Home » Modeling » GMF (Graphical Modeling Framework) » Hide an attribute
Hide an attribute [message #551548] Fri, 06 August 2010 18:54 Go to next message
I have the following problem I need to resolve:
I have an EClass myclass with a few Eattributes attA, attB, attC
each time I change the attribute then save the information is written to an XML file.
<myClass>
attA="dd" attB="dd" attC="p"
</myClass>
So the GMF engine is doing the writing to the XML file using introspection
so it will check if attA isSet then it will put it inside the xml file otherwise no and same thing for other attributes
I have a situation where I need not to put attA even if it is set. in other words I need to override the behavior of GMF engine for this attribute.
Is there a way to do that?
Re: Hide an attribute [message #551963 is a reply to message #551548] Tue, 10 August 2010 06:13 Go to previous messageGo to next message
if I understand well, you can use Transient attribute. It will not be serialized.
Re: Hide an attribute [message #552358 is a reply to message #551963] Wed, 11 August 2010 17:27 Go to previous message
The problem is that I want it to display in the propertySheet of the item and not in the XML File.
Using transient just remove it from both if I close and reopen the editor.
Previous Topic:Shared Editing Domain, Drag and Drop from Explorer, multiple Diagrams
Next Topic:How to save both model and diagram in the same file from "File - Save as" menu
Current Time: Sat Jul 19 16:02:25 EDT 2025
Powered by FUDForum. Page generated in 0.03899 seconds
