BPEL and Rest [message #507200] |
Tue, 12 January 2010 08:34  |
someone knows if is possible to use rest services directly into the bpel designer?
there's example or smt like that?
thanks
Re: BPEL and Rest [message #556186 is a reply to message #556142] |
Tue, 31 August 2010 04:50   |
grid.qian wrote on Tue, 31 August 2010 00:28 | Yes, for now, we have a plan to revive this project.
Do you have any requirements or something else?
yeah, well, if the modification made via UI will be applied to the code will be great
sometime happens when something is modified from the UI that in the code nothing happens. so the user need to change by hand the code. there are some problems also in the remove of component. not all the code is always right removed.
also the way that it creates the variable for the message could be redone, sometime it reuse variable already existing (ok, are the same type) without checking if the variable are used for something else.
but i stop to use the editor a couple of months ago so i don't remember all the issues.
PS: taking a look to the editor of Netbeans, that one is more intuitive, particularly in the way how they display the partnerLinks and the links.
PPS: probably will be great creating a thread or smt similar where the people can ask or share idea for the new release.
Re: BPEL and Rest [message #556287 is a reply to message #556186] |
Tue, 31 August 2010 11:36  |
Hi Stefano,
Yes, we know about the synchronization issues between design and source view and that is one of the problems we'll be working on in the near future. Other things like undo/redo are also on the list of things to do.
There are already several bugs that have been fixed (probably) since the last time you used the editor, so it might be worth another look. If you have the time, I would sure appreciate it if you could grab the latest source, build it on eclipse 3.6 (grab the Helios J2EE distro) and report any new problems in bugzilla.
Thanks!
Bob
FUDForum. Page generated in 0.33412 seconds
