Home » Archived » M2M (model-to-model transformation) » [ATL] Preferred way of using the ATL2006 compiler in Java program
[ATL] Preferred way of using the ATL2006 compiler in Java program [message #546649] Tue, 13 July 2010 12:20 Go to next message
Since I still have problems with using the ATL compiler from a standalone java program my questions are the following:
1) Where can I get a proper version of the compiler.
2) Can I get a stand-alone (ie. outside eclipse) version?
3) Are there some examples on how to call this from Java?
Answering one of these questions can already tremendously help me.
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #546656 is a reply to message #546649] Tue, 13 July 2010 12:40 Go to previous messageGo to next message
This is the code I use though it's not outside Eclipse so I don't know about the standalone mode.
We first inject the ATL file as an ATL Model using AtlParser and then AtlCompiler to get the ASM Model that we have to write to a file.
ByteArrayInputStream inputStream = new ByteArrayInputStream(yourATLString.getBytes());
EMFTCSInjector injector = new EMFTCSInjector();
Map params = new HashMap();
params.put("name","ATL");
params.put("indentString", " ");
params.put("identEsc", "\"");
params.put("stringDelim", "'");
params.put("serializeComments", "true");
EMFModel atlModel = null;
try {
	atlModel = factory.newModel((EMFReferenceModel) factory.getBuiltInResource("ATL.ecore"), "atlModel");
} catch (ATLCoreException e1) {
	e1.printStackTrace();
try {
	EMFReferenceModel problemMetaModel = (EMFReferenceModel) factory.getBuiltInResource("Problem.ecore");
	EMFModel problems = factory.newModel(problemMetaModel, "problemsModel");
	params.put("problems", problems);
	injector.inject(atlModel, inputStream, params);
	OutputStream source = new ByteArrayOutputStream();
	OutputStream result = new ByteArrayOutputStream();
	AtlParser parser = new AtlParser();
	parser.extract(atlModel, source, params);
	AtlCompiler.compile(new ByteArrayInputStream(source.toString().getBytes()), result);
	PrintWriter asmPrintWriter = new PrintWriter(location.substring(16, location.length())+"/transformation/"+model.getName()+"Copy.asm");
	ASM asm = new ASMXMLReader().read(new ByteArrayInputStream(result.toString().getBytes()));
	ASMXMLWriter txtWriter = new ASMXMLWriter(asmPrintWriter,false);
	txtWriter.print(asm);
	asmPrintWriter.flush();
	asmPrintWriter.close();
} catch(Exception e){
	e.printStackTrace();
Hope it helps
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #546658 is a reply to message #546656] Tue, 13 July 2010 12:44 Go to previous messageGo to next message
Thanks I give it a try. One more thing. Your factory variable, what does its declaration look like? Ie. what factory did you use?
Thanks in advance
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #546659 is a reply to message #546658] Tue, 13 July 2010 12:45 Go to previous messageGo to next message
EMFModelFactory factory = new EMFModelFactory();
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #546660 is a reply to message #546659] Tue, 13 July 2010 12:49 Go to previous messageGo to next message
Could you also paste the relevant imports? Because if i press ctrl+shift+o (resolve imports) I can choose from different AtlParsers, each in a different package.
Then i can maybe see if the problem relies there...
Sorry to keep bothering:)
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #547000 is a reply to message #546649] Wed, 14 July 2010 18:03 Go to previous messageGo to next message
Matthias Bohlen, the author of Atl2006Compiler pointed me in the good direction, that differs a bit from the above used code:
import org.eclipse.m2m.atl.compilers.atl2006.Atl2006Compiler;
import org.eclipse.m2m.atl.engine.CompileTimeError;
public class YourCompilerClass
    * The file name of the ATL file to be compiled.
    * @parameter expression="${andromda.atlcompiler.atlFileURL}"
    * @required
   private URL    atlFileURL;
    * The file name of the compiled ASM file.
    * @parameter expression="${andromda.atlcompiler.asmFilename}"
    * @required
   private String asmFilename;
  public void executeCompiler()
       getLog().info("atlFilename=" + atlFileURL);
       getLog().info("asmFilename=" + asmFilename);
       File outputFile = new File(this.asmFilename);
       outputFile.getParentFile().mkdirs();
       CompileTimeError[] compileTimeErrors = null;
       try
           compileTimeErrors = new Atl2006Compiler().compile(this.atlFileURL.openStream(), this.asmFilename);
       catch (IOException e)
           throw new Exception("File to be compiled could not be found: " + this.atlFileURL, e);
       if (compileTimeErrors.length > 0)
           this.getLog().error("Errors when compiling " + atlFileURL);
           for (CompileTimeError error : compileTimeErrors)
               this.getLog().error("    at " + error.getLocation() + " " + error.getDescription());
           throw new Exception("compile time errors in ATL script");
       this.getLog().info("ASM file written to '" + this.asmFilename + "'.");
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #547001 is a reply to message #546649] Wed, 14 July 2010 18:06 Go to previous messageGo to next message
    * @required
    * @required
       try
Re: [ATL] Preferred way of using the ATL2006 compiler in Java program [message #547626 is a reply to message #546649] Mon, 19 July 2010 04:05 Go to previous message
a bit easier indeed Wink
Previous Topic:[QVTO] Accessing a EFeatureMapEntry
Next Topic:XML to xmi that confirms a metamodel ???
Current Time: Sun Jul 20 12:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.04250 seconds
