Home » Language IDEs » PHP Development Tools (PDT) » Cannot Execute Script in IDE
icon8.gif  Cannot Execute Script in IDE [message #545435] Wed, 07 July 2010 14:23 Go to next message
I am running CentOS 5.5 32 Bit
I have downloaded the all-in-one from zend and unpacked it to /bin/eclipse
I have setup the zend debugger successfully, and phpinfo() reports that the zend debugger is present
I have created a phpproject in a brand new workspace
I have created a new php file, called 'hello.php'
I have populated it with simple output statements to establish that the debugger works.
when I attempt to run I get
Cannot run program " bin/eclipse/plugins/org.zend.php.debug.debugger_5.3.18.v2010 0603/resource/php5/php-cgi "
error=13, permission denied.
Well I find that interesting since that location does not exists.
I have no idea what this means and have spent hours attempting to find where to set this path.
-- HELP --, I have fallen and can't get up
Pretend I am a total idiot, can someone please explain how to correct this problem.
Eclipse is located at '/bin/eclipse'
Zend debugger is located at "/opt/ZendDebugger-5.2.14-linux-glibc23-i386"
php is at "var/bin"
project is at "/projects/eclipse/demo/"
I have provided lines from the php.ini
; Module Settings ;
[DEBUGGER]
;zend php debugger
zend_extension = /opt/ZendDebugger-5.2.14-linux-glibc23-i386/5_1_x_comp/ZendD ebugger.so
zend_debugger.allow_hosts=127.0.0.1/192.168.15
zend_debugger.expose_remotely=always
[Date]
; Defines the default timezone used by the date functions
;date.timezone =
Re: Cannot Execute Script in IDE [message #545451 is a reply to message #545435] Wed, 07 July 2010 15:58 Go to previous messageGo to next message
Additional Info
Started over
Realized that the php was referencing the wrong path for php-cgi, and not using the
one that I have installed on the system. However the path is incorrect.
Extracted to "/usr/bin/eclipse"
Started Eclipse PHP Version
Created a brand new clean workspace at "/projects/demos/php"
Created a new php file "phpdemo"
Populated it with output statments
<?php
echo "<p>Hello World</p>";
echo "<p><u>I am a PHP Script:</u> <b>PHPDemo.php</b></p>\n";
which produces the expected output in my web browser
When I attempt to run the script inside the IDE I get
Cannot run program "/usr/bin/eclipse/plugins/
org.zend.php.debug.debugger.linux.x86_5.3.18.v20100603/
resources/php5/php-cgi" (in directory /projects/demos/php"):
error=13, Permission denied
Ok here is the mystery, the location is actually
" /usr/bin/eclipse/plugins/org.zend.php.debug.debugger.linux.x 86_5.3.18.v20100603/
resources/php5/ext/php-cgi"
After several lost hours attempting to reset the path, I find myself writing this
Would someone please help me (explain it like I was a third grader), as I have a
deadline to meet
RESOLVED: Re: Cannot Execute Script in IDE [message #545740 is a reply to message #545451] Thu, 08 July 2010 16:18 Go to previous message
I had set up eclipse as the root user and attempted to run it as a user that did not belong to the root group.
Adding the user to the root group and doing a 'chmod' solved the problem, the php executable needed to be able to execute and thus needed execu Embarrassed te privileges
Embarrassed
Previous Topic:Information: breakpoints stop working when using xdebug with PDT.
Next Topic:context sensitive highlighting ... ?
Current Time: Sat Jul 19 11:24:58 EDT 2025
Powered by FUDForum. Page generated in 0.50382 seconds
