Home » Eclipse Projects » Eclipse Platform » Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK
Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542600] Fri, 25 June 2010 08:02 Go to next message
what is the difference between these terms. You can find these in Software Updates/ The Eclipse Project Updates / Uncategorized
Thanks.
[Updated on: Fri, 25 June 2010 08:02] by Moderator
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542609 is a reply to message #542600] Fri, 25 June 2010 08:29 Go to previous messageGo to next message
As in
http://download.eclipse.org/eclipse/downloads/drops/R-3.6-20 1006080911/index.php
There are different components that make up eclipse. Eclipse SDK is
everything, PDE, JDT, Platform, Equinox + source.
Equinox is the OSGi framework plus other core runtime
Platform provides the frameworks for most of the other components. JDT
is the java development tooling, and PDE is plugin development (depends
on JDT).
If they offer a Runtime vs SDK, like Platform Runtime and Platform SDK,
the different is the SDK version has all of the source plugins.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542620 is a reply to message #542609] Fri, 25 June 2010 09:14 Go to previous messageGo to next message
Thanks, but going back to the question:
what is Eclipse Platform SDK and Eclipse Project SDK
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542654 is a reply to message #542620] Fri, 25 June 2010 10:29 Go to previous messageGo to next message
I'm not sure what the Eclipse Project SDK is. It's not part of classic
eclipse. The Eclipse Platform SDK is the Platform UI/IDE/Framework
support, Resources perspective, + Equinox runtime (and all their source).
Maybe they use that interchangeably with the Eclipse Classic SDK?
PW
Paul Webster
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542702 is a reply to message #542654] Fri, 25 June 2010 12:36 Go to previous messageGo to next message
Thanks. What's the difference if there are sources bundled or not as in Platform vs. Platform SDK.
I also notice there is no Eclipse SDK w/o sources but only Eclipse SDK wich has the sources. Why?
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542709 is a reply to message #542702] Fri, 25 June 2010 12:46 Go to previous messageGo to next message
Because it includes PDE, and doing plugin development without the source
or schema is a non-starter.
PW
Paul Webster
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #542993 is a reply to message #542702] Mon, 28 June 2010 03:25 Go to previous messageGo to next message
If you do not plan to write Eclipse plugins, you may download just the
runtime at:
The minimal thing you need is the Eclipse Platform Runtime Binary. From
there, using update manager, you are able to install just the single
plugins you need (ex.: JDT, WTP, TPTP, Mylyn, etc.). I always do in this
way.
Mauro.
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543037 is a reply to message #542993] Mon, 28 June 2010 05:25 Go to previous messageGo to next message
Thanks. The question is more about the definitions of these 3 terms
When is Platfom SDK useful for example?
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543043 is a reply to message #543037] Mon, 28 June 2010 05:32 Go to previous messageGo to next message
When you need the sources of the Eclipse Platform to work with.
The difference between the different bundles is about what
plugins/components are in.
By the way, I never read about an "Eclipse Project SDK", I think it's
mispelling of "Eclipse SDK". See:
Mauro.
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543865 is a reply to message #543037] Wed, 30 June 2010 17:37 Go to previous messageGo to next message
vlad.balan wrote on Mon, 28 June 2010 05:25
Eclipse is often used to mean the Eclipse Project, so they are synonymous. Eclipse Platform is a subset of the Eclipse Project. "SDK" means it comes with source code and javadoc in the integrated help system.
(Note, that's useful only if you accept the bogus assumption that your target runtime platform and your IDE are one in the same)
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543943 is a reply to message #543865] Thu, 01 July 2010 03:30 Go to previous messageGo to next message
"Note, that's useful only if you accept the bogus assumption "
A bogus assumption is never accepted i guess. So this sentence does not make sense to me.
So Eclipse Platform SDK is never useful?
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543978 is a reply to message #543943] Thu, 01 July 2010 05:00 Go to previous messageGo to next message
Let's try to say it in another way! :-)
Do you need to develop Eclipse? An Eclipse plugin? An application based
on the Eclipse Platform (http://www.eclipse.org/platform/)?
If the reply to any of the questions is YES, then you need the SDK.
In all the other cases, the answer is you can just use the runtime.
Mauro.
Re: Ecmlipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #543997 is a reply to message #543978] Thu, 01 July 2010 06:01 Go to previous messageGo to next message
Thanks but i didn't understand Randy's phrase:
"(Note, that's useful only if you accept the bogus assumption that your target runtime platform and your IDE are one in the same) "
In any case, in what particular case is Eclipse Platform SDK sufficient in comparison to Eclipse SDK.
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544060 is a reply to message #543997] Thu, 01 July 2010 09:42 Go to previous messageGo to next message
As Mauro Molinari was saying, the SDK could be useful when you yourself are not just using eclipse as an IDE, but also developing plugins for eclipse. But, if you're not developing plug-ins that make use of the JDT, PDE, etc., then you don't need the whole eclipse project and its source code. Also, imagine you're developing plug-ins for eclipse 3.5, but you're using eclipse 3.6 for development. So, you download both the 3.5 and 3.6 versions of the eclipse SDK. You launch 3.6, and configure the PDE to use 3.5 as your target runtime. But the help system plug-ins (API reference, javadoc, etc.) in your target 3.5 SDK aren't accessible from your IDE (3.6 SDK). Similarly, if you are developing something that needs EMF, GEF, etc., and you add their SDKs to your 3.5 target (not your IDE), then you won't have their help plug-ins in your IDE either.
[Updated on: Thu, 01 July 2010 09:43] by Moderator
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544084 is a reply to message #544060] Thu, 01 July 2010 10:37 Go to previous messageGo to next message
"So, you download both the 3.5 and 3.6 versions of the eclipse SDK"
What i don't understand is why you need 2 times the sources: once ofr the IDE and for the target?
Let's say i understand the need for sources in the sens that maybe you need to modify them. Otherwise the compiled code would be enought to compile my source code against.
But why source code from 2 locations: the IDE SDK and the target SDK.
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544099 is a reply to message #544084] Thu, 01 July 2010 10:53 Go to previous messageGo to next message
Having the source is one of MAJOR advantages of OpenSource. You can step
through it with the debugger, you can look at the implementation if the
documentation is not good enough, ... .
Tom
Am 01.07.10 16:37, schrieb vlad.balan:
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544101 is a reply to message #544099] Thu, 01 July 2010 11:13 Go to previous messageGo to next message
The questions is why source code for the target and for the IDE in the same time as Randy suggests.
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544103 is a reply to message #544099] Thu, 01 July 2010 11:16 Go to previous messageGo to next message
Vlad,
The responders to your posts seem to be having a problem understanding what
you are asking. You seem to understand the concept of an SDK and why it is
not included in the binary download.
Your question appears to be related to which SDK you need to download.
There are are 3 different SDKs included in the Helios release that have
similar names, Eclipse SDK, Eclipse Platform SDK, and Eclipse Project SDK.
I noticed this as well. The Available Software dialog for installing on
Helios doesn't give any additional information to the user distinguish
between the different SDKs. You seem to want to know what source files are
included in each. Say for example you want to make a change to JDT, which
SDK do you need to download to get the source for JDT. Is it Eclipse SDK,
Eclipse Platform SDK, or Eclipse Project SDK.
What types of development does the Eclipse SDK support?
What types of development does the Eclpse Platform SDK support?
What types of development does the Eclipse Project SDK support?
Unfortunatly, I don't have an answer for you. Hopefully some of the other
responders will now realize what you are asking and be able to explain the
difference between these 3 SDKs.
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:i0ia61$lcj$1@build.eclipse.org...
> Tom
Re: Eclipse SDK vs. Eclipse Platform SDK vs. Eclipse Project SDK [message #544108 is a reply to message #544103] Thu, 01 July 2010 11:33 Go to previous message
Randy,
in your scenario, why have the Eclipse SDK 3.6 for the IDE and not just Eclipse Platform IDE 3.6 + JDT + PDE, without sources.
I understand the need for Eclipse SDK 3.5 for the target because it includes source code i may need (btw - would i need the source code of PDE itself ? ) when developping a plug-in.
Previous Topic:bash plugin
Next Topic:TextEditor annotations in OverviewRuler from IMarkers
Current Time: Sun Jul 20 03:30:11 EDT 2025
Powered by FUDForum. Page generated in 0.70610 seconds
