Home » Archived » M2M (model-to-model transformation) » [ATL] What kind of ATL2006compiler error is this?
[ATL] What kind of ATL2006compiler error is this? [message #545916] Fri, 09 July 2010 11:22 Go to next message
Hello ATL friends,
I got a problem. I have a Higher-order Transformation (HOT), that has as output an .atl file. This works fine, ie. i get the .atl file.
Now, I want to chain a bunch of things together, so i want to programmatically (from java) compile the .atl file to a .asm file. Well, if i just paste it in an ATL project, immediately the .asm file is generated. But when I try to do this programmatically (with the same model), the error below occurs.
Could someone explain in the first place, what KIND of error this is? Because it is hard for me to assess what goes wrong.
Furthermore, and even better, does someone have an example of how to start the ATL compiler (standalone, outside eclipse) programmatically. Is there an elegant way? I just kind of 'hacked' it. Smile
The error is this:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: org.eclipse.m2m.atl.engine.asm.ASMEmitter@21a024c.beginLineNumberEntry(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined)
	at process(ATLCompiler.atl)
		local variables: self=IN!<unnamed>:ATL!Binding
	at process_apply(ATLCompiler.atl[904:4-904:30])
		local variables: self=IN!<unnamed>:ATL!SimpleOutPatternElement
	at process_apply(ATLCompiler.atl[775:10-775:66])
		local variables: self=IN!EClass2MVC:ATL!MatchedRule, forEach=Sequence {IN!<unnamed>:ATL!SimpleInPatternElement}, ipe=IN!<unnamed>:ATL!SimpleInPatternElement, forEach=Sequence {IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement, IN!<unnamed>:ATL!SimpleOutPatternElement}, ope=IN!<unnamed>:ATL!SimpleOutPatternElement, forEach=Sequence {}, v=<null>
	at process(ATLCompiler.atl[538:3-538:26])
	at process(ATLCompiler.atl[448:3-448:24])
		local variables: self=IN!ecore2gwt:ATL!Module
	at main(ATLCompiler.atl)
		local variables: self=thisModule, WriteTo='/Users/marten/Work/EclipseWorkspaces/fatl2atl/out-models/ecore2gwt-featuresEnabled.asm'
Re: [ATL] What kind of ATL2006compiler error is this? [message #546638 is a reply to message #545916] Tue, 13 July 2010 11:33 Go to previous messageGo to next message
This still holds me up, anybody any idea?
Re: [ATL] What kind of ATL2006compiler error is this? [message #546640 is a reply to message #545916] Tue, 13 July 2010 11:49 Go to previous messageGo to next message
Have you tried in Regular VM ?
Re: [ATL] What kind of ATL2006compiler error is this? [message #546645 is a reply to message #545916] Tue, 13 July 2010 12:04 Go to previous messageGo to next message
How would you call that from Java? Do you have an example?
Re: [ATL] What kind of ATL2006compiler error is this? [message #547002 is a reply to message #545916] Wed, 14 July 2010 18:09 Go to previous message
Nevermind the last question.
My first solution did not serialize the ATLModel in memory and then inject it again.
It seems that if I first extract the ATL Model to a .atl file, and then inject it again, things work fine. Could it be that it is because I create elements without setting their 'location' attribute? It seems that beginLineNumberEntry might have something to do with the location attribute (just a random guess this!)?
[Updated on: Wed, 14 July 2010 18:11] by Moderator
Previous Topic:[ATL] is this case refinement or transformation
Next Topic:[QVTo] Referencing types of super-model (model inheritance)
Current Time: Sun Jul 20 14:20:34 EDT 2025
Powered by FUDForum. Page generated in 0.03571 seconds
