Re: [acceleo] Can we know the Generated List file of mainFile [message #543744 is a reply to message #543737] |
Wed, 30 June 2010 09:02  |
--------------000501030501080803070507
The intended way of doing it is to use the "getGenerationListeners"
method, not the "addListener" one.
As mentionned in the "getGenerationListeners" code :
// TODO if you need to listen to generation event, add listeners to the
list here
which means you simply have to change it so that it looks like :
public List<IAcceleoTextGenerationListener> getGenerationListeners() {
List<IAcceleoTextGenerationListener> listeners =
super.getGenerationListeners();
listeners.add(new MyGenerationListener());
return listeners;
poltrox wrote:
> How can I add one class like a listener of my generator if I don't used
> The "getGenerationListeners()" method ?
> the function addListener is deprecated in abstract class and i don't
> find another solution as modify each generator
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000501030501080803070507--
FUDForum. Page generated in 0.03931 seconds
