Home » Archived » M2M (model-to-model transformation) » how to access a tagged value of a stereotype??
how to access a tagged value of a stereotype?? [message #542468] Thu, 24 June 2010 19:54 Go to next message
hi all
can some one tell me how to access the tagged value of a stereotype;
surely it will not be treated as an attribute of the element which the stereotype is applied on,
so if i have a stereotype called x and it has tagged value called IsB and it is of type Boolean how to check its value in an ATL program
Re: how to access a tagged value of a stereotype?? [message #542859 is a reply to message #542468] Sat, 26 June 2010 16:32 Go to previous messageGo to next message
hi again
please I have made many trials but none works
actually the method getValue returns EjavaObject which I can not
retrieve it either by b or c
can some one participate, :D
aggregation <- let b : OclAny = opc.getValue(thisModule.getStereotype('ObjectProperty'),'IsC omposition') in
if b = true then
#composite
else
let c : OclAny = opc.getValue(thisModule.getStereotype('ObjectProperty'),'IsC omposition') in
--opc.getValue(thisModule.getStereotype('ObjectProperty'),'I sAggregation') then
#shared
else
#none
endif
endif
> hi all
[Updated on: Sat, 26 June 2010 18:08] by Moderator
Re: how to access a tagged value of a stereotype?? [message #542860 is a reply to message #542468] Sat, 26 June 2010 16:36 Go to previous messageGo to next message
On 14/07/1431 02:54 ص, wafaa wrote:
> hi all
Re: how to access a tagged value of a stereotype?? [message #542869 is a reply to message #542860] Sat, 26 June 2010 17:53 Go to previous messageGo to next message
Sending the same message again and again is not likely to improve your
chances of getting a helpful response.
Ed Willink
>> hi all
Re: how to access a tagged value of a stereotype?? [message #542870 is a reply to message #542869] Sat, 26 June 2010 18:05 Go to previous message
Of course "it is not again and again"
It is not my habbit, you may for example think that it was an error,
I am currently using a Mail client due to some format and the ability to attach files and it was sent by error:
by the way you can delete the repeated ones as I could not do it.
[Updated on: Sat, 26 June 2010 18:10] by Moderator
Previous Topic:how to deal with nestedPackage of a package
Next Topic:[QVTo] global variables for transformation
Current Time: Sat Jul 19 08:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.07875 seconds
