Home » Eclipse Projects » Eclipse Platform » Problem with "Automated Testing of Eclipse Build"
Problem with "Automated Testing of Eclipse Build" [message #552407] Thu, 12 August 2010 02:20 Go to next message
Hello
I had some problem with "Automated Testing of Eclipse Build". I downloaded
the file eclpse-Automated-Tests-3.6.zip and other. After I installed every
thing, I couldn't run it. The problem was: the eclipse sdk zip had the wrong
name. I had to rename it from eclipse-SDK-3.6-win32.zip to
eclipse-SDK-I20100608-0911-win32.zip. I don't know why.
I needed a lot of time to find this solution. For the future I think we
should change the test.xml to have an idea where the problem is. Could we
change in the test.xml the line 62 from <exec dir="." executable="unzip"> to
<exec dir="." executable="unzip" failonerror="true"> (add failonerror)
thanks
Re: Problem with "Automated Testing of Eclipse Build" [message #552571 is a reply to message #552407] Thu, 12 August 2010 12:00 Go to previous messageGo to next message
You should raise a bug on Eclipse Platform Releng.
The problem comes from the fact that when we are approaching the release,
all the builds are named like eclipse-SDK-I20100608-0911-win32.zip.
Once a particular build is declared to be the final one, then the zips just
get renamed (eclipse-SDK-3.6-win32.zip), but I guess the test scripts still
refer to the original name.
-Andrew
Urs Frei wrote:
> Hello
> wrong name. I had to rename it from eclipse-SDK-3.6-win32.zip to
> to
> thanks
Re: Problem with "Automated Testing of Eclipse Build" [message #553303 is a reply to message #552571] Tue, 17 August 2010 02:01 Go to previous message
Bug 322869
"Andrew Niefer" <aniefer@ca.ibm.com> schrieb im Newsbeitrag
news:i415rm$dmo$2@build.eclipse.org...
Previous Topic:system bundle attaching
Next Topic:plugin installation monitoring
Current Time: Sun Jul 20 07:51:08 EDT 2025
Powered by FUDForum. Page generated in 0.04063 seconds
