Discouraged access of RWTLifeCycle.setSessionDisplay(Display) [message #547331] |
Fri, 16 July 2010 06:16  |
I would like to extend org.eclipse.swt.widgets.Display with some custom
features, so I subclassed it and call
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.setSessionDi splay(Display)
before the initial call to org.eclipse.ui.PlatformUI.createDisplay().
This way org.eclipse.swt.widgets.Display.getCurrent() always returns my
Display-Subclass.
1) I know this way is kind of a hack, but I could not find a straighter
way to achieve my target. Any comments?
2) In eclipse the call to
shows a warning "Discouraged access". Can you please comment on this
warning? Why is it marked as discouraged? Can I ignore the warning?
Philipp
Re: Discouraged access of RWTLifeCycle.setSessionDisplay(Display) [message #547355 is a reply to message #547338] |
Fri, 16 July 2010 07:50   |
Hi Philipp,
subclassing Display is a misuse of the SWT API. You should definitely
not do that. If you need to attach application data to the Display, you
can use Display#setData. But I'd also feel that the session is the right
place to store it.
Regards, Ralf
Philipp Leusmann wrote:
> Am 16.07.2010 13:01, schrieb Stefan Roeck:
>> Hi Philipp,
>>> straighter way to achieve my target. Any comments?
>> If you want to store data per session you could use a SessionSingleton.
>> What's your use case?
> Views in our application may receive events to notify them of available
> udates.
> The common base class we derive all our views from, shows a dialog to
> notify the user, but as you can imagine, this dialog should only be
> shown once per update.
> So i decided to use a semaphore and I thought the display would be a
> convenient place to store it. Of course I could put it directly into the
> session, but still I think it fits nicely into the Display ;)
> You have any other recommendations?
> Regards,
> Philipp
Re: Discouraged access of RWTLifeCycle.setSessionDisplay(Display) [message #547356 is a reply to message #547355] |
Fri, 16 July 2010 08:23  |
Ok guys, you convinced me. A SessionSingleton is even cooler ;)
Am 16.07.2010 13:50, schrieb Ralf Sternberg:
> Hi Philipp,
> place to store it.
> Regards, Ralf
>>> Hi Philipp,
>> udates.
>> Regards,
>> Philipp
FUDForum. Page generated in 0.05935 seconds
