Home » Eclipse Projects » Rich Client Platform (RCP) » why access to org.eclipse.ui.internal is discouraged?(RT)
why access to org.eclipse.ui.internal is discouraged? [message #549137] Sun, 25 July 2010 01:14 Go to next message
how to avoid such warning:
Access to referenced class 'org.eclipse.ui.internal.handlers.QuitHandler' in attribute 'defaultHandler' is discouraged
Re: why access to org.eclipse.ui.internal is discouraged? [message #549206 is a reply to message #549137] Mon, 26 July 2010 02:10 Go to previous messageGo to next message
It would probably help, if you would describe the context,
where this warning occurred. With the absence of such a
description I can only ask: Why do you refer to a type that
is an implementation detail of Eclipse and no official API?
Greetings from Bremen,
Daniel Krügler
Re: why access to org.eclipse.ui.internal is discouraged? [message #549207 is a reply to message #549137] Mon, 26 July 2010 02:21 Go to previous messageGo to next message
Don't use internal code as this can change at any time without notice.
Dani
Re: why access to org.eclipse.ui.internal is discouraged? [message #549309 is a reply to message #549137] Mon, 26 July 2010 08:39 Go to previous messageGo to next message
that's it ! in plugin.xml of a RCP project
I use it to create "File->Exit" menu Sad
what can i use instead of this QuitHandler?
I know I can do it in code, but I wanna if there is a safe way to add a "File->Exit" command extension in plugin.xml?
Re: why access to org.eclipse.ui.internal is discouraged? [message #549603 is a reply to message #549309] Tue, 27 July 2010 07:02 Go to previous message
haha~
stupid to create a command with defaultHandler point to a internal Handler.
Previous Topic:Discard last session state on a condition
Next Topic:RCP Application on AIX/Motif
Current Time: Sat Jul 19 21:01:17 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
