Home » Modeling » Epsilon » [Epsilon] Revisiting problems with examples.friends.
[Epsilon] Revisiting problems with examples.friends. [message #547484] Sat, 17 July 2010 10:45 Go to next message
--------------060104040501060701040809
Hi all,
I'm testing the friends example (in order to see how to incorporate
images to figures), and I have the same problem reported in the
conversation whose link is the following one:
http://www.eclipse.org/forums/index.php?t=msg&goto=51471 9&#msg_514719
That is, when I try to create a person, the editor does not draw it and
shows a pop-up saying that there has been an error.
I tried to follow the steps explained here:
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-node s-with-images/
After reading the thread about the friends example, I have realized
that the example is available for downloading at:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.friends
The main difference with my test is that I haven't created a new
project for figures, but I have written two new packages in the
friends.diagram project containing the corresponding PluginActivator and
PersonFigure classes. Finally, I also have created a folder named images
containing the Person.png image file (I have attached a screenshot of
the friends.diagram project structure).
As far as I understood from the thread I have included previously,
problems were due to plugin dependencies, as friends.figure had been
defined in other project. The point is that I don't have two projects,
and problems seen to appear when loading images. Is there something that
I miss?
P.D.: I know that the two projects option is a better solution, but
I'm curious about what I'm doing wrong.
Thanks in advance,
To
Re: [Epsilon] Revisiting problems with examples.friends. [message #547553 is a reply to message #547484] Sun, 18 July 2010 14:41 Go to previous messageGo to next message
Hi Toni,
Could you please zip and send me your code at dskolovos gmail com so
that I can have a look?
Dimitris
On 17/07/2010 15:45, Toñi Reina Quintero wrote:
> Hi all,
> After reading the thread about the friends example, I have realized that
> The main difference with my test is that I haven't created a new project
> for figures, but I have written two new packages in the friends.diagram
> project containing the corresponding PluginActivator and PersonFigure
> classes. Finally, I also have created a folder named images containing
> the Person.png image file (I have attached a screenshot of the
> I miss?
> P.D.: I know that the two projects option is a better solution, but I'm
> Thanks in advance,
> Toñi
Re: [Epsilon] Revisiting problems with examples.friends. [message #547565 is a reply to message #547553] Sun, 18 July 2010 16:51 Go to previous message
Sure, thx.
El 18/07/2010 20:41, Dimitris Kolovos escribió:
> Hi Toni,
> Cheers,
> Dimitris
>> Hi all,
>> I miss?
>> Thanks in advance,
>> Toñi
Re: [Epsilon] Revisiting problems with examples.friends. [message #590763 is a reply to message #547484] Sun, 18 July 2010 14:41 Go to previous message
Hi Toni,
Dimitris
> Hi all,
> I miss?
> Thanks in advance,
> Toñi
Re: [Epsilon] Revisiting problems with examples.friends. [message #590769 is a reply to message #547553] Sun, 18 July 2010 16:51 Go to previous message
Sure, thx.
> Hi Toni,
> Cheers,
> Dimitris
>> Hi all,
>> I miss?
>> Thanks in advance,
>> Toñi
Previous Topic:[Eugenia] Problem generating the Diagram.
Next Topic:[Eugenia] Package references in generated models
Current Time: Sat Jul 19 15:56:13 EDT 2025
Powered by FUDForum. Page generated in 0.05268 seconds
