Home » Modeling » EMF » Question about notification
icon3.gif  Question about notification [message #548068] Tue, 20 July 2010 11:04 Go to next message
I'd like to modifiy the model when the user change it: for example when the user link two classes with generalization, all the ports of supertclass must be copied in subclass.
I know how to catch the events fired from model changes but I don't know how to modify the model from the Notification.
How can i do that? Is there any code tutorial I can follow?
Thanks in advance, star123
Re: Question about notification [message #548083 is a reply to message #548068] Tue, 20 July 2010 11:30 Go to previous message
Hi, star123,
If your application uses a GMF-based diagram editor, then it already
employs a TransactionalEditingDomain. This gives you a "trigger" API
with which you can react to changes in the model to follow up with
additional edits such as copying the ports.
There is a tutorial and other documentation in the "EMF Model
Transaction Developer Guide" in the on-line help. This is assuming, of
course, that you have installed the EMF Model Transaction SDK.
Otherwise, find it here:
http://help.eclipse.org/
HTH,
Christian
On 20/07/10 11:04 AM, 123star wrote:
Previous Topic:How to generate an ecore from XSD without Type being appended
Next Topic:Emf.Edit: Deletion of a linkage instead of the linked element itself
Current Time: Sat Jul 19 11:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.12913 seconds
