[QVTo] Return from mapping [message #547523] |
Sun, 18 July 2010 03:54  |
I'm trying to emulate the second example of 8.1.10 in the QVT spec:
mapping Class::jclass2jpackage() : JPackage () {
init {
result := resolveIn(jclass2jpackage,true)
->select(p|self.package=p.name)->first();
if result then return;
name := self.package;
which is clearly rather fanciful since
- the if expression is not an expression,
- the endif is missing
- package is a reserved word.
When corrected to
if result->notEmpty() then return endif;
I get a syntax error for a missing return argument although the EBNF
shows it to be optional. When changed to
if result->notEmpty() then return result endif;
I get 'Using "return" from mapping operation is not yet supported'.
Is there a recommended way to perform a premature mapping exit?
Ed Willink
Re: [QVTo] Return from mapping [message #547798 is a reply to message #547744] |
Mon, 19 July 2010 12:00  |
Hi Sergey
I've raised an OMG issue for the poor example.
I managed to workaround it by doing all the work in init:
init {
if result->isEmpty() then
result := object JPackage {
endif
There seem to be a fair few areas where QVTo could warn about meta-model
multiplicity impossibilities. I'm not sure how many of these are
actually MDT/OCL's fault.
Ed
On 19/07/2010 15:10, Sergey Boyko wrote:
> Hi Ed,
> There's no explicit substitution for the case. However there are some
> possible workarounds:
> 1. While it's prohibited by spec to create objects in helpers QVTo
> allows that:
> helper Class::jclass2jpackage_helper() : Package {
> var s := resolveIn(Class::jclass2jpackage, Package | true)
> ->select(p|self.package.name=p.name)->first();
> if s <> null then return s endif;
> return self.map jclass2jpackage();
> mapping Class::jclass2jpackage() : Package {
> name := self.package.name;
> 2. Better way is to redesign the mapping so that single return behavior
> is used (for given parameters tuple the out parameters are populated
> using the corresponding trace):
> mapping String::jclass2jpackage() : Package {
> main() {
> var s := OrderedSet{
> object Class{name := 'a'},
> object Class{name := 'b'},
> object Class{name := 'a'} };
> var s1 := s->collect(i|i.name.map jclass2jpackage());
> Regards,
> Sergey.
> Ed Willink wrote:
>> Hi
>> init {
>> When corrected to
>> Regards
>> Ed Willink
FUDForum. Page generated in 0.06809 seconds
