Re: Generate toString() method based on EMF [message #549506 is a reply to message #549500] |
Mon, 26 July 2010 18:35   |
--------------050901020409030507050904
Lars,
There's the following method in the template, so if you're not seeing a
toString method in a particular class' Impl, it's because the class
doesn't generate any fields deemed suitable for use. Generally we try
to use only attribute values. You'd need to be very careful with
references because you might easily end up with infinite recursion...
<%if (!genClass.hasImplementedToStringGenOperation() && isImplementation
&& !genModel.isReflectiveDelegation() && !genModel.isDynamicDelegation()
&& !genClass.getToStringGenFeatures().isEmpty()) {%>
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
<%if (genModel.useClassOverrideAnnotation()) {%>
public String toString()
if (eIsProxy()) return super.toString();
StringBuffer result = new StringBuffer(super.toString());
<%{ boolean first = true;%>
<%for (GenFeature genFeature : genClass.getToStringGenFeatures()) {%>
<%if (first) { first = false;%>
result.append(" (<%=genFeature.getName()%>:
");<%=genModel.getNonNLS()%>
<%} else {%>
result.append(", <%=genFeature.getName()%>:
<%if (genFeature.isUnsettable() && !genFeature.isListType()) {%>
<%if (genModel.isVirtualDelegation() &&
!genFeature.isPrimitiveType()) {%>
if
(eVirtualIsSet(<%=genClass.getQualifiedFeatureID(genFeature)% ><%=positiveOffsetCorrection%>))
result.append(eVirtualGet(<%=genClass.getQualifiedFeatureID(genFeature)% ><%=positiveOffsetCorrection%>));
else result.append("<unset>");<%=genModel.getNonNLS()%>
<%} else {%>
<%if (genClass.isFlag(genFeature)) {%>
<%if (genFeature.isBooleanType()) {%>
if (<%if (genClass.isESetFlag(genFeature))
{%>(<%=genClass.getESetFlagsField(genFeature)%> &
<%=genFeature.getUpperName()%>_ESETFLAG) != 0<%} else
{%><%=genFeature.getUncapName()%>ESet<%}%>)
result.append((<%=genClass.getFlagsField(genFeature)%> &
<%=genFeature.getUpperName()%>_EFLAG) != 0); else
<%} else {%>
result.append(<%=genFeature.getUpperName()%>_EFLAG_VALUES[( <%=genClass.getFlagsField(genFeature)%>
& <%=genFeature.getUpperName()%>_EFLAG) >>>
<%=genFeature.getUpperName()%>_EFLAG_OFFSET]); else
<%} else {%>
result.append(<%=genFeature.getSafeName()%>); else
<%} else {%>
result.append(eVirtualGet(<%=genClass.getQualifiedFeatureID(genFeature)% ><%=positiveOffsetCorrection%><%if
(!genFeature.isListType() && !genFeature.isReferenceType()){%>,
<%=genFeature.getEDefault()%><%}%>));
<%} else {%>
<%} else {%>
<%} else {%>
result.append(')');
return result.toString();
Lars Vogel wrote:
> I have a model based on EMF and generate Java Code from it. Currently
> the generated code does not include a generated toString() method. Is
> it possible to generated one via EMF?
> Best regards, Lars
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Lars,<br>
<br>
references because you might easily end up with infinite recursion...<br>
<br>
<small><%if (!genClass.hasImplementedToStringGenOperation()
&& isImplementation &&
!genModel.isDynamicDelegation() &&
!genClass.getToStringGenFeatures().isEmpty()) {%><br>
/**<br>
* <!-- begin-user-doc --><br>
* <!-- end-user-doc --><br>
* @generated<br>
*/<br>
<%if (genModel.useClassOverrideAnnotation()) {%><br>
@Override<br>
<%}%><br>
public String toString()<br>
{<br>
if (eIsProxy()) return super.toString();<br>
<br>
StringBuffer result = new StringBuffer(super.toString());<br>
<%{ boolean first = true;%><br>
genClass.getToStringGenFeatures()) {%><br>
<%if (first) { first = false;%><br>
");<%=genModel.getNonNLS()%><br>
<%} else {%><br>
<%}%><br>
!genFeature.isListType()) {%><br>
!genFeature.isPrimitiveType()) {%><br>
if
(eVirtualIsSet(<%=genClass.getQualifiedFeatureID(genF eature)%><%=positiveOffsetCorrection%>) )
result.append(eVirtualGet(<%=genClass.getQualifiedFea tureID(genFeature)%><%=positiveOffsetCorrectio n%>));
else result.append("<unset>");<%=genModel.getNonNLS()%> <br>
<%} else {%><br>
<%if (genClass.isFlag(genFeature)) {%><br>
<%if (genFeature.isBooleanType()) {%><br>
{%>(<%=genClass.getESetFlagsField(genFeature)% > &
{%><%=genFeature.getUncapName()%>ESet&a mp;lt;%}%>)
result.append((<%=genClass.getFlagsField(genFeature)% > &
<%} else {%><br>
result.append(<%=genFeature.getUpperName()%>_E FLAG_VALUES[(<%=genClass.getFlagsField(genFeature)%&a mp;gt;
<%}%><br>
<%} else {%><br>
<%}%><br>
<%}%><br>
<%} else {%><br>
result.append(eVirtualGet(<%=genClass.getQualifiedFea tureID(genFeature)%><%=positiveOffsetCorrectio n%><%if
<%=genFeature.getEDefault()%><%}%&g t;)); <br>
<%} else {%><br>
& <%=genFeature.getUpperName()%>_EFLAG) != 0);<br>
<%} else {%><br>
<%=genFeature.getUpperName()%>_EFLAG_OFFSET]); <br>
<%}%><br>
<%} else {%><br>
result.append(<%=genFeature.getSafeName()%>);<br >
<%}%><br>
<%}%><br>
<%}%><br>
<%}%><br>
<%}%><br>
result.append(')');<br>
return result.toString();<br>
}<br>
<br>
<%}%></small><br>
<br>
<br>
Lars Vogel wrote:
<blockquote cite="mid:i2kuj7$dom$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
Best regards, Lars
<br>
<br>
</blockquote>
</body>
</html>
--------------050901020409030507050904--
Re: Generate toString() method based on EMF [message #550291 is a reply to message #549506] |
Thu, 29 July 2010 14:53  |
Thank you Ed for the answer.
Question is closed now.
On 27.07.2010 00:35, Ed Merks wrote:
> Lars,
> doesn't generate any fields deemed suitable for use. Generally we try to
> use only attribute values. You'd need to be very careful with references
> * @generated
> @Override
> result.append(" (<%=genFeature.getName()%>: ");<%=genModel.getNonNLS()%>
> <%} else {%>
> result.append(", <%=genFeature.getName()%>: ");<%=genModel.getNonNLS()%>
> <%if (genModel.isVirtualDelegation() && !genFeature.isPrimitiveType()) {%>
> if
> <%} else {%>
> <%} else {%>
> <%} else {%>
> <%} else {%>
> <%} else {%>
> <%} else {%>
> <%} else {%>
> result.append(')');
> Lars Vogel wrote:
>> Hi,
>> Best regards, Lars
FUDForum. Page generated in 0.14173 seconds
