Home » Eclipse Projects » Rich Client Platform (RCP) » Open Dialog if close RCP
Open Dialog if close RCP [message #542376] Thu, 24 June 2010 12:13 Go to next message
Hallo,
i want open a fileDialog, if i closed the application about the X at the top (on the right side).
I have a application, and if the user want close the application, i want pop my special dialog , who can save the data.
My special dialog is a command (extend from AbstractHandler).
It is possible to use my command, if the application will closed?
I have try to open my FileDialog in the "stop" method in the calss "Activator", but this doesnt work.
Can someone helpt me ??
Thx.
Re: Open Dialog if close RCP [message #542490 is a reply to message #542376] Fri, 25 June 2010 01:36 Go to previous messageGo to next message
On 24.06.2010 18:13, budili wrote:
> Hallo,
> pop my special dialog , who can save the data. My special dialog is a
You should override the preShutdown method of your WorkbenchAdvisor
and should then programmatically invoke your command via the
IHandlerService - see either of
http://blog.eclipse-tips.com/2009/01/commands-part-4-misc-it ems.html
http://www.vogella.de/articles/EclipseRCP/article.html
how this can be done. A return value of false will prevent the
workbench from closing. Note: You emphasize that you want to do this
(only?), if the application is closed via the special system button.
I'm not sure that you can discriminate this. The above mention method
will be called either way, e.g. also if closed via "Exit" or Alt+F4.
HTH & Greetings from Bremen,
Daniel Krügler
icon14.gif  Re: Open Dialog if close RCP [message #542581 is a reply to message #542490] Fri, 25 June 2010 07:30 Go to previous message
Thank u very much,
exactly this method i have searched.
Previous Topic:Wrapping text in the table
Next Topic:Different height in different table rows
Current Time: Sun Jul 20 04:16:59 EDT 2025
Powered by FUDForum. Page generated in 0.03103 seconds
