Home » Language IDEs » ServerTools (WTP) » Problem with .jspf and validation
Problem with .jspf and validation [message #550761] Wed, 04 August 2010 05:24 Go to next message
I have an old JSP project which I recently started to work on with Helios.
In it there are some .jsp file, and some included .jspf files.
I was used to having errors flagged against the .jspf files, but with Helios
I thought these would go away.
The .jsp files when validated (including the .jspf files of course) are
clear of errors.
In the preferences I have checked that .jspf is marked as a fragment, but
the validation logic still seems to put in error markers on them.
I am not sure if these are old markers which have simply not gone away, or
new markers that are still being generated.
Any ideas on how to get rid of these errors?
David
Re: Problem with .jspf and validation [message #551242 is a reply to message #550761] Thu, 05 August 2010 13:18 Go to previous messageGo to next message
Hi David,
What kind of errors are you seeing in the .jspf files?
It might be helpful to know that jspf files are generally not aware of the context that they may be used in. So if it references a variable that is declared in a JSP you know the fragment will be included in, the fragment is unaware of this and will generate problems from that.
[Updated on: Thu, 05 August 2010 13:20] by Moderator
Re: Problem with .jspf and validation [message #551265 is a reply to message #551242] Thu, 05 August 2010 14:14 Go to previous messageGo to next message
Nick Sandonato wrote:
> Hi David,
There are two errors, each repeated:-
The function fn:substring is undefined Tail.jspf
/project/WebContent/WEB-INF/jsp line 14 JSP Problem
and
Type mismatch: cannot convert from boolean to String Head.jspf
/project/WebContent/WEB-INF/jsp line 95 JSP Problem
(Sorry that has wrapped rather badly).
Wherever they are used they work properly. In the first case it is accurate
to say that fn:substring is not defined in this file, as it happens it is
defined in the second file. In the second case when it compiles properly
it works, so I guess it is because it is undefined.
But I thought the point of the validation and the fragment files was that
only complete files (with their includes) should be checked, and the
fragments left along.
David
Re: Problem with .jspf and validation [message #552260 is a reply to message #551265] Wed, 11 August 2010 09:18 Go to previous message
This particular problem should be cleared up by https://bugs.eclipse.org/317062
Do you have the preference unchecked for "Validate JSP fragments"? This is under Window > Preferences and then under Web > JSP Files > Validation. Once this option is disabled, doing a full validation should remove the problems.
Previous Topic:How to edit HTML templates
Next Topic:unable to use Clay Mark II plugin on Galineo
Current Time: Sun Jul 20 09:12:14 EDT 2025
Powered by FUDForum. Page generated in 0.03777 seconds
