Home » Modeling » OCL » Using getValue(Stereotype, String) with Collections. Possible bug? (I can only manage to retrieve the first element of a collection)
Using getValue(Stereotype, String) with Collections. Possible bug? [message #540251] |
Tue, 15 June 2010 09:30  |
Dear all,
I am trying to construct an OCL constraint that has to navigate all the elements of a property in a stereotype with [0..*] multiplicity. However, the following code returns true when two elements are included in the property list:
(The context is a UML Element)
self.getValue(self.getAppliedStereotype('Qualified::Name'), 'property')->size() = 1
However, if the collection is empty, the I do get a false in the query. Is this a bug or am I doing something incorrectly?
Thanks in advance!
Adrian
Re: Using getValue(Stereotype, String) with Collections. Possible bug? [message #540321 is a reply to message #540251] |
Tue, 15 June 2010 11:40   |
--------------080508090106060504050903
Hi Adrian,
This is a know bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=287052 .
In short, the "Element::getValue()" UML operation is defined to return
an "EJavaObject", and OCL will discard any value other than the very
first of Collection returned by such operations. If you use pure OCL, I
can't propose any workaround.
However, if you're using OCL through Acceleo templates, you can delegate
the call to the UML EOperation by using a Java service which explicitely
returns a Collection.
Laurent Goubet
Obeo
Adrián Noguero wrote:
> Dear all,
> Thanks in advance!
> Adrian
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080508090106060504050903--
Re: Using getValue(Stereotype, String) with Collections. Possible bug? [message #543728 is a reply to message #543467] |
Wed, 30 June 2010 08:28   |
--------------090600020101000605000800
Hi Gaetan,
This would be better asked on the m2t newsgroup :). The thing is :
Acceleo allows you to call for Java methods in addition to plain OCL.
OCL has the symptom of discarding any additional value from these
collections, Java doesn't. Do note that this only applies if you're
using Acceleo (generating code), not if you're using plain OCL (to write
constraints on your models for example).
In short, create a Java class (say "fr.sopragroup.UMLService") with method :
public List<Object> getTaggedValue(Element element, Stereotype
stereotype, String property) {
List<Object> result = new ArrayList<Object>();
Object value = element.getValue(stereotype, property);
if (value instanceof Collection) {
result.addAll((Collection)value);
else
result.add(value);
return result;
create an Acceleo query that will delegate to this method :
[query public getTaggedValue(Element element, Stereotype stereotype,
String property) : Sequence(OclAny) = invoke('fr.sopragroup.UMLService',
'getTaggedValue(org.eclipse.uml2.uml.Element,
org.eclipse.uml2.uml.Stereotype, java.lang.String)', Sequence{element,
stereotype, property})/]
(yes, pretty verbose. We have facilities to create these queries, look
at the included documentation for more information).
Then you can use "getTaggedValue(element, stereotype, property)" from
any Acceleo template or query to get the list of tagged values.
Laurent Goubet
Obeo
gruault@sopragroup.com wrote:
> I have the same problem.
> Laurent :
> " However, if you're using OCL through Acceleo templates, you can
> delegate the call to the UML EOperation by using a Java service which
> explicitely returns a Collection.
> Laurent could you describe how i can "solve" it with java service?
> thanks
> gaetan
--------------090600020101000605000800--
Re: Using getValue(Stereotype, String) with Collections. Possible bug? [message #1708689 is a reply to message #1708674] |
Fri, 18 September 2015 14:15  |
You are piggybacking on a five year old thread that reported a bug fix.
It is very unlikely that you have the same problem unless you are using
a five year old release; upgrade.
Your question has a typo in that makes it unintelligible.
The new PIvot-based OCL supports typesafe stereotype navigation without
using the tape-unsafe Java API.
Ed Willink
On 18/09/2015 16:49, Salim CHEHIDA wrote:
> Hi Adrian,
> how you are used eCrossReferences() to formulate the OCL constraint?
> are you have other solutions?
> thanks
> salim
Current Time: Sun Jul 20 07:40:38 EDT 2025
Powered by FUDForum. Page generated in 0.04410 seconds
