Home » Eclipse Projects » Eclipse 4 » TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6(TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6)
TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541265] Sat, 19 June 2010 02:31 Go to next message
The setup for Eclipse 4.0 M6 (eclipse-SDK-4.0M6-win32.zip) at http://download.eclipse.org/e4/sdk/ shows Test Case failures
When I complete the setup, I see incomplete UI and functionalities. Any idea, when will the next build be available with the fixes
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541530 is a reply to message #541265] Mon, 21 June 2010 09:19 Go to previous messageGo to next message
We're publishing RC0 today. http://wiki.eclipse.org/E4/Self_Hosting has
the list of known issues that need to be worked on for 4.0
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #541892 is a reply to message #541530] Tue, 22 June 2010 21:36 Go to previous messageGo to next message
Thanks... Will work with RC0
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #578072 is a reply to message #541530] Tue, 22 June 2010 21:36 Go to previous message
Previous Topic:TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6
Next Topic:e4 RC0, moved IEclipseContext where?
Current Time: Sat Jul 19 17:42:13 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
