Home » Eclipse Projects » Eclipse 4 » e4: Find a placeholder
e4: Find a placeholder [message #551984] Tue, 10 August 2010 08:12 Go to next message
I realise an e4 application divided in 2 parts:
- the main UI, configured whith an e4xmi file containing a placeholder in a Part Stack.
- a bundle with a view which must display a form in the placeholder.
(The main UI invoque the bundle using services.)
How can I find the declared placeholder in the bundle in order to place my view in the main UI? have you got a code exemple ?
Thanks.
Re: e4: Find a placeholder [message #551987 is a reply to message #551984] Tue, 10 August 2010 08:23 Go to previous messageGo to next message
Am 10.08.10 14:12, schrieb Valoueee:
> Hello,
> in a Part Stack.
I'm not sure I understand about which placeholder you are talking
because the Placeholder-Element is a very special type so that we can
share UI-Subtrees. I don't think that's what you are after, right?
If you are NOT sharing Subtrees between different areas you DON'T need
placeholders but contribute an MPart to the parent-container.
The ID you need to contribute is found in the elementId of the parent.
In my RCP-Tutorial [1] I show how to contribute elements from other
bundles through the so called fragment.e4xmi.
Tom
[1] http://tomsondev.bestsolution.at/2010/07/28/eclipse-4-0-and- tutorial-on-writing-e4-rcp-application-released/
Re: e4: Find a placeholder [message #552208 is a reply to message #551987] Wed, 11 August 2010 05:28 Go to previous messageGo to next message
Thank you very much. Your tutorial is very useful.
I need to share an area in order to edit some data depending node tree selected in the main GUI.
e.g: I have a tree with nodes representing cars and planes.
When I select a car, a form displays its specific features.
When I select a plane, another form displays its specific features too, but the form is different.
Your tutorial show how to open another indepedant view. How can I integrated my view in the main GUI ?
Re: e4: Find a placeholder [message #552214 is a reply to message #552208] Wed, 11 August 2010 05:54 Go to previous messageGo to next message
Well if the view should open dynamically you first have to define a
MPartDescriptor in your model and then you can use the EPartService to
show the view below any container (MPartStack,MPartSashContainer).
Tom
Am 11.08.10 11:28, schrieb Valoueee:
Re: e4: Find a placeholder [message #552222 is a reply to message #552214] Wed, 11 August 2010 06:20 Go to previous message
The SimpleIDE-Demo in CVS holds an example of a MPartDescriptor in
/cvsroot/eclipse/e4/org.eclipse.e4.ui/examples/org.eclipse.e 4.demo.simpleide.iconview.
The important thing to define which container should be used when an
MPart-instance is to be shown, is to set the "category"-attribute to the
id of the container. Afterwards all you need to do is to call:
-------8<-------
EPartService s ....
s.showPart("element.id.of.the.descriptor",PartState.ACTIVATE);
-------8<-------
Am 11.08.10 11:54, schrieb Tom Schindl:
> Tom
Re: e4: Find a placeholder [message #580527 is a reply to message #551987] Wed, 11 August 2010 05:28 Go to previous message
Re: e4: Find a placeholder [message #580537 is a reply to message #580527] Wed, 11 August 2010 05:54 Go to previous message
Tom
Re: e4: Find a placeholder [message #580556 is a reply to message #552214] Wed, 11 August 2010 06:20 Go to previous message
-------8<-------
EPartService s ....
-------8<-------
> Tom
Previous Topic:MPart vs. MPartDescriptor
Next Topic:Where's the best place to start with e4?
Current Time: Sat Jul 19 21:16:51 EDT 2025
Powered by FUDForum. Page generated in 0.12926 seconds
