Home » Eclipse Projects » Nebula » GridTableViewer previous tab traversal?
GridTableViewer previous tab traversal? [message #540670] Wed, 16 June 2010 18:47 Go to next message
I've been doing a bunch of research on the web and have spent the better part of a day trying to figure this out. Can anyone help?
I have a GridTableViewer in my application. I have a requirement which states that the user shall be able to tab and shift+tab to navigate between cells (like Excel).
Tab works by default, but I cannot get shift+tab to work. I've tried a lot different things, including adding a KeyListener to the GridTableViewer's Grid and sending a call to grid.traverse(SWT.TRAVERSE_*) on keyPressed. I've tried passing in tab traverse and arrow traverse, but neither have any significant effect.
My GridTableViewer in my application exists in a Composite with two buttons. When I shift+tab in my application, the focus moves to the previous component: a button. Is there any way to work around this to get the functionality I'm looking for?
I've stripped everything down to an example View that demonstrates the issue. Tabbing works, but shift+tabbing does not.
Any help is appreciated.
Thanks!
Lars
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.part.ViewPart;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.widgets.grid.GridColumn;
public class View extends ViewPart {
	public static final String ID = "GridTableViewerTest.view";
	private GridTableViewer gridViewer;
	public void createPartControl(Composite parent) {
		gridViewer = new GridTableViewer(
		parent, SWT.V_SCROLL | SWT.H_SCROLL);
		gridViewer.setLabelProvider(new ColumnLabelProvider());
		gridViewer.setContentProvider(new TableContentProvider());
		gridViewer.getGrid().setCellSelectionEnabled(true);
		gridViewer.getGrid().setLinesVisible(true);
		gridViewer.getGrid().setHeaderVisible(true);
		GridColumn column1 = new GridColumn(gridViewer.getGrid(), SWT.NONE);
		column1.setWidth(100);
		column1.setText("Column 1");
		GridColumn column2 = new GridColumn(gridViewer.getGrid(), SWT.NONE);
		column2.setWidth(100);
		column2.setText("Column 2");
		GridColumn column3 = new GridColumn(gridViewer.getGrid(), SWT.NONE);
		column3.setWidth(100);
		column3.setText("Column 3");
		gridViewer.setInput(this.getViewSite());
	 * Passing the focus request to the viewer's control.
	public void setFocus() {
		gridViewer.getControl().setFocus();
class ColumnLabelProvider extends LabelProvider implements
ITableLabelProvider {
	public String getColumnText(Object element, int columnIndex) {
		return "foo";
	public Image getColumnImage(Object element, int columnIndex) {
		// TODO Auto-generated method stub
		return null;
class TableContentProvider implements IStructuredContentProvider {
	private List<TableRow> tableRows;
	public TableContentProvider() {
		tableRows = new ArrayList<TableRow>();
		for (int row=1; row<=10; row++) {
			TableRow tableRow = new TableRow();
			tableRows.add(tableRow);
	public Object[] getElements(Object inputElement) {
		return tableRows.toArray();
	public void dispose() {
	public void inputChanged(Viewer viewer,
			Object oldInput, Object newInput) {
class TableRow {
	public TableRow() {}
Re: GridTableViewer previous tab traversal? [message #545541 is a reply to message #540670] Thu, 08 July 2010 04:29 Go to previous messageGo to next message
you have to suppress Tabbing the focus via a TraverseListener in createPartControl:
				gridViewer.getGrid().addTraverseListener(new TraverseListener()  {
					public void keyTraversed(TraverseEvent e)  {
						switch (e.detail)  {
							case SWT.TRAVERSE_TAB_NEXT:
							case SWT.TRAVERSE_TAB_PREVIOUS:
								e.doit = false;
Arne Jans
Re: GridTableViewer previous tab traversal? [message #545566 is a reply to message #545541] Thu, 08 July 2010 05:27 Go to previous messageGo to next message
You should be able to get Tabs working by configuring your when setting
up the GridViewerEditor like this:
-------8<-------
GridViewerEditor.create(v, actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL |
ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL
-------8<-------
Am 08.07.10 10:29, schrieb Arne Jans:
> createPartControl:
> switch (e.detail) {
> e.doit = false;
> Best regards,
> Arne Jans
Re: GridTableViewer previous tab traversal? [message #545736 is a reply to message #540670] Thu, 08 July 2010 15:58 Go to previous messageGo to next message
Arne/Tom,
Thanks for the responses. I've tried your suggestions, but neither of them seem to have an effect. (I've tried each of them individually and together... no difference.) Shift+tab still does not traverse to the previous cell.
Code is below; am I doing something wrong?
package gridtableviewertest;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrategy;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.nebula.jface.gridviewer.GridViewerEditor;
		ColumnViewerEditorActivationStrategy actSupport
			= new ColumnViewerEditorActivationStrategy(gridViewer);
		 * Additions
		GridViewerEditor.create(gridViewer, actSupport,
				| ColumnViewerEditor.TABBING_VERTICAL);
				switch (e.detail)  {
						e.doit = false;
		 * End Additions
		return "foo";
		return null;
class TableRow {
Lars
Re: GridTableViewer previous tab traversal? [message #545786 is a reply to message #545736] Fri, 09 July 2010 03:02 Go to previous messageGo to next message
Ok. I guess I now understand your problem. You are not talking about
editing but simply navigation.
I need to take a look into the code.
Tom
Am 08.07.10 21:58, schrieb Lars Butler:
> Arne/Tom,
> previous cell.
> import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
> ColumnViewerEditorActivationStrategy actSupport =
> * Additions
> switch (e.detail) {
> e.doit = false;
> * End Additions
> SWT.NONE);
> SWT.NONE);
> SWT.NONE);
> @Override
> return "foo";
> @Override
> return null;
> @Override
> @Override
> @Override
> class TableRow {
> Lars
Re: GridTableViewer previous tab traversal? [message #545881 is a reply to message #545786] Fri, 09 July 2010 10:18 Go to previous message
Hey Tom,
Yes, that is correct; I'm only concerned with navigation at this point. Sorry if I didn't make that initially clear.
Thanks for your time.
-Lars
Re: GridTableViewer previous tab traversal? [message #599907 is a reply to message #545541] Thu, 08 July 2010 05:27 Go to previous message
-------8<-------
-------8<-------
> createPartControl:
> switch (e.detail) {
> e.doit = false;
> Best regards,
> Arne Jans
Re: GridTableViewer previous tab traversal? [message #599923 is a reply to message #545736] Fri, 09 July 2010 03:02 Go to previous message
Tom
> Arne/Tom,
> previous cell.
> * Additions
> switch (e.detail) {
> e.doit = false;
> * End Additions
> SWT.NONE);
> SWT.NONE);
> SWT.NONE);
> @Override
> return "foo";
> @Override
> return null;
> @Override
> @Override
> @Override
> class TableRow {
> Lars
Re: GridTableViewer previous tab traversal? [message #599930 is a reply to message #545786] Fri, 09 July 2010 10:18 Go to previous message
Hey Tom,
-Lars
Previous Topic:GridTableViewer previous tab traversal?
Next Topic:CalendarCombo
Current Time: Sat Jul 19 22:49:41 EDT 2025
Powered by FUDForum. Page generated in 0.30578 seconds
