Home » Modeling » M2T (model-to-text transformation) » [Acceleo] No common supertype error(No common supertype compiler error on generated Java Service wrappers)
[Acceleo] No common supertype error [message #540304] Tue, 15 June 2010 11:09 Go to next message
I've tried to create a Java Service Wrapper (using the wizard), but I'm receiving some compile errors.
My Java Service is called UMLServices.
Here's the method that is causing an issue:
public boolean isMarked(Element element, String mark)
for (Stereotype stereotype : element.getAppliedStereotypes())
if (mark.equalsIgnoreCase(stereotype.getName()))
return true;
for (String keyword : element.getKeywords())
if (keyword.equalsIgnoreCase(mark))
return true;
return false;
The generated Acceleo mtl file looks like this:
[module umlservices('http://www.eclipse.org/uml2/2.1.0/UML')/]
[query public isMarked(arg0 : Element, arg1 : String) : Boolean
= invoke('com.pwc.us.mda.services.UMLServices', 'isMarked(org.eclipse.uml2.uml.Element, java.lang.String)', Sequence{arg0, arg1}) /]
It seems fine, but the compiler is showing an error:
Type mismatch. No common supertype: (Element), (String)
I've done some debugging and it seems to happen when my service method takes more than one parameter that do not have a common superclass. Why? How can I change my service method or query to get this to work?
Frank
Re: [Acceleo] No common supertype error [message #540506 is a reply to message #540304] Wed, 16 June 2010 08:34 Go to previous messageGo to next message
I found that this same code works in a pure Helios Modeling environment.
I get the compile error while in an RSA environment, with the same Acceleo 3.0.X build installed. Does anyone know what plug-in dependency might be causing this?
Re: [Acceleo] No common supertype error [message #540809 is a reply to message #540506] Thu, 17 June 2010 08:28 Go to previous message
--------------010705030905030504020809
Hi Frank,
Unfortunately, most type checking issues are pure OCL. The best answer I
can give you is : your RSA environment is based on Eclipse 3.4 or 3.5,
thus OCL 1.2 or 1.3. A good number of such issues were fixed with OCL
1.3, even more have been fixed with OCL 3.0 (available in Eclipse 3.6,
Helios).
I believe that what you get here was fixed with OCL 1.3, but I might be
mistaken. Either way, if you cannot upgrade your RSA environment, I
cannot propose any intelligent workaround for this.
Laurent Goubet
Obeo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010705030905030504020809--
Previous Topic:XtendParser
Next Topic:Accessing a set that's actually a sequence
Current Time: Sat Jul 19 08:16:44 EDT 2025
Powered by FUDForum. Page generated in 0.03560 seconds
