Re: Creating Maven projects [message #549854 is a reply to message #549157] |
Wed, 28 July 2010 04:51  |
From Eclipse with our Eclipse IAM plugin installed you can do
File - New - Project - Maven 2 Project - Maven 2 Project Creation Wizard
and then find a Wicket archetype to use to create a skeleton Wicket project.
Or from an existing Maven project, right click and select Maven 2 - Use
Maven dependency management
to enable Maven in the Eclipse IDE
On 7/25/10 9:49 PM, Kristian Sejersen wrote:
> Hey.
> I am currently trying to setup my Eclipse IDE for using Wicket, and thus
> i want to install Maven in order to make it work. Now from what i
> understand you need to have Maven in your given Dynamic Web Project in
> order to add the necesary information for Wicket.
> This brings my to what i expect to be a very trivial question. How do i
> add Maven to a given Dynamic web project ?? :blush:
> I have already installed the Maven2 plugin for Eclipse.
> I must admit i find the whole setup and installation a bit confusing and
> what i find on google is usually a bounch of command lines i need to run
> in a unix system, but unfortunately i am running windows.
> I am currently reading the "Wicket in action" book, which has a lot of
> nice examples i'd like to play around with in order to get a better
> understanding of Wicket.
> Best regards
> Kristian
FUDForum. Page generated in 0.03380 seconds
