bzp/nTmo8c n8rCO8I5mTjU
ckDj9MgajgukeFVJlBywhwNwTGtPpOOt6TvSSTrY3sb0rWZs5umymJ10ScxM oNNlMdsoOc30
EHNQ8poJJamZmd5mJsrNdPNR2poTGpG5B9coemf6Vg/2sOY8A815WHMeqlWa aXMetjU9zKiA
0khMKHj0tGFP4ozw0PbsiOQH0vEJhKl9Q3yoFE0BC4w+w5wpiKmgiHkJEJP3 yB7f9j8yTZwd
Zja2/7Vs/7ODALnS0nvwqn0/9RrEPCr9pwc5WQYdCpDpn8z8CWDZlJTA/i+p lPqkPrODORXi
gsCot1mDNr3Zgy2GpLgAWBc3Xtn+ZxYPjQaLAAoBQIXBw3lPLF55j+/Gow89 tS8wd0zLr7qr
6ietG8UH7548b37VoT0H+jPIr5fOG3X3Y/33kK5Vq6bef2f/Xyi/LIt+LhwU 3kLp2Kq4PTZP
EqnNwNeordjCpaUhv8VB0lEKYb4AmZl7WOVIMXL+FJUG42BGeprMcTKRM2oJ R+hZTheRUGuH
0hiA95iRQyhFPUzrbuvMwBnJQVmLtexk1bqCC66O2fc1lX2Vca9jDfPE0CM0 YQ9SyRo7RQfR
rYwPeLxur8sLKn1QSk8K+oLqdD4YSHcakv3IbrL6AdlmlUXIpQrpfuzVOfzY ZoYoReP3ozQO
IqZzA8Gp+jmwalmM/Lgw3axiPk7YvGn5eTyYncMIpbkIlqeFp5vbzE0iy7ZE Tuz4c2R79z48
9f3tGN8V3OOff6B5/YvX+kduwOTOG8+MIaXP4P5Tbe0H8TV/fhe3dy/q+VVu S2fltJunbNx+
JPJ9Z10RNsN6rAeh/TLsXzN6TRmdY8USjwN8AT+en8Ev5Dt4lcas1qg1BqtZ Y0CcGuuot1KF
tJrMrWqsTpWt2EpSzezA61Wknx5WMW9hzNRSzIMOPxXbBZfwP3Mmxg0Y5glA ky0Tjwy2QOGA
KwG2rznbdhrMM3quFZuLY64yJL22wchU95o2XJPgYDDZqWID/Lr+kTFNpVdf M2bcuNHX2FL4
4MOtl496MmNiaW1b/9v01CoDbToDqGBALrzkQJKT9m9N2MMmKmLaKeRiFRZR 69JPVF2unq2q
Vi9SNanVBdIoyyh7obNcqrBU2Mudc4W5mulSjaXGPt25TFimqZeWWZbZ653X 4iSNSjBczc0U
Zmqv1i/lGoQG7VK91uHlRTOIQFuah51DHqa8UJ967BwSmf837rRJOH8ZEPe0 n2Fe4Lg3ngG9
ijUtvSBXxEiURFnkxOEnQebR8iuorgqwMQ3pjdT8tTDxxPxCyMsWhvlT4lKI yVNkZ+uiQJNU
vBE03E2dZKCKXNQ3pNZQzbmaiwWhAS8+tXfAQFI0M4QZmvnCfA0Pxg/bBVap CNYJJbEDCg0+
oMoeu/X372P79X+77WSk72DXhlu69q3f0EWsOOOOlZGP+o/97Rc4BRveeP2N N3//+lHguZui
X3Cn6DteeMpB5KaewSRHAZGt9gITVRzzLbaCkBWnqa12PbbadcDCZjAaUL49 3emgip2baY0O
pi86LOzYHzAdHIxpHQOaosMWVwC+jx0KDnYoOKimaKB0ijpwrwM7JrspuZOo kug+4yYt7h3u
sDvq5t36dM3AdtFgpJE1JzSnNLwmsV00A9tFw3qm9jI7S8/FdomGaYkawk7Y yS56PgwyFmAl
/kUdhH3D/O0lsf3CZJmbl4wGk4GoRLVKLahBJeT1HmRQm2Ou5aysdSCP4Fl/ IXPqZASZe9nB
/JjM1cyVrnnnmkenSLpunXn5tGl3jO5+sPvyZVMK28ld/ftuHz5x2owtG0nx hfeAXTZEmng/
7C8LSsHzlTv00lDpMqlC4kvlsEx88hB9IDkvKS95XHKLvFVWj3KM8lzpuNJT rb5aP9cx17NY
vUTfJC1zLPH0ym/ZPnB+4H4r5bTtdMopOSrbA3xICiUV8qOkCfyV0hzpU93f kiOSzmzk7F4m
rOxeow4ZXWkntFjSKtpabaeWl9kGk9lm0/ZEP6N+MICc8fx5dogM9rjErlm0 VBIE2CnSga35
JN+SjtDP36gkLlKkQRcp0iUXKed+epHCDGw4kNlFim9ikRNfcpOSuEj56TUK u0cxFw++RbEm
jnB7ko3Q1cswc4P21obHRt3VuPHE4hUnr5+zZZj5iZWrnn6yo31vpEl4YdO0 aZuj9z4auXDb
pFH9F7jHjh15/Z3Xj/6Jntw7EeLXC4eQBt2uhFRCilq9RcSiiDgezmuC1OKD cC7rCHHreI2M
6WWfHJf95xJutnMxNxs1d3QJbYiJ/0h33HF1RtEyqVOjHT138EUSnM/0ouRc TSWV/XA0M9c7
HNnDc/PN/iQ/Czu5D378lIT7pwqHdkdG7e5fCJy3EYZewu5/RHRMuUYzgq7B FM1WzQ5NWNOr
Oak5oxGRxqdp0XRqtseLTmmiGq0PdiYWecJpVPRGSCWoeK1KTBcQv53fwYf5 Xv4Ur+rlz/AE
8TJ/AnI8n9jA/ICxx7MNzDNjj7cxR2HMz8GACJPfPGUBpvjxk9WXbGa25v0l dMalfQN3QlTd
b2sN0XsfDrbhxu7ubv5vx49fSOKDsNmoLISoiM35kwMCm7BAb0eKRhawtKAw luYOj6Wp6SxV
0kFimgSfsF04KfBTIDojcD6hRegUogIPp7qWcLGDnrbEDvyk/MKC7Qj3ojNA 6Z879c/HNeDB
Ji+jAlLHD/4YCQCIJlggTgs0mb+UFpQYzN4FcjCLpy1WDKe9+aZu4dD5CfQk fxghYTfM3YlS
8Y+K36IzYssI7xzfQvUyH6+RmHXCYpHFadSjQwdnoHucAvoEoEsAlp7ox/ss 7gJIz+xLzSgw
03xyRoEUT03xFOr/vC85GKsHfCme0nrlCgDSjVd6r5Rn6OZ6l3nbNKuMq03r tRtN9xh2mXpM
Xxg/N0lGvV42m2xms8ls0mssHuJ327Uqi1ky6AWnRmN3uF0pDkp45rVzOJA/ le09J9gyRnVK
0PigiiotzMmU2G0q6rFLZb4mFfMv1chpLWmdaVxaqvN/u01V8W36XWKNvk9s 08Donf+yTeMq
teu0E6QTc7LGN2wI6kqKcyzUFHEUbzAOCwk3SEdiVweDPlQzqKH6glatmIpN 0iizZRQUVeNW
5mU1Rj9U3K5ic6qr2ALBqHiLpVQbBB+EpLiTNUR9q0z+qUQwih3WADeMZAQD ATMUj2By0P8w
2XTkjeuOvlWZOWtS9OyLs5ZfNdRf8RF+eP22yfc8GskVDk15dfWD7yanp01e EWnFw2/ePFIn
9q/g8otWT2y8he6zXJCIh4DXRHSrYhBICs9RMagS4CQn7ftkHvM9GD+rkjHJ 4TAH8H7MCE5P
ER0jujpO8W8ZowHwcYL0PyZIndgg0KL6wH0XNwRIv7NUAp6u+Uxirh5K5OG5 IAkLqSwk1kgy
vyniEQy7d5//H7ozHoKdMQdGa0LJ6FMlR/bh8WpvMuUfs5RiQmpHUNbg2FsH GsYSGi0dnYYd
ihrmlGVqh9uXLP3/Mk5iPv/KMSlUsF+cBLBEDK6hzNJfEpsFqCcjOE9MMeHV vMrldDuJSqfV
aw1aTpVkt9mtdk7l4cCushghcqq9fmzXmv2IWVZZ8FlH7QB/HnWJ0BdHjCSQ 7qeuEbr2wAj+
h/APT8+5sbqjffJ1dx5bH9mLi+98fHh55T1LJ++OvCEcSkqeND9y/MiTkciu urzdI4aXf/nE
Z99lpVDrJvo5KQYLlkMzDiIu+mGXrRjMzQ8V2VZ8D4cJt53bwxFuJcI2+gsM DHha7gtEvsA9
eNd+4Jh91zmp6XcWjHJ2K0NvH2oG9kESzsd419ZIlUv4+3kbXbdZ0c95s9DL 3k+ZFb/t1bpT
eMGWYjA4NIkNr2HefLZWZsQ86lRpp2fsJVdbx+JKeeIq65KWYlqOht6Qxb03 X8dEDTTJxCVi
JjSSmDwYfFsWa7NbJbskL4jJLtAEfhs9hewQLBBMIIPm86oNZKNuo+k1o6AR dU5Sbp2UdKVr
vGemdW7SXNd0zxJxiW6BdWnSEletZzW5VrVSd51pg+pecZv0mvM98q7qXd37 JvfAcNs1ih8M
Gao/Sxqi2eozt7MzyQilMqIvWm1NeeW2mI3Sx3yml7xVhEbSD6ZXOtVWid3w Ap9IVFvKCFol
qiyZJVCWRNWsJW/tWNnVMW7xWw+/vfrOg7vWrNm168Y1V9aQtzCPL3tm3r5I 9L1IJPLS7nuf
xb+O3PPNGdyIF3/ddAtdu0pYuyRYu2SUhafE185nwj48D5RET2aKYsAGg01I 8QipKTaDNgWj
dInuNLaOUopDYl5Ipj062Do64kQ/9vYx6fcJV0UNvbun1/ZDl7hwmagklbnK 5DmWmfISrl6s
Vy+21Msd6hXe9epbvO+q37abRZm9w0HfGaJAgJ4QzJDxy3F78lR3hhyQ/bTC TEc51QDGhs2D
35pHxRdpVDSJMQNXj1QsaH96u8TWQ8JIArEAszjzLOUVaWu29hAeCXp/sWIv dcxzNDvWOngH
sycd7IULRw9J2xeKLRUVA/S2nq7W2dh69dewm40aunB0yZjzpAbVVGORvUsh qlQi1XUtcSPS
zExKO2YXz3GFl7uwz5l9xZLZY2fNJ2OfX9Tdf+2Jmz+KnP71rV/s/qC/aMod k9see+T6657i
ZxgX51bmjvn6rwtqI9/9cVPfjbgCr8G7frfzxR8/qHmquuehe/fsAQKMxT1k MVkGOztbcbWQ
Fo5U4kpCcAARt9ACCC6+5XZ6LJ6ukT5DOZUwdNRKX9TxJ40lQ3DP/v309KD7 2i88AZSZnbjr
xvQqiRkMXqM2JSnJa+khz4FtwvMpXoMRTHknVR4pTzCAYjrpns45NuC26j8i HQlRXhhiiTmX
WVzhXp28KXmb9UnrS/p39e971Bqr05jl5jS5Qq7uEGxQDlZasmqTLFbrUaPJ ZrTajCZDD3lM
sdKBKMYdRmI0mpQkHB/UsyYev0XfcOzBTkWmwzPPk5qltdIWiZc6xXYnYwYn Rk7JSWCwZ5+l
w3BulS3P40JkwncjAx7ZZdyPKW8gmLbu4rb19eC79iZ27lnqAY8zRE0Jiju9 KUOYIUh90ukN
6pgegZhhy3iE3XRVW4sGsYCYYYVjkYt5G+g7UsFZLyTdt/QX3bs3X7U5c9cd 5C/9z065+c5e
rO64/eyr/bhT2nTbkUfu75pSaif/eCaycm7k3Juv3Nl1iu5qN0hxCU5SLUwi qIywVOkb9ffr
d+lf0wuTuEmGX/GcBRM10qs4UdDqOBHpYRGOcryN43jOgIjewIvcc+Q5pEYE 71C0iOcBBR3V
8j1k4bOCoFWSfQVaugvpAauNieO4PUrJqO3BRYpBVFIDBWKnv1DcaiJU8ukM tgJEJCIz1+ip
hEf09AH6DNlv7MGbGVn/Tl9qonuNaW0l0mcS06mlsyXnShIOtQ3DQjzQ1GQy AUnjl9sfdlnY
bbaiyy/mUocWc3xyMnNgVsN2pPqaTa/oivWdU4v1SrBYn+qFNH7pXU3VEpzP 3gjhzJhs67+Z
/PqXL7/cHSnE8x7nDvx45eORhwlP7u5fgki0HzSVaqZXGfGiA9hokuI+3jgQ 8+UzH2/1xXcq
YhfUOVKutEjdqKmVNnJbpdeEl1W90hlJpxaq8WwyVWrUhaX/0f+P4X+MGl7P G3gjp9NqBLDS
DEa1ShT1AKtVehFOeaqymNgBKot6G1QRjqNlSbSMk3m9DZ7SpAiCOkXFqXpI i6JBav2XCuhT
5BDWIYx1ikUvowaRmz6VP86f5LmtMY1Q0U3V94on9dxWPdbTvGQSj4tkrdgp EvGXpnf/BGt0
tqbVBQH+nH2xlxf6kLO0xN1XerpE6oM/qjWEYIXoSws0jVmHsHDSkSPGI0c2 CLEUVu/iywzd
vIlTi4eiZ2DHfT+Svc3Q1hrXvQOgdwQ4P2f1c8EMlciR/DdJ1QdP9z/w8F/w P+6bkOrNpxYW
fj5SRubgbQevvf02uhMmRL/gTsJKmaluojymJbwh3VBgKDMIhbZC71Vkpna6 bYZ3EakXGjQL
bLXeXt/bwjvWD1yfWj+1feP4m+tT9o6s3ecLuemLtRVu+patOIykGYbZR5FC QwUpN0ywXeG9
SjvbsMjwqepz+3l81ijhJM6ok0zI49WJZqRN8nI6Zz6cnWZTuiSdMGPJrJhr zZ1m3sf8PDGl
1swu98wDl3tmdrlnZuqtmb6xw3x7ZiO7P0pc7tGbI2UcuzrqsKQdhnU6KUZF PvE+Ycqg9wlT
Yq/XMdcsE7oiu9ej7xNOHfw+YWtl309u9PpgAzL/XAkNF9+IpX7TuPetMP4S Gti6eJAnhxvZ
cGTtOysWv31T7bacff3yMytWPr7z+lUP3/LQ5guPbsfcpmljifH8BGJ54+jv Xn7vjSP03CmF
NdvLj0G5nEO5nk+1pY7SXKkpS5ud2pC6RnOH5ua0J6xPZ7/IGTQOt9ORW5H9 rkPwwLYjUh7W
Oueq52rmaufq5urnGharF2sWaxfrFusXG7qD3RmmjGBaRtqQEWlztNW6+mB9 ZkegAwzNX2of
1N+VeU/23bmPaXfpH814LHNf8PdBe2bijjA1AQQSQFoCyIyZ4HEcCgQSQFoC SKa6tyWleI46
I12v5d1yMInXDUt20wvhVFc2W39XqWuKa55rj+u4S2Vy+VzNrpMu3ufa4iKu F2CDJwErs/dQ
FRtFl+hrShI+AYY1ljC7i9pnsxfE3k81mgswHjY3eWkySfYmiXzsNRLm8vks 4db5TLFSPZr3
DtP53Nid5lKszoI8+ngOZTyXMxZTfnExHd0l0yddMn3KxVRsF1ONXD3k6i4x LQse3e8tPpGF
s2gv9ImshNrPAPoEAF8xSZ/lZl35M7IKavN680hpXmceyaPv1KYhZ+wmkqny cozKZBYD6ABk
pnrSQchpJuasNLHhmWR2ZU39ATLt08TeZItfXqeeRJheeBLkGh5/cRZYPM7s fRAkSNomx19f
CYVaQ5WDbivZ+5eQlva1stdXqFfntNTPkoHbN0fMYa1kDE0JCLbsoFmySFaJ U6UaZA/SZIoe
LAyFKMUGWb8x4EGpAYNePUTrwZkZGq0qxHuQT0qm15yxOzcWsVfgskLr1q1D gzYj9azVDCgO
GcGMYaSwgFqN7IWIxCug1Kh0pJCYxhks7TLdev2aVYXpv3z5viljR2bdOeOG F+aYw/r2pjWL
7fYcz82H75nd9PINx/+CL/MuaWsouyzgTM+7Yt3kiaszfaHLr1/knD53elHA m2zVpuWPXTN3
zvarnqH71Apc2Ql2pgMblBSbBptcOa5cFyicrgf0Dxp2GdRuQ6Yh7Op18S66 3pluX0Gy2sDp
TV4tTiIhm5XnVEi73YZtUavCO9J5xJG7cMyBNzzuwAt5fQVbEXYpjCMVA/XV 2ZhVn8ksyFTm
vcuOW/Xfxt1Btrg76KvE7d1nzG6kdj/T+dGjTtfz+BDyo3NYi+B8uujDo6oH qBxnYQXgXOur
oW6LEmr298HhxVbZJplVGlGlVhGVpLF4kFll8mB6H7FuHQ6BRGzLp2+XFhYU XbzhS0qiekXX
9u1W900rJ831jMybXnb8OHf/5tYlBROusvxaO6F2/uYfFwJN60BzswtPIgNq UYxHDJiHP6Lm
NaCVUU07l2Beoze0cxyh+usUMo80gzLlNqnbNX9DU8Bqm0e4Ukia8Vow/lzG uKbKeL6k8mzf
ZOlca4heuMfcMTCn2HULiHKq/asQpxIDIyyWojpu/+ZIX8UI00HuF/9zK39+ 9+a7I5bIhZ73
d+Ov8CsP0vU/BNEGdAysjHTFSUqQlpTMQ81oLdqD+B1Qv4N/+F6mJFPPCZgY +YX5SYeOHTtG
nz0M0TrmAX5jP/XNE+boHXlZzOGbXxBLh+bG0swhsTQQcwTvS06JpU53zDGc ZZAKZGGrsEfg
OBlUoy1oBwojPoe9130SnUGCRYbCrYgTYnooZRdn3Dn094Rz6OuEc+icEnsV gr0rix7h360e
5BACPbKrE5Snmmrq+h5wDMacvtTVe/hF5urF0DEiF8C21qI9iswpBnPBEn4t 2ULuU/PP8FiD
VALhNALWE3xUy5hdS00SFPfAnUq4qONXrMjLxmSMj/FMTA4m/B1MYLr1gmIw xUhCvQy5ApYF
RSCCS3cIl+D1KGbytYYuuY2jHlEYPPV5Jn4g4A+YwWgtHDGiKJ9c6B771sx7 Ps7p4K8fs8b3
m4lH5yV8Pi6YG32L6jcxT82zOp+TqjjOmL9NRU3A2CnppMPNpAN1mplMNrNR m53m7JAuM8Vk
9BmnGDmj0YamwiHAXleEPTYLU6sNTHiBmY5HQjV5zMzOY5okiGLqaZCon+GD 31N3EfnJIC7a
ocAf1BA1sxvkf9PrpX39pKucwR0pBaPck+xK4Gr7VYGF3FL7MveiwHXuG1I2 u29Lud++y/28
+yv7Z/I52XqZ/SH7bjs3aki9imRQGzYANqzTL6vkzJQpxnnUYPXSLvFbU2NO i246CN8hXIx0
eKRivtRE3ZpNPRnd1JFhHnAjgRpJzFtDr1w0RmOOpL7BdmjCMcF+NVAdtzrH wLGRoYq9hYXg
7LCYmWspiAsu/oigZbd9Td2MG6aOwCOeW3bgRyy+vKXv+uv+8cgz75HXH+9Y 1bVrzQ0P4xnS
dcsnrf1zi945ewlW//kklu6PfBL5NvJ5ZN9vDnMFDxw48uDmPXvYz+LpzwTJ ltfOv/zgPFPJ
P9UeNfu1/COfZGQlfjlPfw2lCgpvA6iJ/68Y9pw4JjIZjb/4A/uf/BuVoIr+ cq8YLeDb0S34
legjkFbwCE0lxSiN/v8D1VPoXii7EsIGCOMgvwHwl4FWtR7yZRBuYnWfoJ34 FbQRwk3CK+hh
yOdC+hBtA+pnQaiEZ8bGYbcwO9oP6QToqxRwrADXQXoIwmGAT6JZbHxJaA9+ iGRxGu4TfgW/
QqUV29WzNZO1C3XDdHv1dxnqjOOND5mcpm3SG+aA+RVz1PKB9VXr32yvJq2y VzoynBdcj7su
uF3u29w/eK1s9hloJL3Ror++RBLKQbNhfI18MhJY6ShC/9sOx+oXs5hjVNOy HMeeMqKOOMyh
a9Av4jAPOKfiMP2fKV/FYRVYuiQOi+gQluKwGuXio3FYgzbh83HYQJ4iNw+s U6EwLA5jJAgL
4jBBotAYhzmUIzTHYR5wHorDAtILj8ZhFeDvicMiqhEOxGE1cqqscViDylWh OGzAs1T0l0aY
56Avvfh7BlMKSeKbDFax8o8YLLLyPgarGdzPYA2lodoQh4GG6mvjMNBQvS4O Aw3VW+Iw0FDd
F4eBhurv4jDQUGOKw0BDTXIcBhpq/hSHgYZaMQ4DDbV3MlhLx2kYzWAdHZth IoP1rPwqBhsZ
vIDBEh2boZnBVoAthhsYbGM4sXEmsXYeYLCdlT/NYBd79lkGexhOjG7JDOcd BvsYHKNbGsOP
zTeLwRcYPJTCRkoZrGbjNzoYzPoyBiisj5XnMJjOBRlHo11IRnkoF74jAJqJ GlEDpJWgWCyH
0IFWoxZWMh5ybQDTuA7KmxjGMKgZi5bCV0bToWwRPN+B2lmuAdIGwF4JcT1g jgW4CZ5dyuoW
oRUA1UHZT/saNQhT/gnuKNh5tM32eP8yKoSWc9FwgDKhpSa0AGqbob4ZLYQW hwxq6989eRGj
EuY/uO8mNpM6CB1s1vXQwjI2jiVQRnv4P6cYbXU5azH23CzINUGO0khGMwCq Y7lYz8uhNIe1
ILO2G9kcZJhlM9BkORtXE8Me9n88kn/FmzkAlTHMa9lYF0F+Csx1IaMurR3K 1qUZzY/PZTKr
aYQSukrtKBvKprKe2lhNE6PhDIhXsBnF1kEG2heDXM1D1Ww2MqPtakhXMM6J 0Si2BgvZWDtY
WTPE9ay8hfW3eoBSMpS0sTF1xGm0nNEylq9jLbWw3pcxmieoPp+1kViRpfF5 Lh8YReyJxDja
BuG2MG6rhxEvYH3E6HEtGzelyM/PIZanuAugtxWMIvVsL/2UEvSJpQzKBPwh kFIOnB8f98+3
vfz/Yu4XW68fWPs2xl+JtUxwz8/NYDBvXzqu0YPWiM4kNpcO1l+CL2n7sbnW Q8m1bObNbNf9
J06ou2TVG+I75af7hVK1A/BWsCfpaFcOcHOsHYq5FDD+Ew8N2yXn5eaOkGc2 NsiVzcubO1a3
NMjjm9tamtvqOpqalw+Txy5dKk9vWtTY0S5Pb2hvaFvZUD9sbFtT3dLpDYtW LK1rSzw1ihXK
8dJRsxva2uF5uXBY7nA5s7JpQVtze/PCjiEMa3AlK6icGXu6qV2ukzva6uob ltW1LZGbF/7b
gclNy+UOqJu1vKmjoV6e0VHX0QAPL6/PaW6Tm6GmTV7QvGJ5R1tTQ/uwf9fI QNlMGpW11V3b
tHyRPGXhwqYFDfJQeXrzfOhlctOCxualde3Z8tQ6aG5BU508o27F8nqYgzy8 eGRedfMKeVnd
anlFewOMCGawsHl5h9zRLNc3tbcshQoYlNzS1gSFC6CmAdK6drmloW1ZUwcd +vzVbCJLoc/l
tAmooG20sdKWtub6FQs66GyvbYSBDOoB0qblC5auqIcFkRODaF6+dLWc2TRE blg2H9oehL38
P/bO0Ovp7Nsa2uksKXkudhCjdryt0WxGmU3QS0fDMkrLtibotb752uVLm+vq LyVCXWzqsBwD
69K8oqNlRYdc37CSkhlwGhuWtlxKoWEggJvZxq5jWwa2NDYAyy4Gpv2SifhE Xex4oduQbrd6
7n5uL/cCdxjCQe4Q98x/lYH/KgP/VQb+qwz8Vxn43ygDl0jdi3Ad45mfq/vo Eryl0M5gecwk
8r9pcyngrB6c51P44XwFP5G/DOLiS3pYDu3+u1YmQ7ySUTG21xtxGD/MIba2 VNa1xeVI3X9o
4SI84PNA0Qy0Df3M5yCayWXuCzp9J57nhqBTEAg3pCuU7DvIZXDJXaN9Sg8X 2GdJyjONHcpR
P2wOi2WImyHsgXAYAo/mcfRNOwnitRA6IeyBcBjCCQgqGEgKq5UhNEPYDuEU reGSOW+X7JPG
ZnAueJZa2ybOgb6BEOWoheyDOAfCFAjzIGyBsB2CiuHRkmYIayEchnCG1Sic o+uufBi7o+s2
luxbvDSPZeti2bk1LLvvqupYWjktlpZdEUMbFUMbXhArHjYulmZkx1JLel4n TbWGvN6xds4O
k6RmfAvEmBxBJoyRD+3gklAYAuFU8RKFs+xLC+ZtP8zxCHOEw7DOvmgvh7sM 5ryxWhIl3yAL
8pGvSV+shvTtM5rzto+9knyM9kA4DIEjH8P3I/IRWktOUZpDXAphO4TDEI5D +AaCipyC70n4
fkg+RCbyAcqBUAphHoTtEA5D+AaCSD6AWCJ/pX4iFlO4FAIhf4VYIu/DtN6H 2ETeA+g98h4M
7a2uouK8gwwI5cQBX3occHjigMWe10P+2PXDEOCoIKw0cNRzXCoag/K51K70 4b4eztlV0uTr
IZ/sk0O+HWNzydsoDIHASN6Gnt9GMoSpEGohtEBQAfQuQO+iTghbIeyAEIYA XAaxBEEmRyG8
AeFdlAtBgTAVgpqc6IJuesjxruA431g7+QN5BTmA4sfIqyx9g7zM0tfJ71n6 GqQpkB4lL3el
+NBYHdQjeEaCVII0B+oF8rt9aRZfdKyZHAba+SDOgVAKYQqEeRC2QFCRwyS1 q95ngUaeQ0fV
CDC70JcsfQI9okbKYp8SHA8MKNMoOOoygCDaLm8PEiW47T7I0ih4x10A0Sh4 82aAaBS8bh1A
NAouXQkQjYL1iwGiUXDOPIBoFJwyEyCIeshDz6Zl+IqmLMHyWBO5Fqh0LVDp WqDStYgn19Iv
+oGnY3ugKysLKHa/EhqS5es8hDufx53TcecjuLMBd96IO9fhzhLceQ3uDOFO L+5MwZ0K7nwO
jwRSdGKl+5JsseLEnUdx527c2Y47g7gzHXem4U4ZFyk9xN91RT5Lylmybyzd dJBeNgakj4n4
gaJ+4Hk/yITDEB+HEGU5BZDk1BiyK4WmqfuySmP5YaPymsdeTl6CB1+CZXgJ nYTAwwK9BGz0
EjTyEjRggrgUwjwIvRC+gRCFoALsVBj4FhabIM6BUAphHoS1EL6BoGLD+QYC Qc3xIe5hA8uJ
D3oKzZGX4Ev/WbSf+JVkySuFpMu5LV5sSsFTUqIppAjZ7SCRLWa1uQcbDnxn +P47A9KM1ZA7
yBaUDAuxNZ5u6foh2deD7+0KPucbm4TvQSk8cB0uRkGcDulI1M7yhcirpmkB 8pKnIc3r8s6G
x0xdwWzfIWykTx3w/eA97fvS20MA/ML7nO9Pcg+Pu3zvQMnTB3xve2/1vZbT o4aS54M9GJJD
MkM96B3p232Uoa6Divu7fDfS5IDvBu9E3xIvq2iIVVzTDjnF5JsenOO7HNor 8873Ke3Q5gFf
qfcaX0kMq5A+c8CXC0MIxcAsGOwQL+s0kMIanFXUgxuVbHGbWCVOEUeIeWK2 6Bd9YrLoEW1q
i1pSG9V6tVatVqvUvJqokdpG34YNUR+7TSXRRMXTmGewRGhMYpcnBKsJuhKF rVwFqZgxDleE
exegivly+NyMQA/WTpsTFgLjcNhSgSpmjguPDFX0iNHp4aJQRVicenXVXozv qIbSMNnYg9HM
qh4cpUXrPfR/2B5EGJvX3+6haeb626urkdO+stRZahljLp5Q9jNRbTwedAPv vARODm+rmFEV
fiq5OpxHgWhydUX4l/Sf3B7E3+Iz5WUH8T9oUl11kBuDvy2fTsu5MWXV1RU9 eDbDQzL+B+AB
x/yD4anhYKZ4SFanxPDuj+Glw/OAl0YTwNNoUDrDS9doGB6PKd7e9rTysr1p aQzHIaN2htPu
kAfjHE0HnPR0hmPvREcZzlF7J8UJj2EoXi+gpHgZCnYjL0PxYjdDmX0RJSeO cusAyq2sJw5f
xPHGcAynEjiGU4AT+t9+GsaFQnjf6OoFc+k/CK4NlDdAqA3ftrLRGe6cL8t7 F1TH/3NwsHb+
gkaa1jWEqwMNZeEFgTJ57+i5P1M9l1aPDpTtRXPLZ1btnas0lHWNVkaXB+rK qvdNnFpQdElf
tw70VTD1ZxqbShsroH1NLPqZ6iJaPZH2VUT7KqJ9TVQmsr4Q4/GpVXvVaFz1 +LmxdB/RaYFf
az3+6nF2qWUMY97RfueNnkOgrexEulB1WB8YFzZAoFVDxw4dS6tgT9EqI/0v 0PEq542j/Z5D
eGe8SoJic2AcCnWsaF+BnOVNZbG/dvhAUccKSvBYHGr/dx+oKw8rdWXtHQhV hLNmVIRLp82p
2iuKUFpLpxQelSjT6cp7or2xwmFQOIoWctwAIi0roWUaTRzxX9d/RTxlb9J2 kuf2YSUFd6D2
ai6cUjGTgCiYGf93u4dAl6LHQ3s1TLAdh3B7oo34sBP/syuE6JwToWNFHIrT oiOexp6ER9oT
JBn4UGKFBijWAQ2i/w+KLCi7CmVuZHN0cmVhbQplbmRvYmoKCjE2IDAgb2Jq CjE2MjM3CmVu
ZG9iagoKMTcgMCBvYmoKPDwvVHlwZS9Gb250RGVzY3JpcHRvci9Gb250TmFt ZS9CQUFBQUEr
QXJpYWxNVAovRmxhZ3MgNAovRm9udEJCb3hbLTY2NCAtMzI0IDIwMDAgMTAw Nl0vSXRhbGlj
QW5nbGUgMAovQXNjZW50IDkwNQovRGVzY2VudCAyMTEKL0NhcEhlaWdodCAx MDA1Ci9TdGVt
ViA4MAovRm9udEZpbGUyIDE1IDAgUj4+CmVuZG9iagoKMTggMCBvYmoKPDwv TGVuZ3RoIDM5
Mi9GaWx0ZXIvRmxhdGVEZWNvZGU+PgpzdHJlYW0KeJxdks1ugzAMgO88RY7d oYIk/LQSQupo
K3HYj8b2ABRMhzRCFOihb7/YZpu0A+hLYjtfEodldazMsISvbmprWEQ/mM7B PN1cC+IC18EE
UoluaJd1RP92bGwQ+tz6Pi8wVqaf8jwI3/zavLi72By66QIPQfjiOnCDuYrN R1n7cX2z9gtG
MIuIgqIQHfS+zlNjn5sRQsraVp1fHpb71qf8BbzfLQhFY8kq7dTBbJsWXGOu EORRVIj8fC4C
MN2/Nb3jlEvffjbOh0ofGkWxD84jRZwqZM18QI6ZE+SEWSOnxFmMnBGrCHnH NY/Ie46XyAfm
E/Ijc4ZcMlP8kXNp/sT1yefMMegpI55HH8n+Ge4r2T9OkVf/PfLqXyKzf4I1 Jfsn6C/ZPyZm
f0V7sb+m+uyvqT77K3SW7K/Jh/011WH/GM8uV3+cV6s/3qFi/xRrKvbXeHbF /grvSrF/jGdR
7K+xpmJ/vaeHXl8Unxx78qeVRHtzzrcRNS71D3bOYOC3t+1kMYu+b/7LxA0K ZW5kc3RyZWFt
CmVuZG9iagoKMTkgMCBvYmoKPDwvVHlwZS9Gb250L1N1YnR5cGUvVHJ1ZVR5 cGUvQmFzZUZv
bnQvQkFBQUFBK0FyaWFsTVQKL0ZpcnN0Q2hhciAwCi9MYXN0Q2hhciAzOAov V2lkdGhzWzc1
MCA3NzcgNTU2IDIyMiA1NTYgNTAwIDI3NyAyNzcgODMzIDU1NiA1NTYgNTU2 IDgzMyA3Nzcg
MzMzIDU1Ngo1NTYgNTU2IDYxMCAyMjIgMjIyIDcyMiA2MTAgNzIyIDI3NyA1 NTYgNTU2IDMz
MyA1NTYgNTU2IDY2NiA1NTYKNTAwIDI3NyA1NTYgMjc3IDI3NyA1NTYgNTU2 IF0KL0ZvbnRE
ZXNjcmlwdG9yIDE3IDAgUgovVG9Vbmljb2RlIDE4IDAgUgo+PgplbmRvYmoK CjIwIDAgb2Jq
Cjw8L0xlbmd0aCAyMSAwIFIvRmlsdGVyL0ZsYXRlRGVjb2RlL0xlbmd0aDEg MjY5NDg+Pgpz
dHJlYW0KeJztvHlcVEe2OF5V996+fW/v+8LSt2lokAZBaESUyEWRqETBNWCG CAoqxsgiaMyi
ZHFPopksmkxmJJsmJjO2EBVcJmSZLDOTp5NkEpOZTHwZs058ceY5WaX7e6q6 UZzJzOf7ft//
fp/XTd1zquqcWk6dOnWqbjWdHV3NSI+6EYfUxdc3tn33/pt/Qwj9FiFsXby6 U0GPjssB/DRC
4oIlbUuv33jor7sRkkoREt5ZumLtku2rmkYhZLIjVDBzWXNj04mNuSaEypug jLHLIGFt9DYR
4g9DPH3Z9Z03zHG9twfigxDft6J1cSNnuvYCQpNWQLz2+sYb2rK4ezUQfwni ysrG65vXfGk8
D/EzCNlb2lpXdb6DsmMIXV1D89s6mtvGvTrxPYi3IWR5A9IwfOlHD6iGxgnH CxpRK8k6vcFo
MlusNrvD6XJ7vEnJKak+xZ8WSM8IZmaNykb///wIR1AyC3tRMh9EyQjFzgyH aEvsDM2jkHwO
wkqJh8SnFz2D3sFZWEF9+DvkQt9gDx6DpiEefQ3ash8NofuRHc1FD2ArSkdO NA9NwzzQhNCd
+Cex1bHP0BXox+jR2GF8W2wf5G9HL6NvoAV/4jEqRjOBfh5qRp9xH6G62ENI izYhHZqAZmMn
akRvw/fv0IZ70X3ol/jm2DdQqx3dBuWVonJUHns+dgFlozv5HcIp6SC6Bx3F mtjiWAtKRWlo
KwnF3o59gIKoDj2GnoE2hfAgPxX50XVoA9qFPdzLgN2PHkdRrCf13GThOahp GpqPVqI1aCva
h36NrbhGOCWci90U+wRpkA1lQZta0Ge4CM8gT/D62MTYe+gaNIBehf7S7yB/ Db9XuCZaFvtp
7AXkQIexjI/h54UC4e6hW2OPxH4BGhlEY0AiM6GeReh29Dx6Df0V/Y2sj61H U9EcqPlXOAUr
OAgSf5t4yDqyjnsTjYbe1kNru9BuFIEROYKOouMgmz+g0+gjbMdJeDpehO/B fyN60kROcD/h
nuXe4jH/FMg7gDJARp3oCXQI5vPr6AQWoPx8XIOX41a8E/8UnyYR8gX5mtfy t/Pf80NCMHo6
+n1sZuzvyI286Cp0I1oPsn0M9aFn0X+g36O/of9GX2EzHoeX4UdwBJ/GXxCJ pJFq0kYeIE+Q
n3MzuXu45/kifhJ/Hf86/56wUdgmNorRC3ui90Z/Hv1d7HDsd6A7Rig/iCpB oreCVjyBnkNv
QunvovfRh1R/oPwJeAG+FmpZhTfj+/DP8a/w7/Dn0EvEvmlkAqmAWltJB8jp NnIvuQ9qPwHf
k+Q98j75C/k7J3Bp3FiunXuEi3D93EnuY97MB/nR/Bi+ml/Ax2BkCoQrhTnC k8LTwgvCOU2p
pknTpvlUvE28Q/vboeyhP0VRdFk0Eu0D3dWCJt0IkvgZehT0/lkYg1+DRP8D WnwanYdR8GI/
zoR2l+BKXIVn4Kvxj3Azvg1vwj/Gu/BP8KP4F9AD6AMRoe0hUk7mkEbSTO4g m8hd5Fn4HiGv
kbfJKXIWWu7iAlyIG8NN4xZw13AroQ+d3DruDpDsPdw+7gT3JvcJ9yl3FkbN xafyXfyN/IP8
Xv5Z/nfCVcL18H1UeE4YFH4nXBAuaIjGq0nW5GmWa57UfChqxLFijbhFfEv8 b20bTsbZ0HJl
pLUgHpiDqWQfsfPr8VlISME8MkHPQzAOc2BW/Dcq46IwLkaaD21zEA9vo5wa lY8Afyc+iorw
r9B6DeHAEvOnUS/+IznNv0iuQL/HDdjD7+VWCr8mfvQ0WKMd5Bg5iiehZ0kp mU8e5hD+CD+J
PgJ9vwHdh6/Dq9DT+Cwej2/BxXg9eos4uTn4DlQae5TwWMLT8DkELUC38k3o 2n9vBXEJ+iP6
LPoz3sDfDPapHz0AI/oM+gA/hb7DQuwLsG4cWKNGsDJ3gr5vQNTq1cM8Ww/z 0QMWZIXmBHqW
rihisWYifyM6h75FnwlHQKMmgSX9JNrC/4z/c6w4lgszDGYZehLm3TJ0JcyY j0BLjkOcxn4E
M10GW1IAs7oGLUBN6BawevfEIrGHY7fH1sZa0W+A9zucg7/DPTAj+oGjFL0K 3+3oXbwN5uGV
/99WgWgTGkSfYzfOwAUwH84Kq4Udwj7hWeGXwuuaMSDtO9BPQKM/BG2WoQeL 0e/Q5+hrrIWx
8aAcFIb2joO216IVpI47jiZjL2qDOZsFdnxSoieroJTbQHoPw3w+DnPjHNiJ H6FfolOYYBf0
aDHUr4VyqkDOC4F6D4zg7bgPUprAamejv0C/jXgc6YT6VCjpAbBag9CmP6KP Qdox1q4csAsV
eD6U9TW6GjVBDWNRDT4AI3AIlYBlreB+C/JOx2Y0Cafhx4GvAWaoEaWgEuHP mKCc6MzYONLC
HYc1JgbpPbB6JaErcDu0wgT9GEIOXI2KorOhDW9ijo/gN1grHiTNsU3cmugK 9Bv0FIyJyq8W
KxBSy+eqZROvKJ0wvmRccVG4sGBMft7o3JxQ9qiszGBGeiDNr/hSU5KTvB63 y+mw26wWs8lo
0OtkSStqBJ4jGOVMCVQ2KJFgQ4QPBqZOzaXxQCMkNI5IaIgokFR5OU1EaWBk yuWUKlAu+QdK
NU6pXqTEZqUUlebmKFMCSuT1ioDSjxfMqgX8ropAnRI5y/AZDN/BcAPgfj8w KFPcyyqUCG5Q
pkQqVy/bOqWhAoo7oJMnByY3y7k56ICsA1QHWMQVaDuAXRMxQ4hryvgDBGkN 0KiIN1AxJeIJ
VNAWRLiMKY1NkZpZtVMqkvz+utycCJ68OLAoggKTIqYQI0GTWTURzeSIyKpR Wmhv0DblQM7g
1jv7zWhRQ0jfFGhq/FFthGuso3VYQlBvRcR14xn3pSgUbp1cu2lkbhK3dYq7 RaHRrVs3KZHB
WbUjc/30WVcHZQAvyahs2FoJVd8JQqyao0BtZENdbQRvgCoV2hPaq3j/mgNT aErDciUiBSYF
lm1d3gBD490aQbPX+nu9XnUgdhp5pyhb59YG/JGypEBdY0XyATvaOnttn0dV PJfn5OYcMFvi
gj1gNCUQvWEk0nwxj2GMnGJVsy9KFtMWBaaBQkSUxQq0pDYAfRpHH83j0NbF 44AMPnUYuCJN
MCItEWlyw1bzeJpO+SNChjmgbP07Ag0InP3i8pTGRIomw/x3RFGqJxdVDfKH 8UgoFMnOpioi
ToYxhTZOZPGi3JzV/WRsoM2sAADxoRqQbWPd+DwQv99PB3hbv4oWQSTSPas2 HlfQoqRepOaF
6iKkgeYMDuc45tGc7uGci+wNAdDkZ9lGwRHRBi/+mcxO25Rl4yPY+W+ym+P5 VXMCVbMW1CpT
tjYkZFs197JYPH/cxbwEFrFNruWSSAIjSRzLBaX80UViGqnVR/gM+NMwpW6K cKCULAErlRFz
w9T4s072+/8lT7+oHcHUHztHuRi4xJZoZWR86PL4hMvil7VOv5WD9vJBUjV3 wdat8mV5lWCA
tm6tDCiVWxu2NvbHuhcFFHNg6wDZS/ZubZvSMDyg/bEj25IilXfWQSeW4fGg rARNOhDAm2cd
UPHmOQtqB8ywu9s8t7aXYDK5YVLdgXTIqx0AV0VlqeRiKo0pNIaqMCh6L9Gy rKQBFaFulsuz
BBZf3I8RS9MOp2G0uJ/E08wsDT654MbQwRfgC16BiCY9S3BUI/aTMtWGBD7K IVnkoxh5tBoh
SrhjOIgkcIbdyB0yf1U6VDrTfL50xlApKgPcfAEeY/L9Fr8lAx4YHIwLCjd4 QRXQ90jhB6Eu
2OEgoRH2YWbkQ+vVwiwhS77S1cw364VsV4lrqrPOucwplLjGJm1KelB4QCf4 LBkYEZs1w2TW
ejL3i1jsjw32SbowNPFO1dbtx4o/30/8FquCFHO+mZj7ybY+ZcwcdwiaVk/b NsNc3/5VqH3G
WdbIMtZGVN+O623+ApfTaXXYwVeEb8CPLYUFxRNJUTgYzAwG7iMphxtu7W/I LV4y4/ZFjw+9
ibPev7l46sLS0hVzJh4UjiQHX4h+8h8Hb+9ZXJXt41+4UGS0zv/Vvn2HlliN tKf3gif2DPSU
SnXNAJJig2qZRS5TpRqJdEsRaVA6KX0pCT6pQVov9UCCwGlEEDlnQlhFJ2Et 51A9DI4GtvS8
TMQg5qHrquRPD/MebVkp62AoIXz6HapvL+UEc2kp/I3Jx+31HSEbDAWGcC/2 RD8Bf/QQ5qMX
vp/OB79/D9QhP/Yp7BMmomzygjqosWgC2kyXxRXYZd1l35l5f7Yk2ivtxHrU MGB8xf9R4BvD
V2maUYZ5hmbD/bqd1r1pA3qxPKCmVwSXpjUFN1k32Tem3Z4uFQenaCp10w3V pkr/pDQxLT0z
WKwv8helFQWK0kWNLFgkv9uQqU9LSwuI6Wlqzir9Dfa1jtWjurI3O+7Ifshx f/azac8GDN14
u+tO94PZT2VHcjQuv1P1B8JONdkX9jnxB07sLNT6azK2Z5AM1Z0SzvDmUNm4 QL41OTg/B+fl
4JxUf74ZmwuxH1GVMUllDAIJYnKUDGHkCd3QT+V4IRQKzTh7vv3sTNCVjhDT lvOAhM6iAxoy
eW6tWqTBWIOdOJg21l/pn4vrXE24xfUVeGouwnv9aSTLZtCTLO9C2I9WZulq vNhbaRPLhurh
z2J1lQyH+vakAZQW+01fVnbY3x+Haf2x032p6TR+us+XHo97vCyuJgFynQGP TatM22W4L+2l
tLfSNP40vYHnvbQfBz1JYVSIac9cuWUAI32SPJHF0zLCFKop3uQwgq2wCpth vgF343MYNh9m
iDWAs08pbU6gxFidgXi8kD/HE9oFpwpFOwtdKpTrUqFQl1pUHHapodHwyBgF DyjX5PK5Frpa
XbxrnldNSw+bvLjGG/OSROfbQ+frQ+xzJkSj50NUvCwaF0Y8s46pK2qHT309 GPcBlB57TZV0
1jJTFjxADl8cMpTo7foSivbqS0BCnx/QlSDKjIEftdfbMpxOmL1ji8KZwUxQ uqLw2MICp0sI
BgNposZhdzl56pdqAmnBfOy1rlx8fXGG3TEt+sw169776L23sqJfWxbWtuYr yUH8fF3t+S/f
HcJ5odnzspLzFIfdUjVx/oNbj929bczEST5nINWRvGR61cYfvxGBeb4tuoLf CbPIjJLRQ+ro
cbapNmINcyWGEls4qYKbZphmq0j6Nkmar5kv11nnO+e765K/Er9N0sLU9vaT zl5BtANQnTod
eMwuv9bblopTLaOMRlPQbIZxGaXq2lA31ORJKStnsx60s9QM9vbMTHP7V8yu lZ2FL5319age
T65VDUs0S+QW6xLnEndLsqa+DoGxc4wFiSCLGYEIMsE820FeIC6Qj2Yb1hT+ YvkAJtELA7Xb
q8FWOO9esui2jYuXbuaDD9c0Rf8UHYp+FX23ct7QZ9xA39M/7dv76G5o0Wyw IA9B3w2wc9qp
Tv0Uf6L92va1g3+FfCoQq0fwSKTOPN8231nn3kl2aXZpd+r7pd+TPwh/lH6v /0T4RPOpwbxX
+xvyW82L2pf1Qpd2i+YOLWehUpF1LioVOy/aS0RvQ1JbEkky+pHHWxuXwYyz w52HroNBb6/H
9e3Qc6nFvAT63eLmMe02WPmwlfbbYYd+pwczRvR69tahh/+Kw9HXvvhx9Out WHlg5cr771+5
8gGSdifWbI2+8uVfoy/eEXvyZ08+2fPwk0/S81Zf7FNyj/BT6O3r6ihYcHBA HmUab5xurDOJ
Hgdyc04HclltduyyEjt2c5Ioi3o3nVom5OpxRVxcA4BBF+fqx3yvA9OB70MO ut52qka9TsqT
8xDKwwthHwkUapabC7qs8xxl9t32/Xauwd5t32E/aT9nF5DdbFfs+Xbe7vHe 0BNf7No7qiLF
c6oiE8CtGUD22OC4utIZdE2GddB83nMGuamSgN4A6RmLtcRSaIIPVRrsCFjs bP646ASB1a/I
EigqLMqwkBsHdZnJmdPdi26+6sYSnXTrrdjLB09H594WSk56L7tw1pQx9+MT p998PLoF5HMP
Qnwd6IMT7Vbdos1lW6BdpuX7eRzWhs0V2grTZ2ZBQ/uaYhGNBo1ep8NIJjjo RKqSHt6PcAwK
8bqp1XKCNdnh7nGTNvc5N/nSjd2yLqg3wnToNRj0lMIELD16fE6P9R5XYj0E 6wLr/VkzdUyY
JWcJbImEZZHOE7r2g7Hx+y1haho0GgesjzA3CgtSiYOvi36SPqtkWmcIpoCw 7c36h6p9JPWZ
5nE1d/RGfTAVnp287I6b6Or+GqjDh3yQre6j1SRuHNZoxvGytJ8jRBPEipAv EGG/9vWnqZ9U
T4Ve+lVCVYcX5dfiizJnoPDCf9MnLfkB8JCOgd/gQH70jXpbiWma6WpxuW65 fp+019gTOGQ8
JckarUZ2aZ3yWGOlsdIkas2SxW60m+zmscaxpitNXca15jdl3Q3SDZ7VKZul zZ6NKRrJaZf0
JuMcY5fxDuN9xseMglEx6O0gS5PeYXA5M2xmO26w99iJ3Y4UfwZ4owaj0YG0 IPJjaiYymA3E
8FZSZo8mohnUnNTwmk1tAawE8gMk4HcoWEH50HjqfKWNWXzJ+aK+V/3Z8/Vn h0dgqNRakgee
ylApBhUs2TQ6VG+8xfwStpQgiCdGp77Q4i9wUnMtOp0um58bTQIBC3hnY+nU Bd8s8ABp/cvv
u194vuGW5X3Rn73dMffaJaV/+P3y0uqp6c9+Ihyp/vVtT7yTPG7j09EPcdnT df6hh7mZ6bWT
pl+jF6iMy8FuZYKe2lEyfmwAmWPfqJW6kgelhwwPmJ8U9spHpaOGfq9Wa8dT yZWaSrk69UnD
Ic0h7yvyq/q35VP6b8SvDYZkU7JDTUoJO1SjJWxyPOc44eAczNVILWPQ6AJI 7lJB7NYaY4OR
GN1Wut4egoUVF1qZO5KihBlMGxWHodw4dCczqJqMpnAP3Z+ZodkLrVZqMHid 1U0nUbpORH6c
5/BXG7HRm5e6MLU1dXcqn2rya1WDKaz1pLTEbWWIGsv6r+rBqaH2ElZY1e5W s+xlbjXVBI8k
MzySLWVsLS4bYiuwFRoBFFbaGCBiEOgo7B0mPZ9YwBkDggxrCW10r4sC5oiw aLm/LESX6jq6
6pfUs+qNKkjJSCs10uqNKgiLLed1eaVDoRA4CaAfhdQ2taP6EBY0moACVsmM wJRzfmqqxtri
S7uLfIfdYz/bH/3LhhZsf/MstmqGVO62xkkLMrkb5v+otBTj2XkPPXLwnvex Foeir0SP37Jt
Kl5x4/rJk1dRm37JT58zgAQQ+SjqpQs1AukWIsKgcFL4UhB8QoOwXuiBBAFc ctgUES6I0bA/
jjz8P/njCQ+8MO59C0e+q4S6dGAfF4DV0OEk1SFkefPCIn1o6ENLH1x/7FQf QObqK97x4Yd4
rOF0Wq2s1zmwg1g5r+SV01Cu7hWdHuo/pzpBg2Qk6OzIo8tA2bowGq/bhKS4 2/qsjA16VpZO
coV5DHs3DZJRWVkpDESITcAk1apDMq+TJYkQrAFcKjFQDndyVlhn8BnyDaqB N7hcXrNcJlfL
nNxP8lUdT0p0fBlfzXP8EZIPhrtbNemLEFbAzeSwR/8SrEkeagRC7hln68Eg 13tmTmmu+JjF
mYDM8LWWYGgCc/9C9XScmTr5sd/mGls8ttjmx/hwdC7OfHW8S2M0/xr7oyC9 oQ8PTnHm5pJU
2MTApJgLc5nuKE3gf+1Qc611mrqLftYu8UHpG0lqS+1OJeO5sH68I+yZzlXo pzsqPA9Kkp25
XzovW311ohF2Xkh2jTIagsztMpmQdzv4YmY/TKXa0hFuR+mMs0OlH8f3XWcv rinU72rRtIz0
u/z+ItDcNPC6rIUFLup0uS75H3xj9PvyAwsOR7+PvtB7G/YMWfMqbmzcfMfS pk0PX1OHM0Ff
jdhzHzFfaNt31conHj/8CPW56mLgOAlvQn+T0KPqvJ3CTu0u/S4jr8WiUWsS 3ZnuG6Q1VnGN
5QbHRn6Ldot+o3GDdYt9s2Oza7N7o1cvWrV20euweu1et8Mr2nINkidX5JyZ +2XovVlW2BDf
qSr5KWpKQ0pbSndKT4pGSTmXQlLMmWCLTLB1z4c5AER9yeteTPgeM86yfXZ9 +0WXDNfTuWsL
F4+FsSxUqOfpVxC2Wy8KoG5ywc+XbunDFXhDdF30eHQgug6P+fjAgT+/f/jw afLW6V1tvaHx
0ZXRh6I/jbbi7XjZt9FYLHbhm+9R3NfQwLxCeuJWdTouqA3qOJ7DMIO6VSl5 fFhWxk8IS3Qr
lYDq48mjIRUeGkkr/1n6QuZ5SZZtJJk3Sz45QHJ4BRywpWQZ3ywtl9eQG/jH pX3yQemI/JX0
nezcze+QdssvS6/J75BT/NvSu/In5FP+I+lz2bBGukG+ndzJ3y7dKe8gYq2u mSznl0rL5NVk
LS9WkCq+QqqSr9ZeLdXKolvOM4bJeD4sTZDLjCJH9LxGkmQH8fIuSUzsN32E 52RJ0Itigcao
L0CIM3NEW6M1hHX0wXpp1BnCWtWYGdbRByQ9rJopotNyGHZyRJSRli67dLa7 SuJbrXqcd9b8
1lmakNQfm6DmQi0Kr5WkAo63cxxPdLJcwBFACRTD6XlC9DLYBlHrg0WmHxv6 6Gn+ETKOmsq+
a+rDAtt4z5kbFgpEVVyvxdrj62EUjusUnZ70k3GqFRYvFQiRCkSowAfuGi3G MKYLXCPYcodC
5tL/Mpd6Peah9qH2Uq/bDPYfEsxn2lHcSpSVQms3CaNDm255adNoNwVsy1gV sc2BhUcbO31A
p4wbVwcKRz/xHSYKtVMvAmN6HIX92HIPPgq7dREfi56Nvh/9c/RPwpELbu7T 7yr5275fRwPo
1CKYW8dhbinolFo5LrUqdb64Wrtav0F7h36D644kSePSJFld1qQsS5Y7y5uV qp2qu4afKy3Q
Ledv4m90d3oPGQ+ZXzG8bH7H/InZyCVrFLZG+LwlPigdfCrsTM7VSFbVaA1b q6pt2KY63GFb
P85Ss525JtiWY8WzEJIzrfOJT1E44lXS8tNImiezR8Ym2Sfnx2dnn3/d7osT j67tzNc6f7Yd
THoeLEBDsNOGLfdZC8SG2kOlw65VfT0u8ls0PGyFSFHYSuclH98jaxzURI0t LuLKyLr66O6D
H0f3PTM4cNcb2IILc6Lv+Z7ufuGjT4/VH51Mkr4e6l+w5Xm89M2PcNPCaR/9 unjFLV/9DazY
99PCR6Cfd8L0fJatqK1sRe0rCDM16QtkxNWlzO4KI4Gusd3C6fji2iacE/hu AfY9hENawr0L
WhOhZ2CD6Bwi1LmkJ2I8WsmPGe54x8i1Nj7qdLW9E2clVtu7YGWYA6utEz2s uq62LLU8IHCS
xqMpJaWWKlJl+YSIJmr6LbzOiWSH3S5LGps96HAgav2NTrYnceKYEzv/zZ5E 0l7cjGjxOdD/
yzcjI3ci8W37P+xF6uNLRBC2XP74JgycXEC5meOPt1y37yrs8c0um9qRjT27 5y26dt8DpCfq
Pt08obrrDB6kKyBGu2DHEAB5S/g/VKPEabQezqXlrSBFsAmoz6or4/rjk5VC NRvmIVcgwiog
ajktISInwSyHGc7xdJ7ydJ7yBZoTAhbAnVc9qq5G16Dj2nTdOtKjG9QRRZev A+sgJQqlUDXO
mROWCtguYJCtDdv6ZDrDE/uAEN2W0an5VSLGxo05ICi+C4APzOu49RtAHJhr CWyZVolbtsHD
ErV19MwucWA0mVF1H9IVabt1RaxjV3hHh7Vz4CFwTq6AUzm+ktug3aHt0fZq z3Cal7gT2ve0
nMLlacPcBG219sfcbm0Pt18b4Z7T6kTmzBUWhYkKD5GuF4a8gjBR6EO0F0HK TnD2RofJXHgw
6spUBWLw0BJRdBPOJeaQTHECKRRnElX8EZkvSnaSJM4gU8SHxKfF35B3yafk E/FbosskWeJ0
8QZxs/gM0VDd7QgNf9CwAatDzH7R3Sm27MIKqcW26DtDB8Bs5XJvflfJHbtQ QUf/UVgbgsIg
ktB8VbqO3ES2EY7woMF9C9kIXntYKwkY6SV0FNeC/4BJvWoQEO/jFT7C87xH PoL34h40PFb0
VJ+NDmzamNGArbJGLBqbXlzIBaOfPPS7lZjkn+EDO6bE0l/bSFswI/YJnwQt GIXeVQs2OV5z
kJuStyWTPdxTwl77Ie6IcMj+nvt9j9Zpx3c573IRv2yA5cllc/p9BrNe7sfp qr7agFXDdthi
GrCzHxPV5LPl2YhNtTrDtj1JAvhj8w+aocWEebMFkMzvyTRE9IN6otc7zafW +7b7dvv2+57z
Cb7T4qnqdJzuDTlPudbgU8iT/eYLCeftPBjLr+jhbj01jfVgKEPtZ9iDRtvP Uo2M70Tjf/XM
jQfXNH68GPdbxGJnwoERMyYS8OtgoyrS3So9YZqBzYaOWVev6Zg9tsrXcUPt tKlLdNGhpOtf
XHvilqVvrtsZ/fiNV6Lf4Q3+ZSvvaFt+s+MjruXq6bVNDTkbdl9zx4rNz69K Orbh+ei5j9gu
9WPeDnJ1oQA6qdZOsFRZmnU3ardonxKe0u4x7rEdRAPcQWO/5Vnbr9CvLYM2 S9g2X1dnWGiZ
bWuwgXO0xvmg633zB3ZhmY06BKLb6kvKSyJJVKpJe0yC2a/4iZ8K1Awp/j35 Eq6WPpDOSZzU
j6v7ejAGuftHyD2Jyd1hcJ+qtmKrNwOEuyb1lN6T/k8CZpI9D3tOWODbyyBQ ycZ3+Oyod1ig
xWD6YCVCF08mMROsgx3T1WOzPHfK1Tdalu/++fdYev0DnBp9+8tn3iLX3jJ7 5tK2ubNa8ZzU
OTU9F27Curc/wJbo3mgXuIsPH+aSNz9w0513b6CnpkHYc1WAFGVkQB+oJXrF UCLpPfqQfo7+
Ov2Hes1ZA9bwTj6DzzJMNVxj2Gs4bHjZIGGiRXqNQRRknUFEer3B0I9/oXrj ThJ12QycgfAy
ElXDoOEkRI7iLPC2CH72EOJ5YIA1pPZZYbuMZarOVrO4W3xO5ESvqYysJ4R4 jEfwVXgqm3Vn
2s2wNz9fzyZemfl86VA9M43UODJAfR/+FvNLJpMp4R7qcvVX6GfoX9e/rxdQ fR1ztmH/BLai
CBdaCh0BCyzbZN3Qk+TmLw4dip6L7seZX3GPXbj26+i7JBX/PaqDeTsd9Otv 4O3k4JPqFQOW
/pRDWS/n8KJNdLhsLoc71Cw0Z3VqbjB0Zr2rfzugr5PnGeel1QWW6ZdYl/pb spbmrEnZmPKA
X28NsBcYvjCFarPHG56VNivwfNrzAb49rT1wa9qtgf9M+8+AJiRnG9LT0gMl hnCgSq4yVKRN
Diw3NAfWGm5M22LYmrZH3mt4Ms0myZJBk6YJeGSPwZkmpgVkA1iL+W7Vo4Rb 3bjVvdtN3EdI
M0oCjdSDa5WEk3LtHJrK3nZM8yrh+LuOBrwD9+AIHoR91H/xqrfEzGM+N1ty fxlzYZdqc4Vd
VWJm0Dval9ljjpiJuQp/aYkfY3ly30i8QKyaU3sAqePqmMkA1QYY6qDazV5t nInDjtAZ+jaD
GW52FpIG8khKmQjyOJmAf+610bcWpwFA7LVeK42dVE3WEoNiLZFZMNG0T1Wj HtIMJbKbBltJ
aOSnLjH+jvHyeAN9p1YlTzNMTqsM7JGfSpOZJsRfbV40V5nsWxQee8nVS7wO YedrfEBB07Hi
3b1p+z1XXBUe+K+GTeu/fArbsUuMnrLdcsut0/JyxuHIia47Y+i56OfRt/H7 yfdsXjsrPC3J
OnrC/LW/aHtxyd9+bWhfXJRWEs7IW3L98W3r/ngdxnRd2AQrUzF7M/KkmrVT wJIRzxGWCF0C
l2etNS4ztll5WTLpfXqyXR/TkzJ9NRjzfrJGHSWKsBXliEbOQpJZypfaJF7y rrfutpKF1vXW
/daTVt5qRkHY7NG3I4R0w0AT7LGUDeDk+ELWPuIY+Kt6zwx6+M18LhikkoL4 i5J2VBVxzamK
FM1aUHtALhhXx9a6+HsSl8gOhy24h54ET76uoqHu6iuvmDA7jw/uvK6i6O+j y/dF/wp9nAc+
Zhn00YP+U51Va6qz1jmXmVqsLc5b3Gs9O8lO/cvml93vmN92f6b5TPuZ7TPH NxrbONs4x3Tr
dGelu07fohfHW4udxW5ujbDGtEnYaNriedK61zlgPeSUjOwkMClM4UGrPWws pCczfZ7UMIMm
S9hwBPNIBh/WatEhFUiRCnSocAeY7iMwCjxkKS4R01TsR3kGihjiB4ZJot9+ 2esUekAYOn82
RLcPsHsI0V1ECGBcp9rrcWKjwGxzsZA42ADT7eTHRP9iXFzdcsv662qWOLA9 dP71z6J/wc6z
L3xEviiYM/eefccfvqY175cv4CCGdQhn7KX6kQOWeQD8VhF1qIE8KZ/PF2pg qLulHZKowQLJ
AEMrIq3kcnn59dSXwbmqrBEVnI/W07NmiFo4Yw1pI91kB+GJRzv0TGLWzqo9 QFT6+oNZVXhM
aa44w7yaoVL2dryemkq/A7aGH0Rn8HdFZ/IvfPPN9xOhVXpoVQM7o9ulbssS X+XJLnEA/xH/
XjxnELSil3drsjTFaJx2Kq7DN+MuUQ7ikDgWjxcr8XRxl+4bzTeilMEHxWw5 zI+XJ/Mz5Rd5
7VXyXL5ObuKvl2/At8j38Q+IR+Tf83+UL8gGjhdFSXbCIpstF/JlciUvOcAr Gy/PlK+T9/KH
+dfkr3gJPM5zfVY3PRk81edwUXhadegtYczLIg8LDwVaJGmp03/60KjccIwd hpxWTc70MBck
4IsSSdDodInsczpMUdUF2bogEuywi9AIAsw6rSTpEHiO1/dqCiUAqk7bXG3Y bTgNyxxHk0mh
jiZbz8UPpqnN5FHzpTO/djd1BDzg8X/FMJQX3/HAgy5lofbhnXwcw/Q0AtFH 3LodlBXJzzrY
CxAxd5+6/fXt7R2YPgphV2+jh4N+jtPj9dF78NXHXsbTo7vwlujeU++RAOGi f8TpUWnod3ha
9DDVtathVN3CHqRDGwcQD90eA7NH1nl14/lx8lRhvm6f7pe613Xv6mQ/yIUT kU+XpyN5ujJd
tY7TUYdJd4T0IA4/c5iArEWtXgsLfF8evZBCGlQjqQZpew0YefQJX6gU/CCq f0Px086zQ9B+
tqxTn7KeXs1waAhx+a3W4qu559d8dSuO/lU8+zL/CBZ+2xWdHrW9gPPJDd8O n1BjD2yr0lUH
GQfzPUjP4OJi9/BLV8eVfgbUNAP2lIkj5+H3SVeDd56d8CKPqxOW67q0m7Q7 PXuFvdqnjPts
A8ZDluO2QcsJm8EhjLVUmG90HiRvmE/axaPoBLAzt9GcpIDbSJfX1LjraPD5 88B1VJnbWCZh
VTopxRJu4/6426im+fg88BvVuM8oxH3Faj3WezPcp6wjfMaES/6vfcb6xIvt uP0RwTxbmbOd
sD4j32Tzpug5ee7kupvMLQ9Hvo9+c+JP0Q9x9n/t/cPQI+tmzVwGPmMbPyd1 bk3P0M3R82/9
Z/QcTOIt+F7cdPTCZ1vuv3Hb9g3rQeLXgMyKQFtSsFkdpTUq+mLrFOs0z4OG nxl3Wt8zSlaL
zeq3BKwbrLCRwgYZ/EOrxdJPelSn0WA3Gg1W2a6wKxdcDXgh5PLty2EmkSQD rHULVINPzpOJ
TKUk77Gzo3q7M0xf7ap2zt6Pn1btFovPnGcmeeYyc7WZM1NSM63LZjIZeZMZ tjsnXVgFn8br
M1LBWw1r8LGT9BbRbrQftMaT+uYAvhJdPC86f4baeorQjZ6ZKSYkhC7uherp MRKdqSPezA27
7pdthDJtYEbF+Ot1EZaD9GuwW796Ru2NaxvXNpzZQT4Z+q+caxcdxXzL9uhv YgivTVnYun3H
pk3X+cn30W+/zYuee/fg3S/Qu0iNsU+Ea8EX9aK31ZkbpS32Lc7daJfmFekt 7i3d3zkpQ8rS
ZxlG2Uc5u4QuaSMYYpvoAjfVNYpkcxmCmCU8KOyUXuN+pRPKcDVIfLaZ/pDr HF0n6K0fd/y1
mmwAiBeoLncurzXSYzhj1UITrjZhEz2JM9GTuDRrrsyZvjTOR18iVpQ3Pxkn OzJ7RGwSfWI+
ePH0BC5p3ZzLTuASb9foyVv7mfjaCUh94tgNlJf5WuwQ3JW4l6KxmKks+TLs mxR9/YvoH6Ob
8Y04jA1PNhVE/+B9YvVjv3m1Z/U+knTNuc/wdrwAr8T37742Utlxx+fR76Kf f/EAnd/TwAMZ
DR5IABXgdnWZ6NUmCylO7/SkqcnTMv5g/sAijfVUeq4OLvEsDW4M/thzr3eP dyDpFe+rSXqN
xuBwajzOTM0oR51nDdlI9mgOal7W6J8Lv2smKekFYyw5hnR64yddTcuChycl 3Jp+IZ2kV6ZQ
Tc03msJXpGCUYk6JpHybwqek5OBCpEIqtU8EzfPTF3x++oLPr7rphSbSeZAX 9QaZXtfqg7yc
xGtFBoEih57HqXZd6pigdpSUZajz6XfriU+PY2A3VKMzrPdWh3G4ATTm7nyw M4Wj/Atd+AMX
rmbXkDiXpzDxzhP8PHajq56OTSgeO0M3WGdhJQGLPASAevDsbXQovvD05qXg 9rqzw4dQ6TBV
k1LCc9Ob0kl9qI7eZIJZwBnNpYkLdtQtyqTeIrjSnN3p8lNfmx3mUX+7eGxx 3CZhjUaMe02Q
NLYIN8dCb5w41l/FJWVEP9eZRW7q4/WPH5//kx//6qqa1qq5+Nqxn6cX11Zc NaXQrCMfjn7o
vroth6P9d264KrnYo62s7N284K6q5AwledaUCdE3rAXuzNIJ8wuCxenNIHJ6 l/M55lPJuHwA
ibFTqlRcEtZkwSN+xJVVFNaoWeyI65Ra48+EPHiMQtmwSmTJefpxqFgo0y9H y0kzt0RYpl0q
f8qZpmtgQyxhTpYkXpQwVpAI/oKokXheETR2QdBoZdWbMlFmBsybEpYzCMdp eIleHjBqRCLw
PEZaPbhyqJ80qjofZj/P6sYc7ifpquSTcD54fkQ6QtLBa21UJQU8Po/u2sXD i5sHTBZ1LYbY
e8ThQ9QZZ9mJNz1SvPwNgQijtOmlxIHis1KYHR3G3xrowOdPZXdkuFi0V8vL R2JRkNSFAxp+
HP3UwdDGt1t+PwdfcDY4Tngu+svuoUNroy+TCbgk+9cv4xnRPuHIha1EGTpN PYwf07svIHkn
6lVDJuzDJbiQFJon4UmWP+FvsSQKTiGd1FqWWQSMic1usdo4O8HsBDqFAw9Q tjtkJ0I6OaiV
2NGzhGMSlv7V0TOyB52Oi0fPDnzOgR3/+uj54lk5ldrZkhKLiymydvjOmCV+ AcZy2bUY/PTm
440PV6dEP1FmXVG5sjD6iXBk6KPdU9s2bx+6h4zZu6CoYsvGoS+g09B/Nxij j8GCO1G/CjYN
Z/OKWbHU8d1uQcs/5yYOp4XYrU6L0WZCZqMNIzOxS1qTDi/UxXRER8Uga7DF FD9wp9FUM5RL
fUyNzS5LhWXaam2NltNmmfMsCy3EQi9IGYy2ILEvRD3OQSdx0rsVkj7s9Lhu GCAt8QUv1B6/
A3WhHrYBnvg2kF4/gUBvJJYUJO5A0dlsK2T75MTmz+Gg5yiwzLsfLnmw64ZV wckTryh6443o
Jw/zwZqNd8xJf8lcMqvq/QuHuWn07vSc2Mewvx4EOaSjfGw4mK9N8YWD/bFv 1BWAvGJ5xfaO
8I7Id5lX2+8wc0GUrR+LJugr0VX6lfxi7VLLMseazE2ZOw273I8bnnI/5d2T ujdzT85T+QPe
w6muNbaNto32TZn8TrCDO0EkyaN3ARaSKJ7BjaY+Qdno6tFk9BFyN0qmJ3pO d7gtuTuZ9MDi
layxZrHJD2T5WWoWyeond6sGq6EsrTqNpFHuNJri1Qi+U9Ka0Cm6IHoLPKe4 NRmnnJ4x/3x+
Sl/yhujl1pCZnZyGztaz+wT1NDCfLXF2iuhcwsHEfcz4jR6HnQ+ksUMJ2wjX jRuB46nXL/7o
zd99srzhxvXRoXde3fDT1QMLq2saFs6c1eBdU3d1R2fd0mbONfqRhsfffvvx Jbuzxxy76TfR
lptPrXkFz5p77cK51Qsbhq7ovO2W1UtvuZvdEojOgl0dXSXz8Ex10ZqUTSnE qje0jdlo6B7D
KzhAAlw+nbCciieTydw1pjp7Xcb8UfNDdXnXmb6xfGOzTjAUOidkFeZUGSqc VVkVOef0Qy75
bhgFnd6gy9YbMo1OlyPXoHc5eXc6TtzNhfWQXQWysKswfTp9HGZlx/2RQEYc jgnHr/tIjiS2
uC0U6NUEnymTAqOcS6eDziG6PZrsUbogmAQ8SpU8Hq93+xg8BrzLflVGhel+ qyf/4j2F84mb
CvQY5MzwFdGh84k3DcNrHGKNY5X3wtRhl3SG92Ml1OkrEbXm0hH3Kw0tphZ7 S8bSUUtCLXns
ZqlLcLqG17YiDRtY6pa7ivwWu5EEFBjnkcO8FpdrU7LmryzOsBnWDb59yyKM n/tVNxYnth3d
Hv3bhxdub1h69+ZlzbdXZo5zpPqdYwLX/uSZg9t/j3XY+/P7L1x57Mjy0oG7 jeT2p376yM+e
6PkpjO39YHm/YTdAktAaNUMjDNgH3NyVAl4qvC0QqyXDYDSiJDO90mZCWuc/ /YrA6UvJT9x0
EFLMppF32ZIv/yHBxd8RJO6xXfotAWy6wK2j+k1/SRDwkEt31e7Hf8DG2ev2 Ldo5c/lrzz+6
f/Xka6cW9QhHnP7392/qb7E4ht7hX4g2jF5UXrPMIMPg0/6cg/7o0A71Cq0A m80MjdUn4Hxh
v0AEQeJ42hVZytAhraip4shUGcGm1auwuzqcgZdGdkE/sgvMUYVdaen50ou/ hmDzlx1bCqAE
KSVCf6y718vAAXb8WAdE7IcFbG/p8CfC/XzZhc/I6SGFKxSOfBM9+nW0/Wv6 81PqgpDt3+sO
bV5oKv271qNlv8p89M+ll35tj6KzNB5YKzCSEv/DgPGJE6Mz0eRLP2T9hx92 ZmsgSXgF3UdK
0L38KpTP/xltgzCb7EM+gPcAfA3yKM0DkF+eoNNB3lxNCarT7EP3AFwE6XdC 2l1AtwvyH4Uw
g9JDCArz0XQuBW0CfB7Q5ADUQ7g6UdbVEK4BvkaA0wAioPkx1OuG+BxaD/Df T0cQPmPR0+gC
2c2lcPfzGfxD/Cv8K8JazXrNQXGh+I72GmmDnCWvkE/rPtAr+t8aWg0XTDmm n5lLzZssHZaT
li+tW2yTbB/YP3Y85gw4H3N1uBvcr3oymVRCqBBWHPohyIzy0DyENN+RF5DA PMA53OcIJfKX
syfHpCmzGMe4tKgzgXOoFt2cwOn/HXgrgQuwkn2awDXIjYfLEdERcD7iuBZW ujcSuIS2EpLA
DWQfufPi+BUJYxM4DJ9wXQIniBfaEjiHcoTOBM4jWehJ4ALSC/sSuAbwQwlc
Previous Topic:[ATL] Xtext as input for ATL M2M
Next Topic:plugin atl
Current Time: Sun Jul 20 18:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.05653 seconds
