Home » Archived » M2M (model-to-model transformation) » Possibility to have several levels in an XMI File?
icon5.gif  Possibility to have several levels in an XMI File? [message #547629] Mon, 19 July 2010 04:12 Go to next message
Hello is it possible to have something like
sequenceFlow sourceRef="Sum < 10000 CHF" targetRef="Give positive feedback">
				<conditionExpression>Request accepted</conditionExpression>
			</sequenceFlow>
Until now, I was just able to handle something like:
<sequenceFlow sourceRef="Sum &lt; 10000 CHF" targetRef="Give positive feedback"/>
I need this two levels, please could you help me? Thanks and cheers
Roger
Re: Possibility to have several levels in an XMI File? [message #547638 is a reply to message #547629] Mon, 19 July 2010 04:42 Go to previous messageGo to next message
> feedback">
> </sequenceFlow>
> <sequenceFlow sourceRef="Sum < 10000 CHF" targetRef="Give positive
> feedback"/>
> Roger
Indicate in your metamodel that for a SequenceFlow, conditions are
"contained". So EMF will store conditions into corresponding SeqFlow...
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Possibility to have several levels in an XMI File? [message #547682 is a reply to message #547638] Mon, 19 July 2010 07:03 Go to previous messageGo to next message
Thanks for your answer!
Can you explain that a bit more detailed, I do not understand what you exactly mean?
Thanks and cheers
Roger
Re: Possibility to have several levels in an XMI File? [message #547691 is a reply to message #547638] Mon, 19 July 2010 07:10 Go to previous messageGo to next message
>> feedback">
>> </sequenceFlow>
>> feedback"/>
>> Roger
The structure of your model s managed by EMF which itself relies on the
metamodel syntax.
If you want a type (like SequenceFlow) to hold an underlying type (like
Expression) through a reference (as your conditionExpression), you must
declare it in the metamodel (that is set ON the containment value of the
reference):
Class SequenceFlow
reference conditionExpression
containment = true
eType = Expression
Cordialement
Vincent MAHÉ
Re: Possibility to have several levels in an XMI File? [message #548197 is a reply to message #547691] Wed, 21 July 2010 00:54 Go to previous messageGo to next message
Hello Vincent
I checkde the settings and they are really like you described. How can I then call this in a transformation rule, do I need a "lazy rule"?
Because I need 4 classes (ControlFlow --> Sequence Flow and Event --> ConditionExpression) and in a rule I can just have two classes, right?
Thanks and cheers
Roger
Re: Possibility to have several levels in an XMI File? [message #548231 is a reply to message #547629] Wed, 21 July 2010 04:03 Go to previous messageGo to next message
In a rule you can have as many output elements as you want (1 or more though)
Re: Possibility to have several levels in an XMI File? [message #548384 is a reply to message #547629] Wed, 21 July 2010 12:05 Go to previous messageGo to next message
Ok, how can I do that then? I have the following rule:
rule Flow {
from
	e : EPK!ControlFlow (not e.isConditionExpression())
to
	b : BPMN!SequenceFlow or Expression
	 	id <- e.id,
	 	name <- e.name,
	 	sourceRef <- e.source,
	 	targetRef <- e.target
Thanks and cheers Roger
Re: Possibility to have several levels in an XMI File? [message #548386 is a reply to message #547629] Wed, 21 July 2010 12:07 Go to previous messageGo to next message
Erm no, what are you trying to achieve ?
Re: Possibility to have several levels in an XMI File? [message #548389 is a reply to message #548386] Wed, 21 July 2010 12:13 Go to previous messageGo to next message
sequenceFlow sourceRef="Sum &lt; 10000 CHF" targetRef="Give positive feedback">
			</sequenceFlow>
I set now the correct settings on the metamodel, but now how can I call the second class <conditionExpression>?
Cheers Roger
Re: Possibility to have several levels in an XMI File? [message #548394 is a reply to message #547629] Wed, 21 July 2010 12:41 Go to previous messageGo to next message
to
b : BPMN!SequenceFlow(
bindings...
c : BPMN!Expression (
bindings...
Of course you can use b in the bindings of c or c in the bindings of b to make the link between the two if needed
Re: Possibility to have several levels in an XMI File? [message #548436 is a reply to message #547629] Wed, 21 July 2010 16:23 Go to previous messageGo to next message
Thanks this worked pretty fine. Smile My next issue is to call a helper within the bindings and then to give the name back to the rule. The problem is I don't know how to call a helper inside an rule and to overgive the helper some values (variables) and to get also some back...Is this possible?
My rule looks:
-- Rule 13 / 11a with conditionalExpression
rule ConditionExpression {
from
e : EPK!ControlFlow (e.isConditionExpression())
to
name <- e.name
con : BPMN!ConditionExpression(
name <- thisModule.getConditionName( overgive id, take back name)
My helper looks:
--Make two level - Rule 13 with conditionalExpression
helper context EPK!ControlFlow def: getConditionName(take id, give back name ) : Sequence(String) =
EPK!Event.allInstances()-> select(e | e.target=self.id)->collect(e | e.name);
Thank you very much that you looking at it....I am really close to my target, if this works. Smile
Cheers Roger
[Updated on: Thu, 22 July 2010 05:10] by Moderator
Re: Possibility to have several levels in an XMI File? [message #548485 is a reply to message #548436] Thu, 22 July 2010 02:20 Go to previous messageGo to next message
Le 21/07/2010 22:23, Roger80 a écrit :
> Thanks this worked pretty fine. :) My next issue is to call a helper
> My rule looks:
> from
> e : EPK!ControlFlow (e.isConditionExpression()) -- and
> he.isConditionExpressionEvent() and not e.isStarter() and
> e.isNotEventEndEvent())
> to
> b : BPMN!SequenceFlow (
> name <- e.name,
conditionExpression <- c
> --name <-
> My helper looks:
> e.name);
> target, if this works. :)
> Cheers Roger
Cordialement
Vincent MAHÉ
Re: Possibility to have several levels in an XMI File? [message #548516 is a reply to message #548485] Thu, 22 July 2010 04:54 Go to previous messageGo to next message
Hello Vincent
What do you mean with?
What is this c for?
I want to call a helper inside a rule and overgive some values and get back some values as you can see it above (fat) signed.
[Updated on: Thu, 22 July 2010 05:03] by Moderator
Re: Possibility to have several levels in an XMI File? [message #548543 is a reply to message #548516] Thu, 22 July 2010 05:41 Go to previous message
Le 22/07/2010 10:54, Roger80 a écrit :
> Hello Vincent
> What is this c for?
Sorry! It is :
conditionExpression <- con
(you have to include the condition into the sequece flow)
Cordialement
Vincent MAHÉ
Previous Topic:[ATL] inverse function of refImmediateComposite()
Next Topic:[ATL] Problem with UML property
Current Time: Sun Jul 20 01:52:47 EDT 2025
Powered by FUDForum. Page generated in 0.07154 seconds
