Home » Language IDEs » PHP Development Tools (PDT) » No completions available
No completions available [message #90380] Thu, 15 January 2009 05:34 Go to next message
Hi there,
i recently upgraded to the latest all-in-one package on my ubuntu
machine and on my windows machine at work.
on the windows machine i get a red "No completions available" as i type
strp [strg][space].
on ubuntu it works fine.
what am i missing here?
cheers
ivo
Re: No completions available [message #90615 is a reply to message #90380] Thu, 15 January 2009 13:12 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Make sure you're running with JDK 5 or 6, 64 or 32 bit as appropriate.
http://wiki.eclipse.org/IRC_FAQ#How_do_I_start_Eclipse.3F
ivo bathke wrote:
> Hi there,
> strp [strg][space].
> cheers
> ivo
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: No completions available [message #90676 is a reply to message #90380] Thu, 15 January 2009 20:24 Go to previous messageGo to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Code assist still seems to need a bit of polishing.
I have come across some situations when code assist doesn't work in some
situations. It could be that one of these situations applies to you. I
have raised a few bug reports about them.
There is something definitely iffy about code completion in this bug,
and this sounds like it could apply to you. Try typing in a few more
characters of something that you know should complete and see if it then
works:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260952
I've also raised another couple about code assist, although these are
more specific and may not apply:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260805
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260947
ivo bathke wrote:
> Hi there,
> strp [strg][space].
> cheers
> ivo
Re: No completions available [message #90957 is a reply to message #90615] Mon, 19 January 2009 05:00 Go to previous messageGo to next message
sorry, i'm runnin the latest JDK.
> ivo bathke wrote:
>> Hi there,
>> type strp [strg][space].
>> cheers
>> ivo
Re: No completions available [message #549908 is a reply to message #90380] Wed, 28 July 2010 08:40 Go to previous messageGo to next message
I have just upgraded from 3.5 to Helios 3.6 on Fedora 13 and now have this as well. There are no messages in any logs as far as I can see and I have changed the permossions on the eclipse install directory to +rw although I never needed to do this before, but it hasn't helped.
If I sign on as root, I don't have the same problem. I am thinking of installing in my home directory instead of /opt/.. but a shared install in /opt always worked before.
Re: No completions available [message #549909 is a reply to message #549908] Wed, 28 July 2010 08:44 Go to previous messageGo to next message
Installing eclipse in my home directory made no difference. Still no completions Sad
Re: No completions available [message #549955 is a reply to message #549909] Wed, 28 July 2010 10:44 Go to previous messageGo to next message
> completions :(
Do You have dynamic languages option turned on and set to 5.3?
Then is project built?
dmc
Re: No completions available - SOLVED [message #550073 is a reply to message #549955] Thu, 29 July 2010 00:35 Go to previous messageGo to next message
For some reason I just got a popup message saying I needed to reconfigure my Content Assist preferences.
I went to Windows/Preferences/Java/Editor/Content Assist/Advanced and pressed "Restore Defaults". All works now. For some reason the "Java Proposals" was unchecked. Smile
Re: No completions available - SOLVED [message #550194 is a reply to message #550073] Thu, 29 July 2010 09:52 Go to previous messageGo to next message
This worked for me. Somehow the Java proposals was turned off. In addition I also setup my JDK properly. Not sure if this would cause it to turn off since these options were working fine in 3.5.
Re: No completions available - SOLVED [message #647879 is a reply to message #550073] Mon, 10 January 2011 05:05 Go to previous message
It worked for me, Thak you Smile
Previous Topic:Which PHP IDE is the best in your Experience including Eclipse?
Next Topic:XDebug php website breakpoints not index page
Current Time: Sun Jul 20 07:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.04861 seconds
