Home » Eclipse Projects » EclipseLink » Maven Trouble: Can't get Nexus to proxy the eclipselink repository
Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #544191] Thu, 01 July 2010 19:32 Go to next message
I am trying to get Nexus (a maven2 repository) to proxy the eclipse link repository and I cannot figure out how to do this. I'm getting the info I need from this webpage: http://wiki.eclipse.org/EclipseLink/Maven
When I try to index the repo, nexus reports this error:
jvm 1    | 2010-07-01 16:24:19 WARN  [ool-1-thread-20] - o.s.n.i.DefaultInde~          - Cannot fetch remote index for repository eclipselink
jvm 1    | java.io.FileNotFoundException: nexus-maven-repository-index.properties (item not found)
jvm 1    |      at org.sonatype.nexus.index.DefaultIndexerManager$1.retrieve(DefaultIndexerManager.java:1261)
jvm 1    |      at org.sonatype.nexus.index.updater.AbstractResourceFetcher.retrieve(AbstractResourceFetcher.java:22)
jvm 1    |      at org.sonatype.nexus.index.updater.DefaultIndexUpdater.downloadIndexProperties(DefaultIndexUpdater.java:493)
jvm 1    |      at org.sonatype.nexus.index.updater.DefaultIndexUpdater.access$100(DefaultIndexUpdater.java:74)
jvm 1    |      at org.sonatype.nexus.index.updater.DefaultIndexUpdater$IndexAdaptor.setProperties(DefaultIndexUpdater.java:780)
jvm 1    |      at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:954)
jvm 1    |      at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:159)
jvm 1    |      at org.sonatype.nexus.index.DefaultIndexerManager.updateRemoteIndex(DefaultIndexerManager.java:1271)
jvm 1    |      at org.sonatype.nexus.index.DefaultIndexerManager.downloadRepositoryIndex(DefaultIndexerManager.java:1152)
jvm 1    |      at org.sonatype.nexus.index.DefaultIndexerManager.reindexRepository(DefaultIndexerManager.java:1012)
jvm 1    |      at org.sonatype.nexus.index.DefaultIndexerManager.reindexRepository(DefaultIndexerManager.java:870)
jvm 1    |      at org.sonatype.nexus.tasks.ReindexTaskHandlerLegacy.reindexRepository(ReindexTaskHandlerLegacy.java:56)
jvm 1    |      at org.sonatype.nexus.tasks.ReindexTask.doRun(ReindexTask.java:57)
jvm 1    |      at org.sonatype.nexus.scheduling.AbstractNexusTask.call(AbstractNexusTask.java:192)
jvm 1    |      at org.sonatype.scheduling.DefaultScheduledTask.call(DefaultScheduledTask.java:338)
jvm 1    |      at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
jvm 1    |      at java.util.concurrent.FutureTask.run(Unknown Source)
jvm 1    |      at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
jvm 1    |      at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
jvm 1    |      at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
jvm 1    |      at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
jvm 1    |      at java.lang.Thread.run(Unknown Source)
jvm 1    | 2010-07-01 16:24:19 INFO  [ool-1-thread-20] - o.s.n.i.DefaultInde~          - Publishing best index for repository eclipselink
jvm 1    | 2010-07-01 16:24:20 INFO  [ool-1-thread-20] - o.s.n.i.p.DefaultIn~          - Unable to read properties file, will force index regeneration
jvm 1    | 2010-07-01 16:24:20 INFO  [ool-1-thread-20] - o.s.n.f.DefaultFeed~          - Reindexing repository eclipselink from path null and below. : Proc
ess started on Thu Jul 01 16:24:18 PDT 2010, finished successfully on Thu Jul 01 16:24:20 PDT 2010
Here is an image to how I set up nexus: http://img816.imageshack.us/img816/4951/bugl.png I thought it would be very straightforward but apparently it's not.
Is there something wrong with how the eclipselink repo is configured?
Re: Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #544221 is a reply to message #544191] Fri, 02 July 2010 00:53 Go to previous messageGo to next message
That URL is not a Maven repository, but a wiki page ABOUT the repository. The links on that page do not get me to a repository, so I'm not sure what the right URL is. But the one you're using is not.
> jvm 1 | at
> org.sonatype.nexus.index.DefaultIndexerManager$1.retrieve(De faultIndexerManager.java:1261)
> jvm 1 | at
> org.sonatype.nexus.index.updater.AbstractResourceFetcher.ret rieve(AbstractResourceFetcher.java:22)
> jvm 1 | at
> org.sonatype.nexus.index.updater.DefaultIndexUpdater.downloa dIndexProperties(DefaultIndexUpdater.java:493)
> jvm 1 | at
> org.sonatype.nexus.index.updater.DefaultIndexUpdater.access$ 100(DefaultIndexUpdater.java:74)
> jvm 1 | at
> org.sonatype.nexus.index.updater.DefaultIndexUpdater$IndexAd aptor.setProperties(DefaultIndexUpdater.java:780)
> jvm 1 | at
> org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAn dUpdateIndex(DefaultIndexUpdater.java:954)
> jvm 1 | at
> org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAn dUpdateIndex(DefaultIndexUpdater.java:159)
> jvm 1 | at
> org.sonatype.nexus.index.DefaultIndexerManager.updateRemoteI ndex(DefaultIndexerManager.java:1271)
> jvm 1 | at
> org.sonatype.nexus.index.DefaultIndexerManager.downloadRepos itoryIndex(DefaultIndexerManager.java:1152)
> jvm 1 | at
> org.sonatype.nexus.index.DefaultIndexerManager.reindexReposi tory(DefaultIndexerManager.java:1012)
> jvm 1 | at
> org.sonatype.nexus.index.DefaultIndexerManager.reindexReposi tory(DefaultIndexerManager.java:870)
> jvm 1 | at
> org.sonatype.nexus.tasks.ReindexTaskHandlerLegacy.reindexRep ository(ReindexTaskHandlerLegacy.java:56)
> jvm 1 | at org.sonatype.nexus.tasks.ReindexTask.doRun(ReindexTask.java: 57)
> jvm 1 | at
> org.sonatype.nexus.scheduling.AbstractNexusTask.call(Abstrac tNexusTask.java:192)
> jvm 1 | at
> org.sonatype.scheduling.DefaultScheduledTask.call(DefaultSch eduledTask.java:338)
> jvm 1 | at
> java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFu tureTask.access$301(Unknown
> Source)
> jvm 1 | at
> java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFu tureTask.run(Unknown
> Source)
> jvm 1 | at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
> Source)
> regeneration
> and below. : Proc
Re: Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #658943 is a reply to message #544221] Thu, 10 March 2011 09:23 Go to previous messageGo to next message
The URL that should be used is:
http://www.eclipse.org/downloads/download.php?r=1&nf=1&file=/rt/eclipselink/maven.repo
This will work in a pom definition but not in nexus (changing & to & doesn't help either)
If you follow this link to the mirror site and include this redirected URL it fails as the mirror service is a webpage full of links, hunted for other mirrors (eg. http://mirrors.ibiblio.org/pub/mirrors/eclipse/rt/eclipselin k/maven.repo/ ) but same effect.
You should be able to specify the mirror site with FTP, but bug(s) in Nexus means you cannot, see https://issues.sonatype.org/browse/NEXUS-3235
All in all this is pretty disappointing - anyone have a clue how to work around this?
I'm stuck with putting:
<repository>
<id>eclipselink</id>
<url><![CDATA[
http://www.eclipse.org/downloads/download.php?r=1&nf=1&a mp;file=/rt/eclipselink/maven.repo
]]></url>
<snapshots>
<enabled>true</enabled>
<updatePolicy>never</updatePolicy>
</snapshots>
</repository>
In my POMs Sad
Re: Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #658979 is a reply to message #658943] Thu, 10 March 2011 10:29 Go to previous messageGo to next message
Hm. I'm proxying eclipselink in my Nexus without problems.
Maven 2 release repostory to
http://www.eclipse.org/downloads/download.php?r=1&nf=1&a mp;file=/rt/eclipselink/maven.repo/
Re: Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #659495 is a reply to message #544191] Mon, 14 March 2011 06:32 Go to previous messageGo to next message
Since the weekend (where we have Nexus scheduled to reindex, repair etc) this seems fine now on the download.php url.
Guess if anyone else has issues with this then run some repair/rebuild tasks should sort it.
Re: Maven Trouble: Can't get Nexus to proxy the eclipselink repository [message #659522 is a reply to message #659495] Mon, 14 March 2011 08:20 Go to previous message
Ah, indeed. I have it rebuild every night.
Previous Topic:MOXy support for inheritance (Java -> XML)
Next Topic:problem with dynamic weaving and class hierarchy
Current Time: Sun Jul 20 11:56:13 EDT 2025
Powered by FUDForum. Page generated in 0.06209 seconds
