Other thing about GMF and MOFSCRIPT [message #550936] |
Wed, 04 August 2010 12:18 |
I need an example where a relational model to generate SQL code, I would like some step by step, because in most jobs that meeting, the transformations are skipped and that is where I have problems. Ie from the creation of a project in Eclipse and as a step by step after designing my metamodel, model, and finally write the code of my transformation. In obtaining this result is enough for me. If you have any link you can give me?, If I can at least try a small example, because what I have to do is actually generate SQL code from an OLAP or ROLAP metamodel and I find even more complicated still. If anyone has worked with something related to this please I hope your answer. Thanks
FUDForum. Page generated in 0.43153 seconds
