Home » Eclipse Projects » Remote Application Platform (RAP) » Seems like the UICallBack mechanism get broken
Seems like the UICallBack mechanism get broken [message #546479] Tue, 13 July 2010 00:34 Go to next message
Hi, all!
I'm trying to use the way which is described here http://wiki.eclipse.org/RAP/FAQ#How_do_I_implement_a_key_bin ding_that_triggers_a_Command.3F
When I start the application and set up a breakpoint to UICallBackServiceHandler.service() I will be suspended on it time by time. However, after pressing the hot keys binding and executing the command "org.eclipse.ui.window.nextView" in ExecuteCommandPhaseListener the application will never suspended at my break-point - seems to me that the UICallBack mechanism get broken. I'm not sure is it platform problem or my own application.
Can anybody check it out and give some advise?
The problem is in IE 8 and RAP 1.3, FireFox works fine.
Thanks, Yury.
[Updated on: Tue, 13 July 2010 02:36] by Moderator
Re: Seems like the UICallBack mechanism get broken [message #546772 is a reply to message #546479] Wed, 14 July 2010 03:38 Go to previous messageGo to next message
Hi Yury,
there is a bug related to KeyListener and UICallback:
317616: KeyListener breaks UICallback on IE, Chrome, Safari
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317616
but there is no KeyListener used in the FAQ entry. Feel free to open a
bugzilla with a snippet to reproduce it.
BTW is this happen in all browsers (IE, FF, Safari, Chrome, Opera)?
Best,
Ivan
On 07/13/2010 7:36 AM, Yury wrote:
> Hi, all!
> Thanks, Yury.
Re: Seems like the UICallBack mechanism get broken [message #546833 is a reply to message #546772] Wed, 14 July 2010 07:45 Go to previous messageGo to next message
Hi, Ivan!
Thank you for your answer. I've already find the cause of my problem and it is https://bugs.eclipse.org/bugs/show_bug.cgi?id=301261 as you sad. But I find may be a little bit different solution. It is shown below. Fixes in Request.js file only.
    // References the currently running request or null if no request is active
    this._currentRequest = null;
    // Running transports array
    this._transports = new Array();
    this._timeoutPage = "";
    _sendStandalone : function( request ) {
      // [if] Dispose the last transport before creating the new one
      // see bug 301261
      for (var i = 0; i < this._transports.length; i++){
    	  var transport = this._transports[i];
    	  var state = transport.getState();
	      if( transport != null &&
	    		  state != "configured" &&
	    		  state != "sending" &&
	    		  state != "receiving") {
	    	transport.getRequest().dispose();
	    	transport.dispose();
	    	this._transports.splice(i, 1);
      // TODO [rh] WORKAROUND
      //      we would need two requestQueues (one for 'normal' requests that
      //      is limited to 1 concurrent request and one for the 'independant'
      //      requests created here
      //      Until qooxdoo supports multiple requestQueues we create and
      //      send this kind of request without knownledge of the request queue
      var vRequest = request;
      var vTransport = new qx.io.remote.Exchange(vRequest);
      // Establish event connection between qx.io.remote.Exchange instance and
      // qx.io.remote.Request
      vTransport.addEventListener("sending", vRequest._onsending, vRequest);
      vTransport.addEventListener("receiving", vRequest._onreceiving, vRequest);
      vTransport.addEventListener("completed", vRequest._oncompleted, vRequest);
      vTransport.addEventListener("aborted", vRequest._onaborted, vRequest);
      vTransport.addEventListener("timeout", vRequest._ontimeout, vRequest);
      vTransport.addEventListener("failed", vRequest._onfailed, vRequest);
      vTransport._start = (new Date).valueOf();
      this._transports.push(vTransport);
      vTransport.send();
      // END WORKAROUND
and it resolved my problem.
What do you think about this fixes?
Answer for you question about browsers:
I'd checked only FF3.6 and IE8 and the problem is reproduced in IE only. FF works fine.
Thanks, Yury.
[Updated on: Wed, 14 July 2010 07:46] by Moderator
Re: Seems like the UICallBack mechanism get broken [message #546842 is a reply to message #546833] Wed, 14 July 2010 08:16 Go to previous messageGo to next message
Hi Yury,
yes... your solution will work too. My first implementation for a fix
was similar. But way we need to keep all running transports in array, as
we can clean (dispose) them when they actually finished (completed or
failed).
Best,
Ivan
On 07/14/2010 2:45 PM, Yury wrote:
> Hi, Ivan!
> is active
> // see bug 301261
> if( transport != null && state !=
> "configured" &&
> requests that
> 'independant'
> request queue
> instance and
> vRequest);
> vRequest);
> vRequest);
> vRequest);
> vRequest);
> vTransport.send();
> // END WORKAROUND
> Thanks, Yury.
Re: Seems like the UICallBack mechanism get broken [message #547019 is a reply to message #546479] Wed, 14 July 2010 23:00 Go to previous message
Hi, Ivan.
I've applied your patch - it works good and seems better than my own fixes. Thanks for advise!
Previous Topic:could not evaluate javascript response: Invalid characters?
Next Topic:IE popup dialog: "A script on this page is causing Internet Explorer to run slowly. ..."
Current Time: Sun Jul 20 14:51:25 EDT 2025
Powered by FUDForum. Page generated in 0.06243 seconds
