Home » Eclipse Projects » Eclipse Platform » [eclipse plugin ] implement a class to handel a command (command that opens a new wizard dialog page )
[eclipse plugin ] implement a class to handel a command [message #549631] Tue, 27 July 2010 08:20 Go to next message
hello,
I've added a command on the menu when I right click with the mouse on a file .
What I want to do now is to control the action when I select the command from the menu .
In fact I need to open a new wizard dialog page that I will configure with SWT.designer
I created a new class for my handler but I don't know how to open a wizard dialog page from this class here is the code
public class Deliverhandler extends AbstractHandler {
        public Object execute(ExecutionEvent event) throws ExecutionException {
        return null;
thanks in advance for your help
Re: [eclipse plugin ] implement a class to handel a command [message #549920 is a reply to message #549631] Wed, 28 July 2010 09:08 Go to previous messageGo to next message
On 27.07.2010 14:20, emna.lamine@ensi-bourges.fr wrote:
> hello,
> file .
> from the menu .
> with SWT.designer I created a new class for my handler but I don't know
> */ return null;
It is not clear to me what your specific problem is. The following
jface snippet shows how to start a wizard
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/wizard/Snippet047WizardWithLongRunningOperation.java?view= markup
Within AbstractHandler.execute you can use from helper class HandlerUtil
the static method
Shell getActiveShell[Checked](ExecutionEvent event)
to get the necessary shell.
HTH & Greetings from Bremen,
Daniel Krügler
Re: [eclipse plugin ] implement a class to handel a command [message #550493 is a reply to message #549631] Fri, 30 July 2010 10:33 Go to previous message
hello !!
thanks so much for your answer it is exactly what I'm looking for
Very Happy
Previous Topic:FormText lacks a getter for the text
Next Topic:Unable to control editor tab size in 3.6
Current Time: Sat Jul 19 18:55:14 EDT 2025
Powered by FUDForum. Page generated in 0.03177 seconds
