Home » Eclipse Projects » Remote Application Platform (RAP) » 'null' is null or not an object
'null' is null or not an object [message #548979] Fri, 23 July 2010 11:17 Go to next message
We've developed a Rap 1.2.2 application. Periodically we get the following error message in the brower (IE 6.0SP2).
Could not evaluate javascript response:
Has anyone had this error before, if so, how did you resolve it.
Re: 'null' is null or not an object [message #549191 is a reply to message #548979] Sun, 25 July 2010 23:26 Go to previous messageGo to next message
Hi, Graham.
Probably this cause tomcat compression is enabled. Look here for details http://www.eclipse.org/rap/noteworthy/1.3/news_M2.php.
Yury.
[Updated on: Sun, 25 July 2010 23:27] by Moderator
Re: 'null' is null or not an object [message #549383 is a reply to message #548979] Mon, 26 July 2010 10:41 Go to previous messageGo to next message
Thanks for the response. Last week I tried disabling the compression. Our app is running with Jetty and not in Tomcat. We still had the same problem. The compression flag didn't help.
Re: 'null' is null or not an object [message #549834 is a reply to message #549383] Wed, 28 July 2010 04:02 Go to previous messageGo to next message
Graham,
this kind of error is difficult to track. Can you isolate the widget
that causes the error or can you provide a code snippet to reproduce?
Have you tried RAP 1.3, does the problem persist?
Can you provide the Javascript response that leads to this error?
Please file a bugzilla with further information.
HTH
Rüdiger
Re: 'null' is null or not an object [message #551848 is a reply to message #549834] Mon, 09 August 2010 14:00 Go to previous message
Thanks for the response. I'm currently trying to deploy to RAP 1.3 to see if the problem persists. It is very difficult to reproduce. I haven't been able as of yet. It seems to happen on very high load and only once out of every few thousand requests.
Graham
Previous Topic:RAP and GMF/EMF
Next Topic:Accessing a RAP application without a servlet name
Current Time: Sun Jul 20 10:34:41 EDT 2025
Powered by FUDForum. Page generated in 0.04182 seconds
