Home » Eclipse Projects » Rich Client Platform (RCP) » Setting my own perspective
Setting my own perspective [message #542485] Fri, 25 June 2010 01:07 Go to next message
I have created my own perspective for my plug-in. Whenever I launch Eclipse, Java perspective is getting opened by default. I need to set manually my perspective after launching of Eclipse.
Is there any way by which I can set my perspective as default, so that only my perspective will be opened during launching of eclipse.
Akash Mahakode
Re: Setting my own perspective [message #542603 is a reply to message #542485] Fri, 25 June 2010 08:04 Go to previous messageGo to next message
For your install, you can add the command line to eclipse.ini, one token
per line:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/runtime-options.html
If you are creating your own RCP/Product, you can include a
plugin_customization.ini (similar to the one in
eclipse/plugins/org.eclipse.sdk_3.6.0.v201006080911
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Setting my own perspective [message #542846 is a reply to message #542603] Sat, 26 June 2010 13:38 Go to previous messageGo to next message
Thanks Paul.
-akash mahakode
Re: Setting my own perspective [message #542938 is a reply to message #542603] Sun, 27 June 2010 13:21 Go to previous messageGo to next message
Hi Paul,
My eclipse.ini file has folllowing contents..
-startup
plugins/org.eclipse.equinox.launcher_1.0.200.v20090520.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.200.v 20090520
-product
org.eclipse.epp.package.java.product
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
-vmargs
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=512m
-Xms40m
-Xmx512m
-perspective
plugins/com.akki.akkide_0.5.0.beta/com/akki/akkide/perspecti ves/AkkidePerspective
I have added -perspective option in last and my perspective is AkkidePerspective.
Please let me know whether its correct or not? If not what I do need to modify?
akash mahakode
[Updated on: Sun, 27 June 2010 13:22] by Moderator
Re: Setting my own perspective [message #542939 is a reply to message #542938] Sun, 27 June 2010 13:44 Go to previous messageGo to next message
Akash Mahakode wrote:
> -perspective
> AkkidePerspective.
> modify?
Does it come up? :-)
It should be the perspective ID as defined in your plugin.xml. The 2
lines (one for -perspective and one for the perspective ID) need to be
before -vmargs
PW
Paul Webster
Re: Setting my own perspective [message #542980 is a reply to message #542939] Mon, 28 June 2010 01:40 Go to previous messageGo to next message
Thanks a lot Paul, Its working.....
But There is one more thing that I need to do.
I would like to remove the Welcome page that is being displayed whenever Eclips eis launched.
Is there a way to remove Welcome page?
Akash Mahakode
Re: Setting my own perspective [message #543103 is a reply to message #542980] Mon, 28 June 2010 08:11 Go to previous message
to do that you need to provide a plugin_customization.ini (similar to
the one in eclipse/plugins/org.eclipse.sdk_3.6.0.v201006080911). You
can set the default perspective in that one:
org.eclipse.ui/defaultPerspectiveId=org.eclipse.jdt.ui.JavaP erspective
Normally one is provided with the product, but there's a runtime option
to specify one.
See org.eclipse.ui.IWorkbenchPreferenceConstants
Paul Webster
Previous Topic:interactive splash not working on the final product
Next Topic:Plugin from Jar
Current Time: Sat Jul 19 11:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.04618 seconds
