Home » Modeling » EMF » One editor for ecore metamodel organized with several packages
One editor for ecore metamodel organized with several packages [message #540213] Tue, 15 June 2010 08:13 Go to next message
Originally posted by: templth.yahoo.fr
I have an ecore metamodel organized with several packages and I want to
have a single editor for this model. But, when I try to generate the
editor, several ones are created, one per package. Is it possible to
change this behavior for example within the genmodel model?
Thanks very much by advance for your help.
Thierry
Re: One editor for ecore metamodel organized with several packages [message #540256 is a reply to message #540213] Tue, 15 June 2010 09:10 Go to previous messageGo to next message
Thierry,
I'm not sure how the classes in the packages are related, but
http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html
might be helpful. All generated editors look pretty much the same and
since the generated item providers register themselves, every generated
editor will automatically use the item providers appropriate for the
instances being displayed, so you can just generate one of the editors.
You'll need to mess with the wizard to have a single wizard that allows
you to create root instances from multiple packages.
Thierry Templier wrote:
> Hello,
> Thierry
Re: One editor for ecore metamodel organized with several packages [message #540436 is a reply to message #540256] Wed, 16 June 2010 03:36 Go to previous messageGo to next message
Thanks very much Ed!
By specifying the false value within the "Generate Model Editor"
property of packages, I can prevent from having several editors. The
remaining problem is: I can only have elements present in the package
"associated" editor as root elements. Is it possible to change that
behavior with a property within the genmodel?
Thierry
> Thierry,
Re: One editor for ecore metamodel organized with several packages [message #540508 is a reply to message #540436] Wed, 16 June 2010 08:25 Go to previous messageGo to next message
Thierry,
No, you'll need to change the wizard to support creating objects from
many packages.
> Thierry
>> Thierry,
>> generated editor will automatically use the item providers
>> appropriate for the instances being displayed, so you can just
>> generate one of the editors. You'll need to mess with the wizard to
>> have a single wizard that allows you to create root instances from
>> multiple packages.
Re: One editor for ecore metamodel organized with several packages [message #540610 is a reply to message #540508] Wed, 16 June 2010 12:52 Go to previous messageGo to next message
Thanks very much for your answer, Ed. I saw that there are some impacts
in the editor class in methods createInitialModel and
getInitialObjectNames. By updating these two methods, it works fine!
I have another question in this context (several packages within the
same metamodel). Is it possible to specify only one metamodel identifier
for all packages. I saw that one is associated with each package...
Thanks very much,
Thierry
> Thierry,
> many packages.
>> Thierry
>>> Thierry,
>>> multiple packages.
Re: One editor for ecore metamodel organized with several packages [message #540612 is a reply to message #540610] Wed, 16 June 2010 13:05 Go to previous messageGo to next message
Thierry,
No, each EPackage must have a globally unique nsURI.
> impacts in the editor class in methods createInitialModel and
> identifier for all packages. I saw that one is associated with each
> package...
> Thanks very much,
> Thierry
>> Thierry,
>> many packages.
>>> package "associated" editor as root elements. Is it possible to
>>> change that behavior with a property within the genmodel?
>>> Thierry
>>>> Thierry,
>>>> and since the generated item providers register themselves, every
>>>> to have a single wizard that allows you to create root instances
Re: One editor for ecore metamodel organized with several packages [message #540947 is a reply to message #540612] Thu, 17 June 2010 12:24 Go to previous message
Thanks very much for the hint, Ed.
Thierry
> Thierry,
Previous Topic:.genmodel reload forces encoding of OCL expressions in annotations.
Next Topic:Databinding SimpleFeatureMapEntry / EList<String>
Current Time: Sun Jul 20 02:24:22 EDT 2025
Powered by FUDForum. Page generated in 0.06473 seconds
