Home » Archived » M2M (model-to-model transformation) » [ATL] EEnum to EClass
[ATL] EEnum to EClass [message #546793] Wed, 14 July 2010 05:00 Go to next message
I need to transform a class X with an EEnum attribute called Y of value "B" into the next model where class X will have a reference to EClass Y that has a String description attribute with the value "B".
And all other class X transformations that point to the same EEnum will also have to reference that same new EClass Y when transformed.
In otherwords EEnum Y needs to be transformed into EClass Y and all the objects that were referencing this enumeration value will now have a reference to this newly created EClass Y.
Can somebody please help me with how I would go about constructing these rules? I don't want to create a new instance of EClass with a value "B" everytime I find the value, so I probably need some way of pre-transforming all the enumeration values into instances of EClass Y before hand and then somehow find a reference to them during transformation of class X?
Re: [ATL] EEnum to EClass [message #547393 is a reply to message #546793] Fri, 16 July 2010 11:07 Go to previous messageGo to next message
--------------010902090805020901030107
Dear Izaak,
I don't really understand well your problem. Could you please give us
more details (e.g. about your metamodels)?
Freddy.
name="freddy_allilaire.vcf"
filename="freddy_allilaire.vcf"
YmVnaW46dmNhcmQNCmZuOkZyZWRkeSBBbGxpbGFpcmUNCm46QWxsaWxhaXJl O0ZyZWRkeQ0K
b3JnOk9CRU8NCmFkcjtxdW90ZWQtcHJpbnRhYmxlOjs7NyBCb3VsZXZhcmQg QW1wPUMzPUE4
cmU7Q0FSUVVFRk9VOzs0NCA0ODE7RnJhbmNlDQplbWFpbDtpbnRlcm5ldDpm cmVkZHkuYWxs
aWxhaXJlQG9iZW8uZnINCnVybDp3d3cub2Jlby5mcg0KdmVyc2lvbjoyLjEN CmVuZDp2Y2Fy
ZA0KDQo=
--------------010902090805020901030107--
Re: [ATL] EEnum to EClass [message #547402 is a reply to message #546793] Fri, 16 July 2010 11:50 Go to previous messageGo to next message
You have to generate the B instance for the enum in a "unique called
rule" which parameter is the enum value. Doing so, each you encounter a
given value of this enum, ATL will return the same B corresponding instance.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] EEnum to EClass [message #547406 is a reply to message #547402] Fri, 16 July 2010 12:14 Go to previous messageGo to next message
Hi Vincent,
Would this rule also create one instance of "B" then so that it can be referenced every time "B" is encountered?
@Freddy
> Could you please give us more details (e.g. about your
> metamodels)?
Version 1:
Class "RoleSpec" has a feature "conformanceType" that is of type "RoleSpecTypeExplorer".
"RoleSpecTypeExplorer" is an Enumrator with values:
Party = 0, Account = 1, Place=2, Agreement=3
Version 2:
Class "RoleSpec" has a feature "conformanceType" that is of type "Type".
"Type" is a class with a feature "name" of type String.
So when Version1 is transformed to Version2, RoleSpec's feature comformanceType must be transformed from an enumeration to a class, and an instance of Type must be created with name set to "Party" or "Account" or "Place" etc.
One instance of each enumeration must be created and every RoleSpec that for instance have a conformanceType with enumeration value of "Party" must reference that same instance of Type with name "Party".
Hope this is more clear?
[Updated on: Fri, 16 July 2010 15:28] by Moderator
Re: [ATL] EEnum to EClass [message #547633 is a reply to message #547406] Mon, 19 July 2010 04:30 Go to previous messageGo to next message
Le 16/07/2010 18:14, Izaak a écrit :
> Hi Vincent,
You can call another unique rule to create B and use this rule every
time you need to get a B instance
Cordialement
Vincent MAHÉ
Re: [ATL] EEnum to EClass [message #547847 is a reply to message #547633] Mon, 19 July 2010 15:08 Go to previous messageGo to next message
Thank you Freddy and William for all the help!
The following code did the trick:
helper def: enumMap : Map(PMWV1!Location, String) =
Map {(#IL, 'IL'), (#AZ, 'AZ'), (#AK, 'AK')};
helper def: enumByName : Map(PMWV1!Location, PMWV2!CriteriaAllowedValue) = Map {};
helper def: getEnum(s : PMWV1!Location) : OclAny =
if (thisModule.enumByName.containsKey(s)) then
(thisModule.enumByName.get(s))
else
(thisModule.enum(s))
endif;
rule enum(s : PMWV1!Location) {
to
t : PMWV2!CriteriaAllowedValue(
description <- thisModule.enumMap.get(s)
do {
thisModule.enumByName <- thisModule.enumByName.including(s, t);
t;
Basically build up a map of the instances created and first check the map for an instance before creating one again...
Re: [ATL] EEnum to EClass [message #547912 is a reply to message #546793] Tue, 20 July 2010 03:41 Go to previous message
Using the keyword unique you can simplify that to :
unique lazy rule enum{
from s : PMWV1!Location
to
Though it's a lazy rule, the call to it is the same as with the called rule.
[Updated on: Tue, 20 July 2010 03:42] by Moderator
Previous Topic:programmatically invoke ATL
Next Topic:[QVTO] ClassNotFound in blackbox
Current Time: Sat Jul 19 22:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.04881 seconds
