Home » Eclipse Projects » JFace » Is it possible to sort a TableViewer without refreshing the model?
Is it possible to sort a TableViewer without refreshing the model? [message #548314] Wed, 21 July 2010 09:00 Go to next message
I've tried to do this in my ViewerComparator subclass:
public void resort() {
    viewer.setComparator(null);
    viewer.setComparator(this);
but this calls getElements twice (and simply
doesn't trigger resorting, if `this` is already the comparator).
Is there a way to resort elements without getElements being called?
[Updated on: Wed, 21 July 2010 09:01] by Moderator
Re: Is it possible to sort a TableViewer without refreshing the model? [message #555920 is a reply to message #548314] Mon, 30 August 2010 04:56 Go to previous messageGo to next message
I've been struggeling the same problem, and I can't find a way to re-sort without calling getElements(). However, I managed to minimize the number of calls to getElements() by re-sorting only when necessary.
public final static String SORTER_PROPERTY = "sorterProperty";
tableViewer.setComparator(new ViewerSorter() {
    public int compare(Viewer viewer, Object e1, Object e2) {
    public boolean isSorterProperty(Object element, String property) {
        return SORTER_PROPERTY.equals(property);
// Update a specific element and trigger re-sorting.
tableViewer.update(element, new String[] { SORTER_PROPERTY });
// Same thing but without re-sorting.
tableViewer.update(element, null);
With reservations for errors... I typed the code, no copy/paste...
Cheers
Re: Is it possible to sort a TableViewer without refreshing the model? [message #556037 is a reply to message #548314] Mon, 30 August 2010 11:58 Go to previous message
I ended up just caching the elements array in my class (so getElements() is trivial and it doesn't matter how many times it's called) and updating it manually. It won't work in all cases, but it does in mine.
Previous Topic:TreeViewer PendingUpdateAdapter Refresh Problem
Next Topic:ComboViewer doesn't support images?
Current Time: Sat Jul 19 18:43:04 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
