Home » Eclipse Projects » Remote Application Platform (RAP) » Menu not showin Radio or Check option.(DropDownMenuButton Menu bug?)
Menu not showin Radio or Check option. [message #544769] Mon, 05 July 2010 09:18 Go to next message
Good day,
I'm playing with dropdownButton as in the toolbar in a composite. And now i discoverd somting weard I use the folowing code:
public void createPartControl(Composite parent) {
		Composite controllComposite = new Composite(parent, SWT.NONE);
		controllComposite.setLayout(new GridLayout(3, false));
		searchBox = new Text(controllComposite, SWT.BORDER | SWT.SEARCH | SWT.CANCEL);
		final ToolBar tool = new ToolBar(controllComposite, SWT.NONE);
		search = new ToolItem(tool, SWT.DROP_DOWN);
		search.setImage(AbstractUIPlugin.imageDescriptorFromPlugin("com.remainsoftware.universalviewers",
				"img/Search-icon16.png").createImage());
		Menu menu = new Menu(getSite().getShell(), SWT.POP_UP);
		final MenuItem exact = new MenuItem(menu, SWT.RADIO);
		exact.setText("Exact Search");
		exact.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent event) {
				System.out.println(exact.getSelection());
				if (exact.getSelection())
					System.out.println("Exact search");
		final MenuItem detail = new MenuItem(menu, SWT.CHECK);
		detail.setText("Include Detail Headsers");
		detail.addSelectionListener(new SelectionAdapter() {
				System.out.println(detail.getSelection());
				if (detail.getSelection())
					System.out.println("detail search");
search.addListener(SWT.Selection, new Listener() {
			public void handleEvent(Event event) {
				if (event.detail == SWT.ARROW) {
					// Shoe menu
						menu = tableSorter.getMenuOptions(getSite().getShell());
						Rectangle rect = search.getBounds();
						Point pt = new Point(rect.x, rect.y + rect.height);
						pt = tool.toDisplay(pt);
						menu.setLocation(pt.x, pt.y);
						menu.setVisible(true);
				} else {
					// Do somting
Now the menu shows up nicly however I dont see tha radio button nor the Checkbox I am expecting in the MenuItems. Or am I doing somting wrong?
Re: Menu not showin Radio or Check option. [message #544781 is a reply to message #544769] Mon, 05 July 2010 09:44 Go to previous messageGo to next message
Hi Martijn,
I've just checked your snippet with RAP from CVS HEAD ant it works fine
- menu is there, radio and checkbox items too. Initially, when the menu
is shown, both radio and check menu items are not selected. Select them
and you will see the checkmark and the small circle in front the radio
button.
Best,
Ivan
On 07/05/2010 4:18 PM, Martijn Cremer wrote:
> Good day,
> search.setImage(AbstractUIPlugin.imageDescriptorFromPlugin("com.remainsoftware.universalviewers ",
> @Override
> // Shoe menu menu =
> rect.height);
> } else {
> // Do somting
> wrong?
Re: Menu not showin Radio or Check option. [message #544788 is a reply to message #544781] Mon, 05 July 2010 10:09 Go to previous messageGo to next message
Ivan Furnadjiev wrote on Mon, 05 July 2010 15:44
Hi Martijn,
button.
Best,
Ivan
That's weird I am using the business theme (I forgot to mention that).
I clicked on them but they do not pop-up (i thought maybe rap was late rendering the items). So this is weard il try outside the business theme.
So after reading your post I tried it without the busness theme same result.
I must note the snippet is simplyfied, the menu is generated under sertain conditions. (meaning when the view loads the menu does not exsist and is created at runtime) could this be maybe the problem?
Re: Menu not showin Radio or Check option. [message #544798 is a reply to message #544788] Mon, 05 July 2010 10:38 Go to previous messageGo to next message
Just to be sure i created a standalone app (not in my project) same result..
Im using:
Rich Ajax Platform (RAP) Tooling 1.3.0.20100615-1734 org.eclipse.rap.tooling.feature.group
Thats the stable 1.3 release as far as I know.
Re: Menu not showin Radio or Check option. [message #544812 is a reply to message #544788] Mon, 05 July 2010 10:52 Go to previous messageGo to next message
Hi Martijn,
if you can provide a complete snippet/project to reproduce the issue
please feel free to open a bugzilla. For me, the attached snippet in
first post works fine with/without business theme.
Best,
Ivan
>> Hi Martijn,
>> fine - menu is there, radio and checkbox items too. Initially, when
>> the menu is shown, both radio and check menu items are not selected.
>> Select them and you will see the checkmark and the small circle in
>> front the radio button.
>> Best,
>> Ivan
> result.
Re: Menu not showin Radio or Check option. [message #544979 is a reply to message #544812] Tue, 06 July 2010 05:14 Go to previous message
Ivan Furnadjiev wrote on Mon, 05 July 2010 16:52
Hi Martijn,
Best,
Ivan
>> Hi Martijn,
>> Best,
>> Ivan
> result.
Never mind, this morning I discoverd that I forgot to keep track of one of the dynamic parameters and because of that the menu got initialised constantly and there for it did run the actions, but never showed the next state. (how dumb can you get).
Previous Topic:hanging UICallBackServiceHandler without any response
Next Topic:No layout registered with default id
Current Time: Sun Jul 20 02:24:12 EDT 2025
Powered by FUDForum. Page generated in 0.05078 seconds
