Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values.
[EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #550628] Tue, 03 August 2010 19:06 Go to next message
Hi all,
I'm trying to incorporate to my emfatic/ecore metamodel some
constrained datatypes. Unfortunately, I haven't found any clear
documentation about that matter. So, I have mixed things from one site
and another, and I finally found that some constrains can be added with
the @ExtendedMetadata annotation. So I have specified a Name datatype,
and I have written a regular expression in order to constraint the
strings that are candidates to be names. For me, a name has to start
with a letter or an underscore and can be followed by cero or more
characters (letters, digits or underscores). I have written the
following annotation associated to the datatype.
@ExtendedMetadata(name="isIdentifier",
baseType="http://www.eclipse.org/emf/2003/XMLType#string",
pattern="^[a-zA-Z_]([a-zA-Z_0-9])*$")
datatype Name: java.lang.String;
Oher kind of constraint I want to write is related to constraining the
values possible values of other datatype. In this case, I have used the
properties minInclusive and maxInclusive, because my PortNumber has to
be a number between 0 and 65534, both inclusive. Below, I have included
the corresponding annotation.
@ExtendedMetadata(name="PortNumber",
baseType="http://www.eclipse.org/emf/2003/XMLType#integer",
minInclusive="0",
maxInclusive="65534")
datatype PortNumber:java.lang.Integer;
The question is that although the editor I'm generating and the
Reflective EMF Editor seem to have into account the constraints, each
time I write a value for a typed PortNumber attribute or a typed Name
attribute, the value is erased, as if the value does not fulfill the
constraint. I have tested with different values for a typed PortNumber
attribute, such as 0, 1, 65534, 7000.
I also have tested a typed Name attribute, and I have introduced values
such as A, My_Name, ...
I don't know if there's something that I'm missing. I also would
appreciate some extra documentation about this ExtendedMetadata
annotations, what kind of regular expressions can be written in the
pattern section, what other kind of constrains can be specified with
this extendedMetadata annotations, and if there is some way of testing
the regular expressions before writing them in the annotations.
Thanks in advance,
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #550634 is a reply to message #550628] Tue, 03 August 2010 19:29 Go to previous messageGo to next message
--------------070809040408090904070702
To
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #550746 is a reply to message #550634] Wed, 04 August 2010 04:57 Go to previous messageGo to next message
Thanks, Ed
the book you have mentioned is the EMF book, isn't it?
El 04/08/2010 1:29, Ed Merks escribió:
> Toñi,
> Comments below.
> Toñi Reina Quintero wrote:
>> Hi all,
> The extended meta data annotations and how they correspond to XML
> schema's constraints are described in detail in the book in and in XML
> Schema to Ecore Mapping
> < http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
>> So, I have mixed things from one site and another, and I finally found
>> that some constrains can be added with the @ExtendedMetadata
>> annotation. So I have specified a Name datatype, and I have written a
>> regular expression in order to constraint the strings that are
>> candidates to be names. For me, a name has to start with a letter or
>> an underscore and can be followed by cero or more characters (letters,
>> digits or underscores). I have written the following annotation
> With EMF 2.6 it's possible to express constraints with OCL. Ed Willink
> wrote some nice documentation on the OCL pages...
>> the properties minInclusive and maxInclusive, because my PortNumber
>> has to be a number between 0 and 65534, both inclusive. Below, I have
>> included the corresponding annotation.
>> minInclusive="0",
> I'd expect such constraints to be checked only when you invoke Validate...
>> values such as A, My_Name, ...
>> pattern section,
> Ones the XML Schema allows.
>> what other kind of constrains can be specified with this
>> extendedMetadata annotations, and if there is some way of testing the
> See the document above. It all comes down to emulating what XML Schema
> supports.
>> Thanks in advance,
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #550866 is a reply to message #550746] Wed, 04 August 2010 09:51 Go to previous message
Toñi,
Yes, the second edition of the EMF book. Everyone should buy one so I
can retire while still relatively young. :-P
> Thanks, Ed
>> Toñi,
>> Comments below.
>>> Hi all,
>>> minInclusive="0",
>> Validate...
>>> pattern section,
>> supports.
>>> Thanks in advance,
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #623099 is a reply to message #550628] Tue, 03 August 2010 19:29 Go to previous message
To
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #623104 is a reply to message #550634] Wed, 04 August 2010 04:57 Go to previous message
Thanks, Ed
> Toñi,
> Comments below.
>> Hi all,
>> minInclusive="0",
>> pattern section,
> supports.
>> Thanks in advance,
Re: [EMFatic] Help with ExtendedAnnotations, Regular Expressions and constrained values. [message #623109 is a reply to message #550746] Wed, 04 August 2010 09:51 Go to previous message
Toñi,
> Thanks, Ed
>> Toñi,
>> Comments below.
>>> Hi all,
>>> minInclusive="0",
>> Validate...
>>> pattern section,
>> supports.
>>> Thanks in advance,
Previous Topic:[EEF] Label not shown on Widget AdvancedTableComposition
Next Topic:EMF diagram editor
Current Time: Sun Jul 20 17:55:06 EDT 2025
Powered by FUDForum. Page generated in 0.06758 seconds
