Home » Archived » Buckminster » How to configure release builds with precompiled components
How to configure release builds with precompiled components [message #550804] |
Wed, 04 August 2010 07:55  |
I'm trying to set up our product builds for nightly, maintenance,
integration and release builds.
Suppose I have two components, say A and B, and B depends on A. I have
set up nightly builds and release builds for A and I can get the results
in form of p2 repositories. Something like
- nightly/A/lastSuccessful/site.p2
- releases/A/R20100433/site.p2
Now, I want to build B. For B I need some source code which is available
from a source code repository via a PDE map file. But B also needs A as
a dependency and I have set up my rmap for B to get A from
nightly/A/lastSuccessful/site.p2. This works very well.
So here comes the difficult part (for me, anyway): How do I describe and
build a named release of B? The first step is to fix the source code for
B which is easy using the PDE map. But how do I specify the version of
A? I can think of many ways:
1. Let the rmap of B be one of the source projects that are fetched via
the map file. And in the map file encode the version of A explicitely,
like releases/A/R20100433/site.p2.
2. PDE map files can also reference p2 sites. Theoretically I could
enter the specific site for A into the map file. But I don't know how to
redirect to this within the rmap.
3. Use explicit versions in one of the features that actually pulls A
and use a composite repository for A's releases so that p2 can get the
right version. This seems to be difficult because one would have to
change versions of the included features a lot.
What's the "best" way to proceed here? Any hints or pointers are greatly
appreciated.
Peter
Re: How to configure release builds with precompiled components [message #550860 is a reply to message #550804] |
Wed, 04 August 2010 09:23   |
You can do this by:
- having a property that denotes "buildtype" (i.e. something like
'release', 'milestone' 'nightly' etc.) and use this to provide routing
in the RMAP.
- This property should have a default (say 'release') in the RMAP
- Use advisor nodes in the CQUERY to set "buildtype" per component (i.e.
on components where you do not want the default).
This gives you the ability to fully control (in a symbolic fashion) the
location from which each component is resolved.
A scheme like "build from release, fallback to milestone or nightly as
required" is then easily supported. If you want ability to 'cherry-pick'
you need to use the identity of the release/nightly instead of a simple
symbolic name. With a policy on how p2 repositories are
named/structured, it should not be all that difficult (without a
structure and naming policy you end up with a list of every possible
repo in your RMAP which is not very good).
I hope that helps. Fire away with questions if something is unclear....
- henrik
On 8/4/10 1:55 PM, Peter Kullmann wrote:
> appreciated.
> Regards
> Peter
Re: How to configure release builds with precompiled components [message #550861 is a reply to message #550860] |
Wed, 04 August 2010 10:04   |
Hi Henrik,
Thanks for the advice.
I think I want to be able to 'cherry-pick' as you call it. For my
understanding of a named release, every part of the product should be
explicitly identified (as is the case with a bom produced by
buckminster). So, given the name of the release, there must be a way to
identify the exact version of the source code (easy via PDE maps) and to
identify the version of the (binary) pre-requisite(s). I don't see how a
naming policy can help in this case.
For example release XYZ consists of source code for the component B with
tag R_XYZ and of version 1.7.2.R207 of component A. The choice of
1.7.2.R207 may be deliberate, it doesn't necessarily mean that it was
the latest release or the latest in the branch or something like that.
So, I need a place to write this down. But where?
You mention advisor nodes in CQUERYs. This brings me to an idea: One
could use a versioned CQUERY, for instance in the same releng project
where the map file for the source code of B resides, and encode the
exact version of A in an advisor node. This information could then be
translated into a p2 repo URL.
Peter
Henrik Lindberg schrieb:
> You can do this by:
> in the RMAP.
> Regards
> - henrik
>> Hi,
>> appreciated.
>> Regards
>> Peter
Re: How to configure release builds with precompiled components [message #551140 is a reply to message #550861] |
Thu, 05 August 2010 08:03  |
A naming policy only helps by not having to list every possible repo.
You probably want the possibility to state "give me A of the version
published in latest milestone/release/nightly" as well as being able to
pick a specific version of A when so required.
The query is the place to state this (and do check it in).
The RMAP should be written to support getting everything required by the
queries. When there is a good naming policy one rarely has to touch the
RMAP.
Did that make it clearer?
- henrik
Peter Kullmann <p.kullmann@arenae.ch> wrote:
> Hi Henrik,
> to identify the exact version of the source code (easy via PDE maps)
> and to identify the version of the (binary) pre-requisite(s). I don't
> see how a naming policy can help in this case.
> with tag R_XYZ and of version 1.7.2.R207 of component A. The choice of
> Regards,
> Peter
>> You can do this by:
>> - having a property that denotes "buildtype" (i.e. something like >
> > routing > in the RMAP.
> > (i.e. > on components where you do not want the default).
> > > the > location from which each component is resolved.
> > > as > required" is then easily supported. If you want ability to
> > > 'cherry-pick' > you need to use the identity of the
> > > release/nightly instead of a simple > symbolic name. With a policy
> > > on how p2 repositories are > named/structured, it should not be
> > > all that difficult (without a > structure and naming policy you
> > > end up with a list of every possible > repo in your RMAP which is
> > > not very good).
> > > unclear....
>>> Regards
>> - henrik
>>> Hi,
> > > have
> > > results
> > > available
> > > as
> > > and
> > > for
> > > of
> > > via
> > > explicitely,
> > > how to
> > > A
> > > the
> > > greatly
>>> appreciated.
>>> Regards
>>> Peter
- henrik
Current Time: Sun Jul 20 11:46:18 EDT 2025
Powered by FUDForum. Page generated in 0.06506 seconds
