Home » Archived » M2M (model-to-model transformation) » Transformation between UML Profiles(Is it possible to create transformations between UML profiles.)
icon9.gif  Transformation between UML Profiles [message #547922] Tue, 20 July 2010 04:09 Go to next message
Hi, I have been trying to find a way to create transformation between two UML profiles (models defined in these two profiles) that I have created in Eclipse Modeling Framework. I tried with ATL and QVT, but it seems that these two transformation languages are only able to execute transformations between models for which their metamodels are defined in ecore. That's OK and I understand that this is because ATL and QVT are implemented as metamodels in ecore. However, if I try to make transformations between UML profiles, both these transformations aren't working. Since UML and UML profiles are defined in ecore metamodel I thought that this could be possible.
So my question is: Can I use ATL, QVT or some other transformation language to make transformations between UML profiles (that is models defined in my own UML profiles in eclipse)?
Any help will be so gratefully appreciated!
Re: Transformation between UML Profiles [message #548048 is a reply to message #547922] Tue, 20 July 2010 10:14 Go to previous messageGo to next message
Moving this to the EMF M2M forum group.
Re: Transformation between UML Profiles [message #548155 is a reply to message #548048] Tue, 20 July 2010 16:20 Go to previous message
No Message Body
[Updated on: Tue, 20 July 2010 16:22] by Moderator
Previous Topic:[ATL] A strange console-Message by launching ATL-transformatiom
Next Topic:[QVTo] Access EMF model enum value
Current Time: Sat Jul 19 11:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.24456 seconds
