[ATL] Problem with UML property [message #548631] |
Thu, 22 July 2010 10:12  |
Hi there,
I tray anxiously to refractor an uml class diagram as follow:
- I have to ignore (remove) a property for 2 sub-classes
- I have to create a new property into the super-class.
For this I do the following implementation:
create OUT : UML refining IN : UML;
helper def: getClass(s:String) : UML!Class =
UML!Class.allInstances()-> select(c | c.name = s).first();
helper context UML!Class def: getProperties() : Sequence(UML!Property) =
if self.ownedAttribute.size() > 0 then
self.ownedAttribute -> select(p | p.name <> 'IDb' and p.name <>'IDc')-> asSequence()
else
Sequence{}
endif;
rule parent2parent {
from classS:UML!Class (classS.name = 'Person')
to classT:UML!Class
name <- classS.name,
ownedAttribute <- addNewProperty,
ownedAttribute <- classS.ownedAttribute,
ownedOperation <- classS.ownedOperation
addNewProperty: UML!Property
name <-'matricule',
type <- thisModule.getClass('Number')
rule childs2childs
from classS:UML!Class (classS.name <> 'Person')
to classT:UML!Class
ownedAttribute <- classS.getProperties()
The super-classe is ok, but the 2 properties in the sub-classes respectively are not ignored, I do not understand why, anyone could help me please, how we can do it?
With regards,
Bler
NB: You can write in French too.
Re: [ATL] Problem with UML property [message #548637 is a reply to message #548631] |
Thu, 22 July 2010 10:26   |
Le 22/07/2010 16:12, Bler a écrit :
> Hi there,
> asSequence()
> else
> Sequence{}
> endif;
> to classT:UML!Class (
> name <-'matricule',
> rule childs2childs {
> to classT:UML!Class
> ( name <- classS.name,
> With regards,
> Bler
I do not remember the details of UML but are you sure that
ownedAttribute contains what you expect it contains?? Could
ownedAttribute elements be link to a Property in place of a Property???
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
FUDForum. Page generated in 0.05669 seconds
