Home » Modeling » M2T (model-to-text transformation) » [acceleo] Can we know the Generated List file of mainFile(Can we know the Generated List file of mainFile)
[acceleo] Can we know the Generated List file of mainFile [message #543649] Wed, 30 June 2010 04:26 Go to next message
I use a main file acceleo with condition on generation of template.
Is it possible to know the generated file List of doGenerate call ?
Thanks.
Re: [acceleo] Can we know the Generated List file of mainFile [message #543667 is a reply to message #543649] Wed, 30 June 2010 04:59 Go to previous messageGo to next message
--------------040908040803030307070602
The "doGenerate" method doesn't allow it, yet if you look at its
implementation, you'll realize that it simply delegates to "generate"
which does return the list of generated files. You can change your
We didn't add it directly to doGenerate() because of API compatibility
issues. You can call "generate()" directly if you wish to retrieve this
list.
Laurent
poltrox wrote:
> Hi
> Thanks.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040908040803030307070602--
Re: [acceleo] Can we know the Generated List file of mainFile [message #543675 is a reply to message #543667] Wed, 30 June 2010 05:25 Go to previous messageGo to next message
I try to call directly generate but the map return is empty.
Map<String,String> mapList;
dataAcceleoGenerator = ((AbstractAcceleoGenerator)acceleoGenerator.newInstance());
dataAcceleoGenerator.initialize(modelUri, folder, arguments);
mapList=dataAcceleoGenerator.generate(new BasicMonitor());
System.out.println("size " +mapList.size()+ " contains "+mapList.values());
Console :
size 0 contains []
This call generates 4 files .
Re: [acceleo] Can we know the Generated List file of mainFile [message #543680 is a reply to message #543675] Wed, 30 June 2010 05:38 Go to previous messageGo to next message
I see a method get Listener, I don't understand how to use her.
I don't find a method to add me to the listener.
Do you have some exemple ?
Re: [acceleo] Can we know the Generated List file of mainFile [message #543693 is a reply to message #543680] Wed, 30 June 2010 06:33 Go to previous messageGo to next message
I find a solution , but i don't understand why you return a new list of Listener at each call of
getListeners ()
I must move to global attribute
List<IAcceleoTextGenerationListener> listeners = super.getGenerationListeners();
in each mainfile generated.
I can add my listener after this change :
dataAcceleoGenerator.getGenerationListeners().add(this);
Why you don't create this list in the abstract method as attribut instead to create a new list for each call ?
Re: [acceleo] Can we know the Generated List file of mainFile [message #543721 is a reply to message #543693] Wed, 30 June 2010 07:51 Go to previous messageGo to next message
--------------010600070503030007070609
The "getGenerationListeners()" method will only be called once for each
generation, thus returning a new list is the easiest.
As for the "generate" call returning an empty map, this is due to the
generation strategy you use (see method getGenerationStrategy) : the
default strategy will create the files on the fly, and it doesn't keep
track of the files it generated.
If you use the PreviewStrategy instead, "generate()" will return a Map
which key=value pairs such as : filename = file contents... but the
PreviewStrategy doesn't generate files :p.
Feel free to fill in an enhancement request for this, the default
strategy simply doesn't keep track of them because this functionality
has been added later.
Laurent Goubet
Obeo
> Listener at each call of getListeners ()
> I must move to global attribute List<IAcceleoTextGenerationListener>
> listeners = super.getGenerationListeners(); in each mainfile generated.
--------------010600070503030007070609--
Re: [acceleo] Can we know the Generated List file of mainFile [message #543737 is a reply to message #543721] Wed, 30 June 2010 08:53 Go to previous messageGo to next message
How can I add one class like a listener of my generator if I don't used
The "getGenerationListeners()" method ?
the function addListener is deprecated in abstract class and i don't find another solution as modify each generator
Re: [acceleo] Can we know the Generated List file of mainFile [message #543744 is a reply to message #543737] Wed, 30 June 2010 09:02 Go to previous message
--------------000501030501080803070507
The intended way of doing it is to use the "getGenerationListeners"
method, not the "addListener" one.
As mentionned in the "getGenerationListeners" code :
// TODO if you need to listen to generation event, add listeners to the
list here
which means you simply have to change it so that it looks like :
public List<IAcceleoTextGenerationListener> getGenerationListeners() {
listeners.add(new MyGenerationListener());
return listeners;
--------------000501030501080803070507--
Previous Topic:Using JET on WSDL and XSD
Next Topic:[Acceleo] Import UML Profile to use in templates
Current Time: Sun Jul 20 14:12:53 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
