Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Xtext] Problem: Scoping on objects at runtime (Problem with Scoping on objects at runtime )
[Xtext] Problem: Scoping on objects at runtime [message #544293] Fri, 02 July 2010 05:03 Go to next message
I'am trying to to some kind of scoping. I have the following DSL:
Definition Name{
	property  Name_prop
	property  Name_prop1
Definition Test{
	property  Test_prop
Access Test {
 	propertyRef  Test_prop
Now I want to press [Strg + Space] after 'propertyRef' and
I want to see just "Test_prop" as proposal in the context menu!
By default Xtext generates me 'Name_prop", "Name_prop1"
and "Test_prop" as proposal.
Is there any posibility to do that with Xtext? My grammar looks like this: (notice the {FunctionCall} was just a try to get access to the objects at runtime for scoping?)
Language returns Language:
		(statement+=Statement)*;
Statement returns Statement:
	Definition | Access;
Definition returns Definition:
	'Definition'
	name=DefName
		(properties+=Property)*
DefName:
	name = ID;
AbstractDefName:
	Definition |DefName ;
Access returns Access:
	'Access' {FunctionCall} DefinitionName=[AbstractDefName]
		propAccesses+=PropAccess
PropAccess : 'propertyRef' propertyRef=[Property];
Property returns Property:
	'property'
	name=ID
EString returns ecore::EString:
	STRING | ID("." ID)*;
If there is no way to do that automatically by using Xtext? What
API can I use to implement this feature? How to do that using the ScopeProvider?
Thanks and Regards,
Martin
[Updated on: Fri, 02 July 2010 11:52] by Moderator
Re: [Xtext] Scoping on objects at runtime [message #544561 is a reply to message #544293] Sat, 03 July 2010 18:53 Go to previous messageGo to next message
Hi Martin,
something like
public IScope scope_PropAccess_propertyRef(Access context, EReference ref) {
Definition definition = // navigate from context to definition
return Scopes.scopeFor(definition.getProperties());
should do the trick. Have a look at the documentation to learn more
about scope providers.
Please note that Xtext has a dedicated newsgroup eclipse.modeling.tmf
Sebastian
Am 02.07.10 11:03, schrieb Martin:
> Definition Name{
> property Name_prop
> property Name_prop1
> Definition Test{
> property Test_prop
> Access Test {
> propertyRef Test_prop }
> 'Definition'
> name=DefName
> DefName: name = ID;
> AbstractDefName:
> 'property'
> name=ID
> ScopeProvider?
> Thanks and Regards,
> Martin
Re: [Xtext] Scoping on objects at runtime [message #544562 is a reply to message #544293] Sat, 03 July 2010 18:53 Go to previous message
Hi Martin,
something like
Sebastian
> Definition Name{
> property Name_prop
> property Name_prop1
> Definition Test{
> property Test_prop
> Access Test {
> 'Definition'
> name=DefName
> DefName: name = ID;
> AbstractDefName:
> 'property'
> name=ID
> ScopeProvider?
> Thanks and Regards,
> Martin
Previous Topic:How to load XML instance with SDO 1.0 (EMF 2.2)
Next Topic:[Xtext] Scoping on objects at runtime
Current Time: Sat Jul 19 12:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
