Home » Archived » M2M (model-to-model transformation) » [ATL] 1 source 2 target with 2 subdestination and referenc(1 source 2 targets with 2 subdestination and reference)
[ATL] 1 source 2 target with 2 subdestination and referenc [message #542205] Thu, 24 June 2010 05:09 Go to next message
HI,
I don't do to write my transformation :
I have this 2 models :
Source:
Module contains fields
Stringfields, NarrativeFields herited of Fields
Target :
Module contains Fields , businessObject
BusinessObject contains businessItems, BusinessFileItems
NarrativeItems herited of businessItems
StringFields herited of businessFileItems
I try 2 solution to write my transformation but i have always one problemes :
Solution 1 : Using a lazy rules with separated rules for fields and Items
rule ModuleToConnectedModule {
	from
		s : ClientMetaModel!Module
	to
		Module : AppliMetaModel!ConnectedModule (
			Labels <- s.Labels,
			BusinessObject <- BusinessObjectFunction,
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!StringField))
								   -> collect(e | thisModule.StringFieldsToStringField(e)),
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!AmountField))
								   -> collect(e | thisModule.AmoutFieldToAmountCurrencyField(e)),
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!NarrativeField))
								   -> collect(e | thisModule.NarrativeFieldToNarrativeField(e))
		BusinessObjectFunction :AppliMetaModel!BusinessObject(
		SpecificsBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!StringField))
										   -> collect(e | thisModule.StringFieldsToStringObject(e)),
		SpecificsBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!AmountField))
										   -> collect(e | thisModule.AmoutFieldToAmountCurrencyObject(e)),
		SpecificsFileBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!NarrativeField))
										   -> collect(e | thisModule.NarrativeFieldToNarrativeObject(e))
lazy rule StringFieldsToStringObject {
	from
		ClientStringfield : ClientMetaModel!StringField
		(ClientStringfield.oclIsTypeOf(ClientMetaModel!StringField))
	to
		StringItem : AppliMetaModel!StringItem(
			name <- ClientStringfield.name,
			MappingBDD <- MappingDB
		MappingDB :AppliMetaModel!MappingDB(
		name <- ClientStringfield.debug().name.toUpper(),
		Type <- StringMapping
		StringMapping :AppliMetaModel!StringDBType(
		length <- ClientStringfield.maxLength
lazy rule StringFieldsToStringField {
	from
		ClientStringfield2 : ClientMetaModel!StringField
		(ClientStringfield2.oclIsTypeOf(ClientMetaModel!StringField))
	to
		StringField : AppliMetaModel!StringField (
			name <- ClientStringfield2.name,
			maxLength <- ClientStringfield2.maxLength,
			FormLabel <- thisModule.resolveTemp(ClientStringfield2.Label,'AppliLabel'),
			BusinessItemBinding <- thisModule.resolveTemp(ClientStringfield2.debug(),'StringItem').debug(),
			password <- false,
			upperCase <- false,
			size <- 35
lazy rule NarrativeFieldToNarrativeObject{
	from
	 	ClientNarrativeField : ClientMetaModel!NarrativeField
		(ClientNarrativeField.oclIsTypeOf(ClientMetaModel!NarrativeField))
	to
		NarrativeItem : AppliMetaModel!NarrativeItem(
		name <- ClientNarrativeField.name
lazy rule NarrativeFieldToNarrativeField{
	from
	to
		NarrativeField: AppliMetaModel!NarrativeField(
		BusinessItemBinding <- thisModule.resolveTemp(ClientNarrativeField,'NarrativeItem'),
		FormLabel <- thisModule.resolveTemp(ClientNarrativeField.Label,'AppliLabel'),
		name <- ClientNarrativeField.name,
		column <- ClientNarrativeField.column,
		row <- ClientNarrativeField.row,
		size <- 35
Problems : Methods ResolveTemps do not run for lazy rules => I can't create the ref for the attribut BusinessItemBinding of Narrative fields
the second solution : Do not use Lazy rules => I can't separate Fields and Item
	from
	to
			Labels <- s.Labels,
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!StringField)).debug(),
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!AmountField)).debug(),
			FormFields <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!NarrativeField)).debug()
		SpecificsBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!StringField)),
		SpecificsBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!AmountField)),
	from
	to
			maxLength <- ClientStringfield.maxLength,
			FormLabel <- thisModule.resolveTemp(ClientStringfield.Label,'AppliLabel'),
			BusinessItemBinding <- StringItem,
			password <- false,
			upperCase <- false,
			size <- 35
Problems : In the result my fields do not populate the Modules->Fields
they are created at the root node , If I change the order of my Rule StringFieldsToStringFields, String Items is created in the root node
I can't separate this rules because ATL do not accept multiple rules with the same source.
Any one could give me a solution ?
Ps: Sorry I have a bad english, I am french and accept a english and french response Wink
[Updated on: Thu, 24 June 2010 05:36] by Moderator
Re: [ATL] 1 source 2 target with 2 subdestination and referenc [message #542225 is a reply to message #542205] Thu, 24 June 2010 05:42 Go to previous messageGo to next message
You better use the second option with resolveTemp because the resolution mechanism of ATL basically bind the "from" object to the first "to" object. By using resolveTemp you can reference the others "to" objects :
SpecificsBusinessItems <- s.Fields -> select(e | e.oclIsTypeOf(ClientMetaModel!StringField))->collect(e | thisModule.resolveTemp(e,'StringItem')
Re: [ATL] 1 source 2 target with 2 subdestination and referenc [message #542232 is a reply to message #542225] Thu, 24 June 2010 05:55 Go to previous messageGo to next message
Thank you,
It works Very Happy
Re: [ATL] 1 source 2 target with 2 subdestination and referenc [message #542339 is a reply to message #542232] Thu, 24 June 2010 10:54 Go to previous messageGo to next message
Poltrox
Do you write your ATL files all by hand?
Re: [ATL] 1 source 2 target with 2 subdestination and referenc [message #542517 is a reply to message #542339] Fri, 25 June 2010 03:40 Go to previous message
Yes , the completion with eclipse-plug in is a good help.
Previous Topic:how to use enumerations literal in Atl Program
Next Topic:[QVT-R] Suggestions for QVT-Relations plug-in
Current Time: Sun Jul 20 05:45:11 EDT 2025
Powered by FUDForum. Page generated in 0.05942 seconds
