Home » Archived » BIRT » How to set column i.e. text field values from DataSetEventAdapter
How to set column i.e. text field values from DataSetEventAdapter [message #545710] Thu, 08 July 2010 13:07 Go to next message
Originally posted by: pschoenb.gmx.de
I am trying to implement a Java-based event handler for a data set.
However, I do not understand how to write to a text field/list
cell/table cell from the onFetch() method, yet?
Are there any examples out there?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545905 is a reply to message #545710] Fri, 09 July 2010 10:54 Go to previous messageGo to next message
Patrick,
From a dataset event handler you do not write to a text filed. It is
just used to populate the dataset. You can then drag the dataset to the
report or drag individual columns to an existing table/gird. Every
table in a birt report is bound to a dataset (look at the binding tab in
the properties editor) which will do the evaluation automatically. If
you can give some more details I can help with an example.
Jason
On 7/8/2010 1:07 PM, Patrick Schönbach wrote:
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545943 is a reply to message #545905] Fri, 09 July 2010 12:23 Go to previous messageGo to next message
Jason,
meanwhile, I found out that I have to extend ScriptedDataSetEventAdapter
and overwrite fetch().
However, I am still puzzled how to actually get the data into the
dataset. I tried
row.setColumnValue(columnName, someString);
BIRT does generate some PDF, but except for the footer that I've put
into the master page, I get empty pages.
What am I missing?
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545944 is a reply to message #545943] Fri, 09 July 2010 12:31 Go to previous messageGo to next message
Have you dragged the dataset on to the report canvas? Datasets do not
run unless they are bound to a report item (table/chart/etc).
Jason
> Jason,
> dataset. I tried
> What am I missing?
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545963 is a reply to message #545944] Fri, 09 July 2010 13:57 Go to previous messageGo to next message
Yes, I dragged one dataset element just into the report, and another
into the header cell of a list, but both do not display.
What could I be missing?
Patrick
Re: How to set column i.e. text field values from DataSetEventAdapter [message #545980 is a reply to message #545963] Fri, 09 July 2010 14:45 Go to previous message
Patrick,
I sent you an email with an example. Can you try it?
Jason
Previous Topic:Fixed number of characters in column
Next Topic:Help for BIRT charts / data sets
Current Time: Sat Jul 19 13:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.05225 seconds
