Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Setting a child of SashForm to a desired size
Setting a child of SashForm to a desired size [message #543990] Thu, 01 July 2010 05:47 Go to next message
I have a piece of code which looks like this:
SashForm sashForm = new SashForm(parent, SWT.VERTICAL);
Composite mainPart = new Composite(sashForm, SWT.NONE);
Composite second = new Composite(sashForm, SWT.NONE);
sashForm.setWeights(new int[] {1, 0}); // normally the second child should be hidden
int totalHeight = sashForm.getSize().y;
int desiredHeightOfSecond = ...;
sashForm.setWeights(new int[] {totalHeight - desiredHeightOfSecond, desiredHeightOfSecond});
However, this results in a bit smaller height than wanted, presumably because totalHeight includes the thickness of the separator. How can I find this thickness? Or is there a simpler way to achieve what I want? (I've tried using second.setSize(), but couldn't get it to work despite trying different combinations of pack and layout.)
[Updated on: Thu, 01 July 2010 05:49] by Moderator
Re: Setting a child of SashForm to a desired size [message #544397 is a reply to message #543990] Fri, 02 July 2010 10:44 Go to previous messageGo to next message
SashForm.getSashWidth() returns the width of the sash (separator).
HTH,
Re: Setting a child of SashForm to a desired size [message #544400 is a reply to message #544397] Fri, 02 July 2010 10:50 Go to previous message
Can't think how I missed that Embarrassed
Previous Topic:Tooltip for multi-column TreeViewer
Next Topic:WordPad in SWT application
Current Time: Sat Jul 19 05:00:08 EDT 2025
Powered by FUDForum. Page generated in 0.03668 seconds
