Semantic Highlighting Job error [message #511800] |
Tue, 02 February 2010 18:02  |
I have a couple of PHP projects, recently i restored one from CVS and started getting errors whenever I attempt to edit a file. Each keystroke/insert pops up an error box that says
An internal error occurred during: "Semantic Highlighting Job".
In the error log it provides this stack trace:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
at org.eclipse.dltk.ti.GoalEngine.evaluateGoal(GoalEngine.java: 258)
at org.eclipse.dltk.ti.DefaultTypeInferencer.evaluateType(Defau ltTypeInferencer.java:223)
at org.eclipse.dltk.ti.DefaultTypeInferencer.evaluateType(Defau ltTypeInferencer.java:213)
at org.eclipse.php.internal.core.typeinference.BindingUtility.g etType(BindingUtility.java:156)
at org.eclipse.php.internal.core.typeinference.BindingUtility.g etType(BindingUtility.java:180)
at org.eclipse.php.internal.core.typeinference.BindingUtility.g etType(BindingUtility.java:150)
at org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er.getEvaluatedType(DefaultBindingResolver.java:193)
at org.eclipse.php.internal.core.ast.nodes.DefaultBindingResolv er.resolveExpressionType(DefaultBindingResolver.java:305)
at org.eclipse.php.internal.core.ast.nodes.Expression.resolveTy peBinding(Expression.java:107)
at org.eclipse.php.internal.ui.editor.highlighter.ModelUtils.ge tMethod(ModelUtils.java:42)
at org.eclipse.php.internal.ui.editor.highlighters.StaticMethod Highlighting$StaticMethodApply.visit(StaticMethodHighlightin g.java:59)
at org.eclipse.php.internal.core.ast.nodes.MethodInvocation.acc ept0(MethodInvocation.java:73)
at org.eclipse.php.internal.core.ast.nodes.ASTNode.accept(ASTNo de.java:275)
at org.eclipse.php.internal.core.ast.nodes.InfixExpression.chil drenAccept(InfixExpression.java:189)
at org.eclipse.php.internal.core.ast.nodes.InfixExpression.acce pt0(InfixExpression.java:183)
at org.eclipse.php.internal.core.ast.nodes.IfStatement.children Accept(IfStatement.java:95)
at org.eclipse.php.internal.core.ast.nodes.IfStatement.accept0( IfStatement.java:89)
at org.eclipse.php.internal.core.ast.nodes.Block.childrenAccept (Block.java:97)
at org.eclipse.php.internal.core.ast.nodes.Block.accept0(Block. java:90)
at org.eclipse.php.internal.core.ast.nodes.FunctionDeclaration. childrenAccept(FunctionDeclaration.java:108)
at org.eclipse.php.internal.core.ast.nodes.FunctionDeclaration. accept0(FunctionDeclaration.java:97)
at org.eclipse.php.internal.core.ast.nodes.MethodDeclaration.ch ildrenAccept(MethodDeclaration.java:90)
at org.eclipse.php.internal.core.ast.nodes.MethodDeclaration.ac cept0(MethodDeclaration.java:82)
at org.eclipse.php.internal.core.ast.nodes.ClassDeclaration.chi ldrenAccept(ClassDeclaration.java:118)
at org.eclipse.php.internal.core.ast.nodes.ClassDeclaration.acc ept0(ClassDeclaration.java:104)
at org.eclipse.php.internal.core.ast.nodes.Program.childrenAcce pt(Program.java:191)
at org.eclipse.php.internal.core.ast.nodes.Program.accept0(Prog ram.java:184)
at org.eclipse.php.internal.ui.editor.highlighter.AbstractSeman ticHighlighting.consumes(AbstractSemanticHighlighting.java:9 2)
at org.eclipse.php.internal.ui.editor.highlighter.AbstractSeman ticHighlighting.consumes(AbstractSemanticHighlighting.java:1 01)
at org.eclipse.wst.sse.ui.internal.style.SemanticHighlightingRe conciler.reconcile(SemanticHighlightingReconciler.java:116)
at org.eclipse.wst.sse.ui.internal.style.SemanticHighlightingRe conciler$1.run(SemanticHighlightingReconciler.java:267)
my session data reads:
eclipse.buildId=M20090917-0800
java.version=1.6.0_0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
I just want to know where to start to figure out what this is. I completely deleted Eclipse (removed all mention of eclipse from my system as found with find and grep) and reinstalled it. Same error.
There must be a config problem but I can't figure out how to debug this issue.
help
Re: Semantic Highlighting Job error [message #544558 is a reply to message #544260] |
Sat, 03 July 2010 15:52  |
NoobieRoobie wrote on Fri, 02 July 2010 03:52 | Maarten Kossen wrote on Fri, 02 July 2010 02:56 | May I ask what you mean with 'all-in-one package'?
Sure, it basically is a brand new install in its own folder by extracting a zip file.
You find multiple on this page:
http://www.eclipse.org/pdt/downloads/
The are listed below the "Eclipse PDT 2.2.0 All In Ones / Eclipse PHP Package" headline.
It might be adviseable to use a new workspace as well and to not import older projects, because even I do not get the errors any longer, PHP Search and Open Declarations (F3) does not currently work for me (even on brand new projects).
Update / Warning: I had problems re-using the already existing workspace with the new install. Projects in that workspace had problems running properly with the new standalone version.
Are those any different from the ones offered on the Eclipse download page (http://eclipse.org/downloads/)?
FUDForum. Page generated in 0.05475 seconds
