[wikitext] Converting mbedded images [message #503798] |
Tue, 15 December 2009 15:05  |
I'd like to have images appear inline in wikitext-to-eclipse-help as opposed to as href links. Is there any OOTB functionality for this, or do I need to write some kind of custom converter?
cheers,
Miles
Re: [wikitext] Converting mbedded images [message #544856 is a reply to message #544801] |
Mon, 05 July 2010 13:47  |
L. Frank Turovich wrote on Mon, 05 July 2010 10:40 |
Has to be something simple I am missing, but can't figure out what it might be. Any suggestions?
Hi Frank,
That's the format I'm using as well i.e.:
[[Image:images/edit_tutorial/SimpleTutorial3CreateModel.png] ]
Note that the image references are relative to the doc location, not the project root.
Re: [wikitext] Converting mbedded images [message #601017 is a reply to message #506316] |
Wed, 07 April 2010 17:06  |
David Green wrote on Wed, 06 January 2010 18:19
> Miles Parker wrote:
> > One other question..on my setup using ant task, > and < are not being
> > converted. Is this suported for mediawiki wikitext to eclipse help?
> What do you mean by not being converted? Please file a bug if you think that there's a problem.
Following up on this finally.. basically I just want to find out what the formula is for specifying an embedded image in wikitext (mediawiki) such that it appears correctly in the generated Eclipse html docs. I'm currently doing docs locally, so it won't be using the auto wiki [[image:]] upload strategy. There might simply not be a way to do this as a limitation of mediawiki, not wikitext, but I'm hoping for some kind of solution that avoids actually having to manually edit the html post conversion.
thanks,
Miles
FUDForum. Page generated in 0.05622 seconds
